First Fire In New Stove Guidelines Please
Discussion in 'Modern EPA Stoves and Fireplaces' started by Kimberly, Feb 10, 2016.
  1. HDRock
    :smoke:
    Eric VW likes this.
  2. Eric VW
    Don't know what your book says, but the common placement on stovepipe is 18" above stove top....
  3. HDRock
    There you go :thumbs:a picture of what you have going on that's what we need here
    bobdog2o02 and Eric VW like this.
  4. Kimberly
    Kimberly
    The Kangaroo State
    I took a look at the code, you have the text aligned centre. Edit and remove the align centre and see if it corrects.
    Eric VW likes this.
  5. Eric VW
    Winner winner, (too late tonight for) chicken dinner!
    What the heck happened? I dunno!
    :thumbs::rofl: :lol:
    concretegrazer, HDRock and Kimberly like this.
  6. HDRock
    Oh! I don't know, but I got an error:wacky:
    Eric VW likes this.
  7. concretegrazer
    concretegrazer
    Southwest MO
    Just a thought Kimberly . Is your cleanout door on the T sealed well? Any airleaks in the flue system hurt draft. And I know you know you need all you can get on that short stack. It might be beneficial to try & seal the pipe inside.
    basod, papadave, fox9988 and 3 others like this.
  8. Kimberly
    Kimberly
    The Kangaroo State
    If you mean the stove pipe, the manual stated not to seal the joints on the stove pipe. Plus, I was told that I would need to be able to separate them for inspection of creosote buildup
  9. Kimberly
    Kimberly
    The Kangaroo State
    I will check the plug on the tee. What about the one foot section under the tee; should I leave that in place? What about where the tee sits on the support plate, it just sits without any mechanical connection.
    Eric VW likes this.
  10. concretegrazer
    concretegrazer
    Southwest MO
    Yes the stove pipe normally isn't sealed. And it will be a pain to disassemble but shouldn't be to bad.
    Eric VW likes this.
  11. concretegrazer
    concretegrazer
    Southwest MO
    Good questions that I can't answer. lol! I've just read that the plug has been a problem for some. Haven't heard of any other issues with the class A.
    Eric VW likes this.
  12. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
    Have you tried cracking window or door slightly open while it is burning to see if it makes a difference?
    Gary
  13. yooperdave
    I didn't need to, it was so marginal, but I cleaned my glass only once this season. Nice wood!
    Eric VW likes this.
  14. Kimberly
    Kimberly
    The Kangaroo State
    Yes, that really does not make a difference.
  15. Kimberly
    Kimberly
    The Kangaroo State
    I would guess you would need proper draft through the stove so there is air traveling through the chambers including the air wash chamber.
  16. papadave
    Kimberly, that brown pattern is normal on most stoves. Have a hot wide open fire for a little while and most of it should burn right off.
    "Normal" (very subjective term) pipe thermo placement is about 18" up from the stove. Try using it on several spots on the stove top as well, to find the "hotspot".
    basod, HDRock and Eric VW like this.
  17. Kimberly
    Kimberly
    The Kangaroo State
    I think I will remove the section of chimney under the pipe and see what effect. The purpose of that section, in my guess, is to collect debris that could block the chimney; is that correct?
    Eric VW likes this.
  18. Kimberly
    Kimberly
    The Kangaroo State
    I will still need to get a thermometer for the stove top. I had an old cooker thermometer for the oven. The manual states above the door on either the right or left side. So does that mean place it near the edge of the top of the stove above the door? I wish the manual was more specific on these things. For those with the pdf, it is page 18.
  19. yooperdave
    Kim, DexterDay and Eric VW were not asking you to stick the prongs into you skin!
    If you read Dexter's post, he asked you to "lay" the prongs across your palm. Very common way to test the meter and many members here have done it. Kind of a verification thing going on, you know?
    bobdog2o02, wildwest, HDRock and 3 others like this.
  20. papadave
    You know, you could move it around and see what readings you get. Sometimes, the best answer isn't in the manual.
    Yooper's correct (as are Dex and Eric).....just lay the prongs across the skin. No one's suggesting you skewer yourself.:pain:
    You can use the same thermo on either surface as a guideline.
    wildwest, HDRock, Eric VW and 2 others like this.
