Finally pulled the trigger...
Discussion in 'Modern EPA Stoves and Fireplaces' started by Barcroftb, May 4, 2021.
  1. Backwoods Savage
    And it was raining when you put it in.
    Eric VW, brenndatomu and Barcroftb like this.
  2. Backwoods Savage
    fwiw, when I am caught with having to put wood in stove (need to be gone for a long time and it is cold outside) but there is still a good fire I most times simply put the wood in, close up and engage cat right away. No problem so long as you have dry wood.
    Amazing it was down to 75 when I got up, but that is being taken care of.
  3. Canadian border VT
    I was witness it was in NH
  4. Barcroftb
    Barcroftb
    The Mitten
    oddly enough the outside temp has dropped 2 degrees since then.
  5. Backwoods Savage
    Dropped here too. it is -3.
    Eric VW, Barcroftb and brenndatomu like this.
  6. Eckie
    Eckie
    Yall are making me cold just reading about your outside temps....
  7. Backwoods Savage
    Just looked at ours and it reads -10.
  8. Barcroftb
    Barcroftb
    The Mitten
    So potentially new problem :headbang:
    Noticed what I thought was an excessive amount of smoke last night. So I removed cat this morning and cleaned it. Still having lots of smoke this morning after cleaning cat. For cleaning the cat all I did was blow it out with the air compressor. 59CCE776-70A2-4CD1-B6B3-7CDCDEDF4118.jpeg
    Running air at 1 notch above 1/4 open.
    Maybe 30 minutes after reload. Heard ticks and pinging that makes me think cat is lit.
    what say you fellers?
  9. RGrant
    RGrant
    Connecticut
    That's a bright white smoke on my screen- I'm pretty sure that's condensation coming out of the stove off the wood. I get that sometimes too, but not for a whole heck of a lot of time.
    I'd be tempted to let it run wide open a little bit longer before running the cat and cutting the air back. Maybe another 10 minutes or so, then engage the bypass and adjust the air flow to where you want it.
    That would be my approach, we'll see what some of the other guys thing is going on.
  10. Barcroftb
    Barcroftb
    The Mitten
    It does look like steam to me too, but I wasn’t completely sure. This white ash I’m burning isn’t the driest at an average of 18%
  11. brenndatomu
    Agreed...getting the same cloud from the gas boiler here at work today...
  12. oldspark
    oldspark
    NW Iowa
    Yep its water vapor, get it here whens it's really cold, first time my new epa stove did that I thought i had a epa smoke dragon.
  13. oldspark
    oldspark
    NW Iowa
    Barcroftb, what was the temp of the stove when you cleaned the cat?
  14. oldspark
    oldspark
    NW Iowa
    Is 18 percent a little high for a cat stove?
    Eric VW, brenndatomu and TurboDiesel like this.
  15. oldspark
    oldspark
    NW Iowa
    I'm going through a lot of wood with this below zero south wind crap.
  16. TurboDiesel
    The leg or the blanket?
  17. TurboDiesel
    I do that occasionally if I'm going to be out for several hours. Hot loading will build up a lot of extra coals though
  18. TurboDiesel
    18% is fine
  19. TurboDiesel
    Oh yeah. You'll be high-stepping for no reason. Lol
    (If everything looks closer, you feel like you're walking uphill)
  20. oldspark
    oldspark
    NW Iowa
    I am trying to use less dense wood for hot reloads, just put some elm and ash in stove, hope it helps when the excessive coling.
    TurboDiesel and brenndatomu like this.
