Firestarter, say goodbye to butane Grill lighters
Discussion in 'Modern EPA Stoves and Fireplaces' started by HDRock, Oct 5, 2017.
  1. JWinIndiana
    JWinIndiana
    NorthWest Indiana
    Exactly what happens to me. I don't smoke so when I do need it, it is out of fluid. A very safe lighter to carry in a welding shop, but it requires maintenance and I quit carrying it. Carry a Bic lighter in my work coats around the farm.
    Horkn and HDRock like this.
  2. bushpilot
    bushpilot
    Eastern Washington
    I am likely to use the torch when my lighter runs out. I also use my torch for lighting my beehive smoker.
  3. HDRock
    How?
    I was wondering if there is a way to fill these with a 20 lb tank
    p61 western and Horkn like this.
  4. Warner
    Warner
    There is a fitting that you screw into a 20 pounder then screw the small tank on it's sketchy at best. The small green tanks don't seal back up sometimes.
    p61 western, Horkn and HDRock like this.
  5. FatBoy85
    FatBoy85
    Washington State
    I used a few for the novelty.
    Its a nice thing to have but if anything it all requires just a little tlc and watching over it. Id fill it up every 3-5 days.
    Horkn likes this.
  6. FatBoy85
    FatBoy85
    Washington State
    Sounds a bit of a hit or miss.
    Horkn likes this.
  7. Highbeam
    Highbeam
    No no no, the fittings are made by big companies like Mr heater. They work very well. Easily refill the 1# green cans from 20# bulk containers.
    p61 western, HDRock and Horkn like this.
  8. Warner
    Warner
    I don't think the issue is refilling. In my experience the green tanks dont always reseal. Perhaps I was doing something wrong.
    Horkn likes this.
  9. Mwalsh9152
    Mwalsh9152
    Pelham NH
    I'll have to investigate refilling the little tanks. I don't have a 20lb tank, my grill is plumbed into my 500 gallon tank, and there is a quick connect right behind the grill. Could make it super easy if the tanks will reseal!
    Horkn likes this.
  10. Highbeam
    Highbeam
    You must be doing it wrong. Don't mess with the little Schrader looking valve. All you do is thread the little tank to the bulk tank using the same threads/valve that you use every time you attach the green bottle to anything. The normal threads are meant to be used repeatedly and the inner valve is as well.
    You freeze the empty green tank and weigh in 16 oz of lpg from an inverted bulk tank. It goes into the green tank where propane normally goes out.
    Then, since you leave the torch head installed, this valve on the green tank stays open. Just don't underestimate the energy contained in 1# of lpg.
  11. HDRock
    Looks pretty simple to refill the little tanks , a 10 dollar adapter , then you have to turn donor tank , like a 20lb, upside down to get the liquid propane into the small tank
    p61 western and Highbeam like this.
  12. Rumpy
    Rumpy
    Pioneer Valley, MA
    That’s the torch I use for soldering at work, it’s great unless you need a bigger flame.
    For the woodstove in the shop, we have a green coleman canister with a regular torch and a flint striker. It’s the only thing that won’t get stolen! If there was a Burnsosmatic with a piezo ignition, it would disappear in a week.
    This reminds me of boyscouts when I got ahold of a Coleman canister, and spent a half an hour trying to jam a twig into the safety valve. When I finally got it, propane shot at my face. Boy was the scoutmaster mad!
    OhioStihl and HDRock like this.
  13. CoreyB
    CoreyB
    South east iowa
    Will this work?
    p61 western and HDRock like this.
  14. Mwalsh9152
    Mwalsh9152
    Pelham NH
    p61 western, HDRock and CoreyB like this.
  15. HDRock
    That will work just fine , only thing is those tall tanks are not as stable standing up as the fat little green ones .
    I had my tall tank setting in a coffee can so it wouldn't get knocked over
    p61 western and CoreyB like this.
  16. CoreyB
    CoreyB
    South east iowa
    Ya just the ignition head was the same cost as with a bottle. Figured I could get a fat bottle later when this one is used up. As long as the threads are the same.
  17. HDRock
    No biggie , threads are all the same.
    You will be much happier than dealing the grill lighters.
    Burn on bro :thumbs:
  18. Eric VW
    MAPP.....
    Only b/c I have it from the old handyman days.
    :yes:
  19. Highbeam
    Highbeam
    I bought the bigger MAPP gas torch that came with a yellow bottle of map gas. Works great for starting fires. When that MAPP gas ran out I just grabbed the closest little green LPG can and threaded it right on. Works great.
    I like how it says "self lighting" as though the torch will randomly light itself. You need to actually light it by pressing the trigger.
    Eric VW, CoreyB and HDRock like this.
  20. HDRock
    It's magic:rofl: :lol:
    CoreyB and p61 western like this.
