First fire in EPA rated Hearthstone Green Mountain 60
Discussion in 'Modern EPA Stoves and Fireplaces' started by gaberelli, Nov 28, 2022.
  1. Rich L
    Rich L
    Eastern Mass.
    I don't know if I've ever heard of over night burns with a small stove.So many say they think they should have gone with a larger stove.It's very expensive to make the wrong decision.
  2. gaberelli
    gaberelli
    Wisconsin
    This is super helpful, thanks. I have been using my largest logs for the overnight thinking they would burn longest thinking more surface area on more smaller logs would just burn up the load faster. Going to try stuffing more full with smaller logs tonight and see.
  3. gaberelli
    gaberelli
    Wisconsin
    Yeah, a larger stove would have made it easier, no doubt, but even this one on low gets it up close to 80 in here on a full load of logs so a bigger stove make have cooked me out even on low. Space is 1000 sq ft but I am only actually heating about 750 or so as the rest is cold storage.
  4. Backwoods Savage
    As for longer burns, I do not like real small splits as that will tend to give you a quick hot fire but not a long burn.
    My stove is not large (2.2 cu ft firebox) but we make out quite well. Naturally the first thing to consider is what kind of wood you are burning during the nights. You want the best wood for that time. Here, this means oaks. White is a bit better than red but both are good. In your area I'd guess hard maple should be abundant. Regardless I burn sometimes all ash and even soft maple. But if I am stocking up for a long burn throwing good amounts of heat, oak gets the nod.
    The key for me is to have at least a small bed of coals and the rake or shove those coals toward the front of the firebox. Make sure there are not a lot of hot coals in the rear of the stove. That bottom rear is the magic area. I like to put either a decent sized round there or a large sized split. This is the key to a long burn. Now pack that stove with the rest of the splits or small rounds.
    I do not know your burning habits but will tell you mine. for our stove we want the stovetop to reach 250 degrees which turns out to be about half the interior temperature of 500. That 500 is what the catalyst needs to fire up. It also helps to have a flue temperature of around 400. Naturally it is slightly different if going from a cold stove vs an already hot stove. It also depends a lot on the quality of the firewood. But even if the stovetop is at 250 or more, you need to let the fire get started good before engaging the cat. Most times 5-10 minutes will be enough but take longer if necessary. Just don't burn up half the wood then expect the rest to last the night.
    Also, when the cat is engaged, I dial down the draft to where there is only a small flame; very small flame. Let the cat do the work. That is what it is there for along with getting a clean burn.
    I hope all this has made sense. Good luck.
    gusty60, T.Jeff Veal, Eric VW and 4 others like this.
  5. gaberelli
    gaberelli
    Wisconsin
    My woodpile is exclusively red and white oak, so doing as good as I can there. To leverage a true scientific method, I plan to only change one variable at a time. First, I will try and load it up as late as possible with the same large oak splits, coals in front with largest split in rear, and see how she fares. Part of this is being ok with an "ugly fire" that is just toking along dark but hot.
    If I still don't make it until morning in the 60's for room temp, I will try loading more full with smaller splits and see if there is any difference. Thankfully, if you can say that, the low is zero every night for the next few so at least outside time will be consistent... :)
    Appreciate all the insights! Confident I will figure out a good approach.
  6. Oldhippie
    Oldhippie
    Ashby Ma
    Buy from Woodstock Soapstone and this is off the front page of their website.
    "Enjoy the radiant, efficient and gentle heat of a Woodstock Soapstone stove in your home for up to six months. If you are not entirely delighted, we will buy the stove back at the price you paid. We even cover the cost of the return shipping!"
    I have seen them be flexible with the 6 months if you're replacing with another of their product line.
  7. Rich L
    Rich L
    Eastern Mass.
    How insulated is your space ? I lit a Hearthstone 1 once in Maine on a Friday night -3 and the new log cabin retained that heat until Sunday morning on one load on a bed of coals.That place was well insulated and retained the heat.
  8. gaberelli
    gaberelli
    Wisconsin
    This is a good point...the walls here are only 2x4 and attic DOES need some more insulation after disruption from remodel. I plan to rent an insulation blower and refresh the attic space at least.
  9. Canadian border VT
    I would do that insulation as soon as possible.
  10. RGrant
    RGrant
    Connecticut
    Forgive my ignorance- I just want to orient something in my mind.
    The building you’re heating with the wood stove: is this living space or is this some kind of office?
    T.Jeff Veal and Backwoods Savage like this.
  11. Rich L
    Rich L
    Eastern Mass.
    If you can afford it foam is the best.
  12. gaberelli
    gaberelli
    Wisconsin
    Office in detached ancillary structure. Formerly an insulated and heated (overhead propane) garage.
  13. gaberelli
    gaberelli
    Wisconsin
    Yes but since there is already a decent layer of blown in up there already, I think it best to just fill in and add to it.
  14. RGrant
    RGrant
    Connecticut
    Far be it from me to tell someone else what to do, but if you’ve got a small stove heating a secondary building and holding temps in the 50s overnight- sounds pretty good to me.
    Unless there’s running water in there I’m not certain I’d be backing off the heat at night and just get it going in the morning.
    To each their own of course, but I’ve come down some mornings and the inside temps were in the 50s.
  15. brenndatomu
    Yup, blown in is cheap and easy, and insulation pays you back 24/7/365, forevermore!
  16. gaberelli
    gaberelli
    Wisconsin
    Agreed. It’s not horrible, but I’m out there working by 7, out there until 5 or so, then again with wife after kids are asleep in our 900 sq ft home as the detached space is also our “living room”. Basically, other than sleeping, I’m in the space every waking hour of the day. Makes checking in on the stove throughout the day no problem!
  17. rudysmallfry
    rudysmallfry
    Connecticut
    Do it. When I moved into my 1978 house, there was very little insulation in the attic. Before I added more blown in insulation, I sealed all the air leaks I could find. (air leaks are easy to find since there will be dirty insulation in those spots) I blew in about 18" the entire floor of the attic and it make a huge difference in how well the house holds the heat now. All it cost me was the 10 bags of insulation which came with the free blower rental and a pizza to feed the person sitting in my garage feeding the new bags into the blower. Very messy but fun project.
  18. Eric VW
    Welcome aboard rudysmallfry :salute:
  19. rudysmallfry
    rudysmallfry
    Connecticut
    thanks!
  20. gaberelli
    gaberelli
    Wisconsin
    Well, an overnight burn is 100% possible with this little catalytic stove!!! Packed it to the gills at 10pm last night and it was 67 room temp at 7am! Only downside is she may have gotten a little hot last night.... I checked the wifi thermometer at 2am when I woke up and it read 82 degree room temp. That's cooking!! Might start the fire a little earlier tonight and close the air damper as far as it goes and see if it stays a bit cooler but burns longer.
    T.Jeff Veal, Rich L, JD Guy and 3 others like this.
