First Fire In New Stove Guidelines Please
Discussion in 'Modern EPA Stoves and Fireplaces' started by Kimberly, Feb 10, 2016.
  1. HighCountry
    HighCountry
    New Mexico
    He should at least get to write the preface.
  2. Kimberly
    Kimberly
    The Kangaroo State
    I pushed it as hard as I could into the wood.
  3. Kimberly
    Kimberly
    The Kangaroo State
    The sweet gum I have been burning is two years old. I have not burned any of the sweet gum I cut at the beginning of the year but could look for it in the stacks and test; that wood may be too wet. Most of the poplar was split small just for the purpose of helping it to dry but there may be some larger pieces in the stack. I am worrying over the creosote and hope the wood is not causing it.
  4. Kimberly
    Kimberly
    The Kangaroo State
    See, I didn't know how hot things should be cruising at; I have been afraid of things getting too hot; the manual warns of over firing the stove.
    bobdog2o02 likes this.
  5. Kimberly
    Kimberly
    The Kangaroo State
    Yes, there have been times I watched the stove and witness this.
  6. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Creosote where? Have you seen some. In the pipe? If the chimney "stack" temp isnt higher than 100C, 212F then steam which is a product of combustion will condense on the inside of the chimney, the wet pipe then acts like an adhesive and grabs the particles of smoke to make creosote..... The pipe has to be HOT, HOT HOT HOT.
  7. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Overfire for your stove would be stove top temps above 650-700F, can you post a pic of the magnetic thermometer you purchased.
    saskwoodburner and Eric VW like this.
  8. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Your stove is too cold if your not seeing these secondaries with wood in it. again, you need more wood in there.
    saskwoodburner, fox9988 and Eric VW like this.
  9. Kimberly
    Kimberly
    The Kangaroo State
  10. Kimberly
    Kimberly
    The Kangaroo State
    I think tomorrow morning I will do an inspection of the chimney at the tee.
  11. concretegrazer
    concretegrazer
    Southwest MO
    If there's not enough draft to pull air through to the baffle you won't have them either.
    HDRock likes this.
  12. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Without enough heat in the pipe there will surely be not enough draft.
    Kimberly run that thing hard enough to get up to 400 on that thermometer. It won't hurt anything.... I bet your draft gets established around 350....
  13. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Btw, good on you for getting the condar. Not as cheap but far higher quality.
    Eric VW likes this.
  14. yooperdave
    That, too, was given and sent to her....
    :headbang:
  15. concretegrazer
    concretegrazer
    Southwest MO
    & she won't get enough heat without enough draft.;) It's kinda hard to get one going with only 3' of effective stack.
    Eric VW likes this.
  16. concretegrazer
    concretegrazer
    Southwest MO
    I fail to see the value of your post. Is she here begging for stuff? I haven't seen it... Our good hearted community has freely helped her out.
  17. yooperdave
    And a very good hearted community indeed!
    However, there is a big difference to a helping hand and a hand out!
  18. Kimberly
    Kimberly
    The Kangaroo State
    It was a gift from a member on FHC; see my post here: A Nice Gift | Firewood Hoarders Club
    I still need to buy one for the stove top to replace the oven thermometer I am using.
  19. Kimberly
    Kimberly
    The Kangaroo State
    Yes, the members here have helped me out with chainsaws and chaps and one member made me some brackets for the chimney and of course there has been lots of information to help me learn. All they ask is for me to pay it forward which I will try to do. May is the postal carriers food drive and I contribute each year and this year I will try to contribute double as a way to pay it forward. I will look for other ways as well.
    concretegrazer likes this.
  20. Kimberly
    Kimberly
    The Kangaroo State
    Yes, that is true. I was waiting on a sale or a find on the fleabay. I think I should just go ahead and get one at Lowes when I go out this week for groceries.
    papadave and concretegrazer like this.
