First Fire In New Stove Guidelines Please
Discussion in 'Modern EPA Stoves and Fireplaces' started by Kimberly, Feb 10, 2016.
  1. TurboDiesel
    Oh, Long John silvers comes to mind here:picard::zip:
    brenndatomu likes this.
  2. Woody Stover
    Woody Stover
    Southern IN
    Whoa, back up the truck! :)
    :Yar: :rofl: :lol: Is the antenna you installed an OTA (over-the-air) TV antenna? This is something I know a little bit about....besides the fact that your stack is too short. ;) I have a double bow-tie antenna (actually an outdoor antenna) in the bedroom, mounted on a 6' PVC pipe attached to a pedestal fan base. Since it is inside the house, I don't have to worry about grounding for lightning protection. I have a pre-amp installed to compensate for running the signal through a splitter (I have a TV tuner card in my computer.) If you are feeding only one TV, and the coax run (RG6) is under 100', you don't need a pre-amp...in fact, it might be counter-productive. With this setup, I can regularly get solid reception of stations that are up to 60 mi. away (I do have a good location, but the far-away transmitters are not line-of-sight to my antenna.) I've included a link that will show what stations may be available to you. You can also have it draw in the lines to the transmitters, show a terrain map so you can pinpoint antenna position, etc. There are only a couple of stations where I may need to move the antenna. The majority come in without adjusting it, thanks to the gain and the 90* beamwidth of this particular antenna. And some stations come in through the back of the reflector screen. The second pic is of a small indoor Terk log-periodic antenna (similar to the "fish-bone" antennas that used to be on everyone's roof.) It works well but only has a 30* beamwidth, so it's more directional and may need more adjustment if your stations aren't all in one direction. Note that it has rabbit-ears in case you have weaker VHF stations that you want to get. The two VHF stations I need come in fine with the double bow-tie antenna. This un-amped version is no longer available, only the amped version. :(
    TV Fool
    milleo, Kimberly, bobdog2o02 and 4 others like this.
  3. Kimberly
    Kimberly
    The Kangaroo State
    Yes, my friend gave it to me; he ordered a new one for his house.
    Here is a photo of what mine looks like; this is from the internet and not my actual antenna but the exact same antenna.
    milleo, HDRock and Well Seasoned like this.
  4. Eric VW
    This thread should be renamed Grand Central for all the rails running to and fro....
    S'ok tho....
  5. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    41 pages, i got $20 that it hits 50 by Friday. Did i mention that if you have anything other than a BK stove, its not a real stove. Also you MUST, I repeat MUST, stack your spits with the bark facing up.
    papadave, concretegrazer and Eric VW like this.
  6. Eric VW
    I got $20 bucks says you didn't mean to type "spits."
    :thumbs:
  7. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Fork it over, it was a test to see if youd catch it.... But thinking about it, which side is up on a spit?
    Eric VW likes this.
  8. Eric VW
    Was that pic at your spit spot?
    bobdog2o02 likes this.
  9. TurboDiesel
    no way...
  10. concretegrazer
    concretegrazer
    Southwest MO
    The side that's not down....
    papadave, bobdog2o02 and Eric VW like this.
  11. TurboDiesel
    this thread...
  12. TurboDiesel
    could ...
  13. TurboDiesel
    hit fifty pages...
  14. TurboDiesel
    by friday....
    unclefess, bobdog2o02 and Eric VW like this.
  15. TurboDiesel
  16. Eric VW
    Nice cascading effect TD:rofl: :lol::thumbs::yes:
    :D
    TurboDiesel and bobdog2o02 like this.
  17. brenndatomu
  18. concretegrazer
    concretegrazer
    Southwest MO
    What you did there... I seen it....:rofl: :lol:
    yooperdave, milleo, papadave and 2 others like this.
  19. TurboDiesel
    ya know it gives you an error each time you post like that?
    tells you that you have to wait so many seconds before posting?...
    and it adds three more seconds with each post?
    me either ... but I do now:rofl: :lol:
  20. concretegrazer
    concretegrazer
    Southwest MO
    Something to do with spam I believe.:grizz:
