Firewood tractors
Discussion in 'Chainsaws and Power Equipment' started by D2082, Mar 1, 2015.
  1. Mastermind
    Mastermind
    Tennessee
    No they really don't do they? lol The machine was made in 1970.......and spent many years in a barn.
    We've got it drained........and have been rinsing with gas, and air pressure. I'm sure it's never gonna be "good enough", but maybe it will be better.
    I'll put a see thru filter between the tank and the pump. That way I can see when it's becoming an issue.
    fuelrod and Boog like this.
  2. Boog
    Boog
    Where my spirit is free
    :yes:
  3. 94BULLITT
    94BULLITT
    Frederick County, VA
    You should not be using compressed air. A spark can come out of your blow nozzle plus you adding oxygen to a place that gas has been in.
  4. Mastermind
    Mastermind
    Tennessee
    My air gun is solid aluminum.
    MasterMech likes this.
  5. 94BULLITT
    94BULLITT
    Read #8
    F.A.Q.
  6. Mastermind
    Mastermind
    Tennessee
    I did.
    Thanks.
    94BULLITT likes this.
  7. hoghunter
    hoghunter
    How would a spark come out of an air hose? Never heard of such a thing.
  8. Mastermind
    Mastermind
    Tennessee
    I get what he's saying. Pressurized gas vapors.....mixed with air, are a very explosive combination.
  9. hoghunter
    hoghunter
    In most cases, rust and sediment particles will get stopped by the fuel filter system but the issue that can be a bugger is when the finger screen in the tank gets stopped up. I've had to blow air backwards through the fuel line to clear these types of clogs. (algae can block the screen too or a mix of algae and rust particles). I've had success cleaning these tanks of algae and rust using the aforementioned technique of agitating the fuel and then sucking it out.
  10. MasterMech
    I'm no chemist but maybe there is a way to dissolve the rust without attacking the steel of the tank?
    Boog and Mastermind like this.
  11. Boog
    Boog
    Naval Jelly!
  12. ja_cain
    ja_cain
    Chesterfield, VA
    Disolves in strong acids (sulfuric and hydrochloric) and chelating agents like EDTA or oxalic acid.
  13. 94BULLITT
    94BULLITT
    I've only seen it happen a couple of times. I'm not sure why it happened. I think both times the compressor was running, I'm not sure if that had anything to do with it.
    Mastermind likes this.
  14. 94BULLITT
    94BULLITT
    Yep, I wasn't trying to be the safety police but I didn't want anyone to get hurt.
  15. MasterMech
    Could be static build up in the hose, especially if it's PVC. Or from accidental contact of a steel blow gun to a steel tank.
  16. Mag Craft
    Mag Craft
    South East Wyoming
    Well I got my tractor repaired. I had to replace the seals where the brake shaft goes thru the bottom of the rear diff case.
    I had to drop the frame of the loader about 6 inches in order to get the shaft out and replace the seals. Sure am glad I got it done and everything is working great. It is a 72 Ford 2000 3cylinder gas. Everything works great on this baby.
  17. Gasifier
    Good work Mag Craft! Way to stick with it. Nice tractor!
    Mag Craft likes this.
  18. Mag Craft
    Mag Craft
    South East Wyoming
    Hey thanks Gasifier. It was a little more involved than I originally thought. But done and no more leaks.
  19. hoghunter
    hoghunter
    I did that repair to a Ford 4000. Got the shaft seals replaced and about two years later got the rest of the tractor put back together. One thing led to another and then to another... Just got a power steering kit in the mail today for that same tractor.
  20. 94BULLITT
    94BULLITT
    I think it is static electricity or something else. I forget what I was blowing off but I did not bump it with the blow nozzle plus it has a rubber tip.
