firewood carts for Atv
Discussion in 'The Wood Pile' started by Davek134, Jan 5, 2017.
  1. Davek134
    Davek134
    Nj
    Looking for recomendation on carts for moviv firewood with atv
    Woodsnwoods, HDRock, Chvymn99 and 4 others like this.
  2. Stinny
    HDRock, Eric VW, Horkn and 4 others like this.
  3. Backwoods Savage
    The first pictures are of a dray I threw together using some junk stuff that was laying around but I did have to buy a few bolts. It works great if you want to haul some logs.
    The atv trailer I bought at Cabelas when it was on sale. I see they have one now for $299. Regular price is $399. The mesh is a bit light but it works fine. I put a board in the bottom of the trailer and that works best. You can haul a big load with this and if you think you need it, you can add a tandem but I see no need for one. The wide tires go through mud and snow nicely. The trailer bed is a tilt bed also. Another nice thing is that the trailer is low so loading big rounds is not so much of a problem.
    Ashwatcher, HDRock, Eric VW and 12 others like this.
  4. bogydave
    Dennis has a great at set up
    Get something similar !
  5. Fanatical1
    Fanatical1
  6. Horkn
  7. Ashwatcher
    Ashwatcher
    West By God Viginia
    This is mine-Polar HD 1500 w floating tandem axle-lil pricey though it has come down some-much cheaper at Lowes over Home Depot for some reason when I purchased-2 loads of rounds in it fills a full size 1/2 ton p/u, 6' bed
    Oldman47, HDRock, Eric VW and 8 others like this.
  8. swags
    swags Moderator
    I bought a little motorcycle trailer for $100 on craigslist and added a deck and small sides. Works pretty well for hauling splits up to the house from the woodshed. And it is big enough that I can fit the wheeler in it if I want to haul the fourwheeler somewhere to cut. I can then just hook the trialer to the fourwheeler and go.
    HDRock, Eric VW, Horkn and 2 others like this.
  9. swags
    swags Moderator
    The only thing I m going to change is the sides, they should be a little higher to be able to haul more splits when moving wood up to the house.
    HDRock, Eric VW, Horkn and 5 others like this.
  10. Farmboy707
    Farmboy707
    Southern Ontario
    Love that trailer looked it up here in Canada $600 :headbang::hair:
    HDRock, Horkn and Backwoods Savage like this.
  11. Deer Meadow Farm
    Deer Meadow Farm
    Warren, MA
  12. TurboDiesel
    HDRock, Eric VW, Horkn and 1 other person like this.
  13. TurboDiesel
  14. 74buc
    74buc
    NE WI
    You could upgrade! LOL
  15. JIMBETHYNAME
    JIMBETHYNAME
    Poughkeepsie ny
    Horkn likes this.
  16. lukem
    If I had to do it over again I would have skipped the poly cart and bought the 4'x4' trailer from harbor freight and added wood sides and floor to it.
  17. Horkn
    This is really a great deal.
    Yeah, you have to add a floor and some sides, but that's pretty easy, and you can use scraps.
    Backwoods Savage, HDRock and Eric VW like this.
  18. Sawdog
    Sawdog
    That is a really good deal ^^^ but I think single axles wood trailers with pizza cutter tires isn't the best way to go. I think id rather have double axles and an ATV type tire - much better under the weight of wet wood in the woods and mud.
  19. HDRock
    I have one of those sitting out here haven't used in years, has larger diameter tires I put on, used it as a motorcycle trailer.
    Will sell cheap :)
  20. Horkn
    True, wider tires will not rut it up so much, but you can put those on later. Wider snowmobile trailer tires could be fitted to get more flotation.
    Although, if it's frozen or dry there's no issues.
    Hmm, how far away? For someone really local, that would be a deal. For me it'd be $100 in gas round trip.
