First Fire In New Stove Guidelines Please
Discussion in 'Modern EPA Stoves and Fireplaces' started by Kimberly, Feb 10, 2016.
  1. HDRock
    I saw pics of your stacks in looks like they are stacked and covered just fine, single rows will dry best.
    What I don't understand is why are you quoting things in metric, when you are an American living in Virginia, what is up with that?
  2. Kimberly
    Kimberly
    The Kangaroo State
    No, there are not running water on the property; I wish there was as it would be a source for irrigation.
    I am burning wood that has been keep out of the weather that was cut some 2 1/2 years ago; so it is not wet wood, no, I can not tell you at the moment the precise amount of moisture in it but it is not wet wood.
  3. HDRock
    I'm glad for you that you finally got your Stove up and running and you're sitting there nice and toasty now
  4. Eric VW
    Gotta be better than 50F, right?:thumbs:
    Flatlander Pete, basod, Horkn and 4 others like this.
  5. HDRock
    That's for damm sure:fire:
    Flatlander Pete, basod, Horkn and 2 others like this.
  6. brenndatomu
    Well wet wood, or not, short chimney, or not, this ^ ^ ^ was the end game right?! :thumbs:
    basod, Horkn, papadave and 2 others like this.
  7. Kimberly
    Kimberly
    The Kangaroo State
    Because I trained in the SI system; the world does not use US system. The US came close to going to SI but instead of just teaching it, they did the stupidity of conversions. Instead of just saying, this is a meter stick, they taught it in relation to a yard stick, throw out the yard stick and just use the meter stick. Eventually the US will have to convert because it will be left behind in trade by the rest of the world.
    However, I can use feet. The stack is around seven feet tall. I plan on relocating the stacks and stacking them better. Prevent ground moisture at the bottom of the stacks and have them so the air circulates through the stacks better.
    Eric VW likes this.
  8. Kimberly
    Kimberly
    The Kangaroo State
    Yes, I can take the coats off!
  9. brenndatomu
    I grew up with the US system (still use it) but as a former jap bike mechanic...I had to learn the metric measuring system...I gotta admit, it does make more sense, so simple once you understand it
    Horkn, papadave and Eric VW like this.
  10. Kimberly
    Kimberly
    The Kangaroo State
    To tell the truth, I don't know what I am suppose to be seeing in the stove. I don't really know how it is suppose to be operating. I have read posts on here about pipe temperature and stove top temperatures and how they should be this or that. My friend keeps telling me that if I don't do it correctly I am going to get creosote build up in the stove pipe and chimney; I don't want that to happen.
    Eric VW likes this.
  11. Eric VW
    :whistle:
    I've got to locate a good conversion app for sure :thumbs:
    bobdog2o02, Horkn and HDRock like this.
  12. HDRock
    The simplest thing you can do now for your draft is get another adjustable elbow and put in 2 45s instead of what you have, it will make a difference, in the meantime get you a Moisture Meter and burn up some wood and stay warm:dex:
  13. Eric VW
    Until you get all angles under scope, you may very well see some build up. As long as you don't see(once you get at least a magnetic thermo) temps on your flue pipe in the "overfire" range, any creosote that mite build up shouldn't ignite.
    You're going to be fine. Chillax, chick.:thumbs:
  14. Kimberly
    Kimberly
    The Kangaroo State
    So I don't have to throw away what I have now? That would not be so bad. We are in the middle of a snow storm that is going to dump around six inches before it warms up and melts away on Tuesday.
    Flatlander Pete, Horkn and Eric VW like this.
  15. Eric VW
    Always save pipe bits. Regardless.:thumbs:
  16. HDRock
    No you wouldn't have to throw anything away probably have to do some more cuts on the pipe you already have though
  17. brenndatomu
    That's true, you could get another adjustable elbow and then make 45s outta 'em. I like non adjustable elbows better, but with how short your stove pipe setup is, it should be fine. If you ever need to replace the stove pipe in the future, it would be good to go non adjustable...just one less "moving" part
  18. Kimberly
    Kimberly
    The Kangaroo State
    Last night I let the fire go out and it was cold in the house this morning. Can I do an overnight burn? If so, how do I go about it?
    Flatlander Pete, Eric VW and Horkn like this.
  19. brenndatomu
    I wouldn't until you get things working right...mainly so you can close the door completely
  20. brenndatomu
    You could get a big ole pile of red hot coals made up in there...then leave that for the night (with the door closed) that will give you some extra heat
