Finding the right chain saw
Discussion in 'Chainsaws and Power Equipment' started by Kmart0104, Nov 23, 2014.
  1. DexterDay
    DexterDay Administrator
    Northeast Oh
    I believe one is sold already, just want to clean them up and run through them. But a member has already PM'd me and expressed interest in one of them. :)
    foragefarmer, Chvymn99 and mdavlee like this.
  2. Cut4fun
    Cut4fun
    OHIO Redneck
    I've seen new echo 590 going in 300ish range.
    mdavlee and Chvymn99 like this.
  3. bogydave
    FWIW
    I've found over time, look at the top of the line & the bottom of the line
    Get somewhere near the middle & you are going to be OK
  4. Kmart0104
    Kmart0104
    Ri
    Well, I stopped at my local stihl dealer today. I am leaning towards ms250 or 271.
    I saw the 311 and I that's a lot bigger than I feel I need. That's a big saw to be to be using all day.
    Talked to my friend today and his dad is giving us his husqvarna 371xp.
    So I am leaning towards a smaller sized saw. Am I right here?
  5. MasterMech
    There is no difference in weight between the 271 and the 291. If you are considering the 271, I'd pick the 291 if you can swing the extra cash.
    That said, if you are looking at $450 saws, you could snag a Husqvarna 545 to go with that 371 and be in wood cutting nirvana.
    Oliver1655 and mdavlee like this.
  6. bogydave
    Good choice :)
  7. bigbarf48
    bigbarf48
    Stone Mountain, GA
    291 or 545 would suit you well. If you'll always have access to the 371, the 545 would compliment it well like MM said. If not, the 291 may be more versatile as a single saw
    If 400 is really tops of your budget, the 271 would serve you well. I'd recommend looking at the echo cs590 though as well. Those are 399 and are a lot of saw for the price
  8. bogydave
    Lighter weight,
    545 is 10.8 lbs
    vs
    ms271 is 12.3 lbs
    Oliver1655, Chvymn99 and bigbarf48 like this.
  9. Kmart0104
    Kmart0104
    Ri
    The 271 with a 16" bar is going for 399.
    The 291 is foingg for 459.
    Is the husqvarna 545 comparable to the 291?
    Does an extra 5 cc's make a big difference?
  10. bigbarf48
    bigbarf48
    Stone Mountain, GA
    Any of those saws will pull a 16" bar just fine IMO
    Oliver1655 likes this.
  11. Kmart0104
    Kmart0104
    Ri
    Thank you for all the great jnfo and advice. Should I be leaning towards using a "16 or should I be looking to keep with a "18? Or personal preference ?
    bigbarf48 likes this.
  12. MasterMech
    If you have a 371 coming already, then there is no reason to try to make a 50cc saw pull anything bigger than a 16" bar. The 545 is much lighter than the 291 as Dave pointed out, not quite as powerful but still plenty for a 16". Also it's built in such a way that it's easier to service and or modify should you ever choose to go down that path. The 545 has one huge advantage over the 291 and that's called AutoTune. The saw adjusts itself to your cutting conditions automatically so you are going to get the best performance it can give 100% of the time.
  13. bogydave
    Good question
    I asked that about the ms261 vs the ms362 at the Stihl shop a few days ago.
    Guys answer was " It all depends on how long you want to hold the saw in the cut"
    I took it to mean the more power , the faster cutting speed.
    291 (55cc, 3.76 bhp) ($459) is 12.1 lbs vs 251 (50cc, 3.49 bhp) ($409) at 12.3 lbs
    291 has a better power to weight ratio.
    345 is 10.8 lbs, 3.35 bhp ($500)
    345 not gonna perform like the ms291, but it is smaller & lighter weight
    Now which bar size?
    16" either saw is good
    18 or 20" the 291 will outshine the other 2
    I'd go with the ms291 with an 18" , full chisel RS3.
    Get an extra chain or 2 thrown in :)
  14. Kmart0104
    Kmart0104
    Ri
    Can you usually try and haggle with a dealer? Price or chains?
  15. MasterMech
    Sometimes, sometimes no. Don't expect any miracles tho. There is not a lot of markup in OPE whole goods.
  16. GRIZ
    GRIZ
    Stihl is the way to go:yes: ms362cm/441cm/my favorite 461[​IMG] Pick the one u want and add:banana:= 1 day :cheers: 1 day=:saw: Welcome FHC buddy let me know what u do:loco: :crazy:
    Chvymn99 likes this.
  17. GRIZ
    GRIZ
  18. GRIZ
    GRIZ
    :banana::banana::banana::banana::banana:
  19. rburg
    rburg
    TN
    An earlier poster mentioned a used Husky 55 that he had for sale. This size Husky would be a good saw to match up with the 371. Buying used off these forums is usually better than dealing with craigslist or ebay. I have the Jonsered version of the 545 that has been recommend by some. This model will work fine in the 16-18" size wood I like to cut for firewood. Good luck in your choice.
  20. bogydave
    Like said,
    Markup is controlled by the manufacturer , dealers can
    throw in a chain or some oil.
    Get the chain type you want on the saw
    Full chisel chain is what most here like to use.
    Saw shop I deal with want your business,
    On a new saw purchase, throwing in an extra chain is normal.
    They know you'll need more stuff,
    mixing & bar oil , sharpening chain & new chains, files etc....
    A $20 chain makes the buyer feel better, probably $10 dealer cost.
    Always ask, some do some don't
    shop around
    GRIZ and bigbarf48 like this.
