Finally getting the windows for the stove room
Discussion in 'The DIY Room' started by papadave, Nov 5, 2015.
  1. Eric VW
    Not familiar with the NC30... Can u describe the "other two intakes?"
    wildwest likes this.
  2. Eric VW
    BTW papadave, glad to hear things are tightening up in your house:yes:
    No side comments, no off color talk, just simply happy for ya!
    I must not be feeling right.....:rofl: :lol:
    schlot, papadave and Stinny like this.
  3. Stinny
    o_O....... :D
    Eric VW likes this.
  4. papadave
    Hernia messin' with ya'... some kinda' fevah? :)
    Primary (controllable), secondary (not controllable), and the "doghouse", which comes in two holes. One in each of the front corners on the underside of the stove body, behind the front legs (I installed the legs).
    Eric VW and Stinny like this.
  5. papadave
    Supposed to get down to 8 and 4 tonight and tomorrow night, so it'll be a nice test to see how well this has affected my ability to heat the house and the house to maintain that heat.
    If recent results are any indication, things should be better. I only put in 7 Maple splits before bed last night (normal would have been 10-12) and woke to the house at 68 and lots of coals in the stove. Three splits of Maple to take out the slight chilled feeling and we're up to 73. OAT was about 24 or so, and in order to hit our high of 21, the temp needed to drop. We're almost there.
    This has been our new normal since the windows/door install.:thumbs:
    I knew that room was leaky, but wow. Normally, the house would be down around 66-67 in the AM, and it would take longer to bring the temp back up. The kitchen would normally have been 3-4 degrees cooler most of the time too. Temp difference now is usually only a single degree.
    Temps in the low to mid teens will be a better test.
    Stinny, Eric VW, Brad38 and 3 others like this.
  6. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    Sounds like a nice improvement. I've used incense stick smoke carefully around the house locating leaks. I have a laser thermometer now.
    Eric VW and papadave like this.
  7. savemoney
    Nice, I am happy for you. Something good! Not easy getting into a situation and then having to turn it all around. Hope you are safe and warm.
    Larry
    Eric VW, papadave and Brad38 like this.
  8. papadave
    Did some shopping today and grabbed a single sheet of 1/4" drywall as a test.
    I've got to do a little shimming of a couple studs next to one of the windows, as they've got a bow that needs to be filled.
    I have a plan, but expect it to change at any given moment.:thumbs:
    Grabbed a pack of T&G pine, but forgot wife wanted beadboard wainscot. :picard:
    I refuse to use the crappy fiberboard stuff, so any suggestions for an actual Pine beadboard source is welcome. Still not sure how I want to do the window/door trim. Might go real simple for a while.
    I have a bundle of FG batts to finish the insulation, so there's that too.
    Thanks for that Larry. This has been .......interesting.:hair:
    Definitely safe and warm.:)
    Stinny, Eric VW and milleo like this.
  9. schlot
    schlot
    NW Iowa
    Great to read about all the improvements in tightening up the house!
  10. Eric VW
    Oh living room remodeler guru Grizzly Adam, whereyat?:D
    papadave likes this.
  11. Eric VW
    All in all, gooder news report, papadave :thumbs:
    Bet you're getting stoked on nearly having put this behind you:yes:
  12. Grizzly Adam
    Grizzly Adam Guest
    Ours is a 3/8" pine plyboard from menards.
    papadave and Eric VW like this.
  13. Eric VW
    That's some "Johnny on the spot" response time, right there yes sir:thumbs::yes:
  14. Grizzly Adam
    Grizzly Adam Guest
    I get emails for tags.
  15. papadave
    Dang, that's right.
    I already forgot about your living room wainscoting. :headbang:
    What a great solution.
    I'll go check it out.
    Thanks Eric and Grizz.
    Eric VW , I'm getting closer every day, but it'll take me a little while to finish. I like to think I'm on the downhill slide. Weeeeee:)
    My wife thought it important to put some stuff back in the room......:headbang:
    Eric VW and savemoney like this.
  16. Eric VW
    Don't forget to use that new massive hatchet to trim off any shims:thumbs::rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol:
  17. Grizzly Adam
    Grizzly Adam Guest
    Check em over for large spots of wood putting. Accept only the best!
  18. papadave
    I didn't see any when I was there, but according to the website, HD has 5/16" pine T&G beaded planks, as well as the v-groove planks I got.
    However, I didn't see those.
    I have the aisle and bay location, so I'll be on a mission to check those out sometime soon. I'll check out any ply beadboard too.
    This will be finished with a semi-transparent stain.......maybe. Wife says the wainscot has to be white. White, it shall be.
    Eric VW likes this.
  19. eatonpcat
    Story of my DIY life...Back to the store for plan B!!
  20. papadave
    Well, I'm waaay beyond plan b.:rofl: :lol: There may well be an alien alphabet in use at this point.:)
    Loaded up with Oak last night before bed about 11, and when I got up at 6:45, OAT was 15, with 66 in here. Tons of coals.
    Not as good as I'd hoped for, but with 4 Maple splits, we were back up to 70 in about 1/2 hour.
    So heat loss is still an issue (this is no surprise.....back bedroom is the main culprit, I think, as well as the attic), but recovery time is reduced quite a bit.
    Stinny, eatonpcat, bogieb and 4 others like this.
