First Fire In New Stove Guidelines Please
Discussion in 'Modern EPA Stoves and Fireplaces' started by Kimberly, Feb 10, 2016.
  1. Kimberly
    Kimberly
    The Kangaroo State
    Oh, not too mention the 90 in the stove pipe and the 90 (tee) in the chimney which I have been told reduces it more.
  2. Kimberly
    Kimberly
    The Kangaroo State
    No, that was not it at all, I have been trying to tell you but YOU won't listen that the wood was dry. Now I have the data to back up my statements!
  3. Kimberly
    Kimberly
    The Kangaroo State
    Now why would I want a non EPA stove; especially since non EPA stove will no longer be manufactured; which uses more wood and produces more pollution? I could have purchased several non EPA stoves from Northern Tools at half the cost of the one purchased. No, what I need to do is to work at correcting the problem I have with the draft, and the first thing would be having the required chimney height.
  4. basod
    basod
    Mount Cheaha AL
    Kimberly sounds like the moisture meter is dispelling the wet wood idea. Might be a good idea to check its accuracy on a fresh sapling split
    It still wouldn't hurt to try some dry pallet wood to see if you can get the door shut on a hot stove.
    Does the stove have a pipe tap fitting for hooking up a manometer? you could cob something together with some aquarium air tank hose, or any transparent tubing and use a tape measure..
    Just an aside on the gum - it does smoke more than other woods, even seasoned, it's the only wood I have to ease the door open with to reload - and I rarely have a draft issue due to ambient temps
  5. basod
    basod
    Mount Cheaha AL
    they will light off well on a hot coal load, or under a pile of kindling with a good draft.
    Stick a blow torch on one and see resulted char wood go out in a few seconds after removing the flame
    HDRock likes this.
  6. yooperdave
    Well then "dry wood girl", I congratulate you on the moisture of your wood!:thumbs:
    Now with all the experience and time you have accrued to wood burning, you'll be a regular fountain of knowledge!!:whistle:
    I humbly apologize for the decades of wood burning, cutting, processing, splitting, stacking, etc. etc. that I acquired thinking I could actually share some of that knowledge to benefit others. My bad!:picard:
    I stand at your service with your now almost a week and a half of burning experience!:D
    Burn safe!
    (Are you my ex-wife by the way???):doh::rofl: :lol:
  7. Brad38
    Brad38
    S. Indiana
    :picard:
  8. brenndatomu
    X2
    HDRock likes this.
  9. Brad38
    Brad38
    S. Indiana
    Congrats on all of your successes so far, Kimberly! You've already taken on more diy work than I did with my install. You should be proud. Yes, you do have a few more obstacles to overcome it seems, but you're already aware of those, so just give it a little time. Someone that has made it this far will be successful.
  10. DexterDay
    DexterDay Administrator
    Northeast Oh
    Did you bury the prongs in the wood completely?
    Can you do me a favor and lay the moisture meter prongs across the palm of your hand and tell us the reading?
    Because the black soot is another sure sign of wet wood. I am rooting for you. From the saw you got, the brackets I made, etc.. I am not throwing stones.
    Just here to help. But there is numerous signs. I've cleaned my glass one time this year (and it was only grey and ashy as it is now). I've seen numerous stoves that it was so hard to remove they needed a razor blade. But it was the wood. An arm load of my wood made all the difference in the world.
  11. DexterDay
    Northeast Oh
    It has been since around new years since I cleaned this (again, only time this year. Stove is in the basement. So I'm the only one that sees it).
    The staining (ash pattern) you see is because of the air wash. Only the top center portion gets hit with the largest quantity of cold/fresh air.
  12. HDRock
    bobdog2o02 likes this.
  13. Star Gazer
    Star Gazer
    Right behind you
    Looking at the picture of your stove, I might suggest you tap that lower hinge pin for the door back into place before it falls out. Even push the top plate with the holes in it back into place. That might help straighten out the air wash system.
    concretegrazer likes this.
  14. Flamestead
    Flamestead
    Windsor County, VT
    Maybe he could come do mine, after he fixes his? I don't worry too much about it, but it does bother others in the household.
  15. HDRock
    I think gravity will probably keep it in there pretty good
  16. papadave
    No top plate....those are burn tubes.
  17. yooperdave
    Same thing happened to the 13 of mine. Only thing, mine was raised about 1" or a bit more! No worry, still had room and even if it did come all the way out, the door wouldn't fall off. Never even noticed it, Discovered it when I changed the gasket on the door.
    I believe that is a ceramic board on top of secondary burn tubes that you are seeing.
  18. brenndatomu
    The hinge pin on my VZ rides up like that. If you pound it down, the door squeaks when you open/close it, until the pin rides right back up to where it was...where it stays...if you leave it alone.
    DexterDay, HDRock and Eric VW like this.
  19. yooperdave
    Same squeaking results with the 13. Put a little WD on it..very little, mind you!
    DexterDay, wildwest and Eric VW like this.
  20. Eric VW
    Both good empirical angles here, that you will no doubt give attention to, Kimberly :thumbs:
    DexterDay likes this.
