Firewood tractors
Discussion in 'Chainsaws and Power Equipment' started by D2082, Mar 1, 2015.
  1. chris
    chris
    SE WI
    certain versions of those are good , couple others are xxxx. Course anything that has to do with Lucas wiring is a royal PIA. I don't remember if those are positive ground- but for a lot of souls in the states that is just bassakwords to them . Course these are the same souls that add all kinds for fancy stuff to their rides and wonder why their batteries keep draining out.
    Horkn and Screwloose like this.
  2. Son of a Woodcutter
    Son of a Woodcutter
    London, Ontario. Canada
    It is yah, lots of people comment on the length of the chimney. The dealer suggested it to get it up and over the building, it was a good idea I think :)
  3. Son of a Woodcutter
    Son of a Woodcutter
    Indeedy it is negative earth, I am pretty used to it now I think, some other vehicles I have had in the past were the same. Great tractor for the money, I will only upgrade when I win the lottery, so I suspect this guy will be with me for a long time!
  4. JWinIndiana
    JWinIndiana
    NorthWest Indiana
    The reason I ask is, our dealer said definitely no to a cap. I always thought a cap a smart idea. I think I am going to raise our chimney one length, in the summer without air conditioning, it is tough to close a window due to smoke smell.
    Screwloose, Horkn and amateur cutter like this.
  5. Son of a Woodcutter
    Son of a Woodcutter
    interesting, what was their reason for no rain cap? It’s looking pretty messy right now, I’ve been burning some crappy stuff, and some freezing rain this am
  6. JWinIndiana
    JWinIndiana
    NorthWest Indiana
    Draw. This is the 2nd generation at this store and selling/knowing the stoves is not their passion like their dad's was.
  7. chris
    chris
    SE WI
    cap on flue, yes, breaks up wind flowing over causing suction, deflects most rain/snow really do not want moisture draining down flue, leads to acid formation when combined with combustion residuals. The more or less standard caps that are a top hat style with a ring of screen are a PIA . Screen clogs up just because of condensation of flue gases. High moisture fuel compounds this. I prefer units with multiple rings stacked no screen, caps keep most birds and rodents out.
  8. Son of a Woodcutter
    Son of a Woodcutter
    I see yes, that makes alot of sense on a house. This OWB has a big blower on it so it doesn't matter. From what I understand, a longer chimney will definitely help draw and yes, I imagine any cap will impede this. Good luck!
  9. Gasifier
    Took a soft Maple down that was damaged and always in the way of plowing anyway.
    There was some frost in the ground but not much. The L5030’s BH90 Backhoe did a nice job!
    The Echo CS680 Turned into firewood.
    Done and gone.
    Forgot to take pictures of the firewood.:emb: Maybe later.
  10. Erik B
    Erik B
    Western Wisconsin
    chris Do you have any pics of the other kind of chimney cap? The one I have had the small holes around it and they would clog up. I cut a bunch of them out and that seems to help but it could be better.
  11. Gasifier
    Always a good feeling seeing stacks! Isn’t it?
    GrJfer, Screwloose, Horkn and 9 others like this.
  12. chris
    chris
    SE WI
    type in selkirk chminey caps, should bring a bunch of pics up
  13. Erik B
    Erik B
    Western Wisconsin
    Thanks:handshake:
  14. Scottiechop
    Scottiechop
    Heading out IMG_20221216_133516.jpg to grab a few logs.... Oliver 550
  15. isaaccarlson
    isaaccarlson
    Colfax, WI
    I have been needing a loader for a while. I picked up a couple of cub 149's a while back and have been looking for a loader for one. Today I picked up a rikon lift out of a school bus. It looks just like a front end loader! A little cutting and welding and it should work perfect. It might have to wait till warm weather gets here though. I'm pretty excited about it. A full size tractor would be too big.
    GrJfer, Screwloose, Horkn and 5 others like this.
  16. Lehman
    Lehman
    Minnesota
    7A2BD987-9EF9-4675-B853-0CD7FB8D8F23.jpeg 218915BE-6DB9-4B98-B9FC-6A31728E4BA4.jpeg
    here’s my 2025r I’ve had for just over a year has 160 hours on it. Very handy little machine that will surprise you on what it does
  17. isaaccarlson
    isaaccarlson
    Colfax, WI
    I know two guys with those, and they are nice, but way out of most folk's price range.
  18. gwoods71
    gwoods71
    The Mitten
    This is mine, I had it split for a stuck clutch this summer, so I took the time to paint the chassis and do the "working resto"
    Didn't get the tinwork done before cold weather arrived.
    1965 Case 430 Draft-o-matic, w/ triple range. I need to get the loader back on, I built the forks to fit the front end loader or the 3 point.
    If anyone else has one let me know, I need a measurement on the 3 point. It doesn't seem to be lifting as high as I remember...but CRS...
  19. morningwood
    morningwood Administrator
    Yanmar YT347. I’ve had it four or five years at this point. It’s been a great machine so far.
    Polaris Ranger XP. Knock on wood, zero issues so far. Was very hesitant on buying a Polaris based off of their track record. Has around 1600 miles on it so far.
    2C2EADCE-330A-4720-BC3D-384F9759B3D5.jpeg 9481A421-A74C-4841-9A2E-B6786AF6522F.jpeg
  20. Lehman
    Lehman
    Minnesota
    I’m sure the yanmar is a fine tractor they used to build all the small John Deere tractors and still make all the engines for them, far as the polaris gos I know tons of people with no issues on the polaris wheelers and rangers. Mostly people that beat on them with no maintenance have issues but it you use within its limits and maintain it I’m sure it will be fine. Use low range when pulling a trailer or slow riding in woods. Even if it seems to go well in high it’s hard on belts and clutches.
    Screwloose, Hinerman, Horkn and 4 others like this.
