Firewood longevity.
Discussion in 'The Wood Pile' started by dylantdyck, Nov 9, 2018.
  1. jrider
    jrider
    I haven't read this whole thread so I don't know if this has been said yet or not but from my experience, poplar rots faster than many other types and if you let it sit much more than 8-12 months, you better have a place to get rid of a lot of bark because most of it will easily fall off.
    bear 1998, mat60, Midwinter and 2 others like this.
  2. dylantdyck
    dylantdyck
    CA
    So today i cut up a big oak tree that has been standing dead at my place for over 6 years and thought it would completely rotten but its still rock hard and so far everywhere i have tested is around 18% moisture
    Sent from my SM-G950W using Tapatalk
  3. WeldrDave
    Did you split a piece and test "in the split"? It's most likely much higher.
  4. dylantdyck
    dylantdyck
    CA
    I haven't yet but what is the difference between a split piece and a freshly cut piece?
    mat60, bear 1998 and WeldrDave like this.
  5. WeldrDave
    If your testing on the end it'll be a bit dryer. The split will hold more moisture. If you test "right after" you cut then your reading is spot on!
    yooperdave, mat60, Chaz and 2 others like this.
  6. dylantdyck
    dylantdyck
    CA
    Perfect! I burnt 2 peices last night and now i don't want poplar anymore
    Rope, T.Jeff Veal, yooperdave and 3 others like this.
  7. papadave
    Do both, then you'll know.
  8. Ashwatcher
    Ashwatcher
    West By God Viginia
    Well yes, they are...and we can grow some nice ones also but at the same time, Milo Hansen owns the world record typical from there and I’ve always been attracted that in the bush there, you may hunt all week or so and see relatively few deer...but the one you do could be truly exceptional...just on the bucket list, thats all...again welcome and you’ve found a great place to hang out, I promise
    bear 1998, T.Jeff Veal and mat60 like this.
  9. dylantdyck
    dylantdyck
    CA
    So i split a bunch of that oak and the i got some readings of 24% moisture think it could be ready by january if i have 2 fans and a dehumidifier going on them?
    BigPapi, Rope, bear 1998 and 2 others like this.
  10. Rope
    Rope
    Alaska
    Not sure if your popple is like what my area of Alaska is. We have a stringy later just under the bark. If that layer remains wet it rot quickly. I have cut popple that was killed in the ‘97 burn that has no bark, is off the ground and is solid as if it were still alive. And seen logs that were 1-2 years old with bark on rot.
    Midwinter, bear 1998, Maina and 4 others like this.
  11. Timberdog
    Timberdog
    Az
    The Sierra Nevada mountains in California do get mighty cold....that’s where the the Donner Party story took place.
    Thor, bear 1998, Chaz and 1 other person like this.
  12. yooperdave
    Desperate times!
    Thor, bear 1998 and Chaz like this.
  13. Chaz
    Chaz
    Southwestern NY
    Well sure, if ya wanna bring up that.
    :emb:
    :whistle:
    If I recall correctly, I think one side of lake Tahoe is in Cal. also.
    I got caught generalizing I guess.
    :picard:
    Suburban wood snob and bear 1998 like this.
  14. Timberdog
    Timberdog
    Az
    It is:salute:
  15. Timberdog
    Timberdog
    Az
    Now just wait for the cannibalism jokes....
    yooperdave and Chaz like this.
  16. Midwinter
  17. Chaz
    Chaz
    Southwestern NY
    And there I was, expecting a meme with a little "meat on the bone".
  18. bear 1998
    bear 1998
    S.C.Pa
    Timberdog, Midwinter and Chaz like this.
  19. Midwinter
    Marvin, bear 1998 and Chaz like this.
  20. Timberdog
    Timberdog
    Az
    Chaz likes this.
