Finally bought a riding mower..
Discussion in 'Chainsaws and Power Equipment' started by raybonz, May 31, 2014.
  1. MasterMech
    That's a pretty serious hill! She runs chains?
  2. jeff_t
    jeff_t
    SE MI
    It's not a long climb, but it is pretty steep. I don't think I would be very comfortable going up on my zero turn. No chains necessary, though.
    I cut three good size ash trees down there a few years ago. I couldn't heap my trailer as I normally do, because traction was an issue with my 4x4 atv. The trailer is pretty well balanced, and adds little to no tongue weight.
    clemsonfor likes this.
  3. MasterMech
    I would go up just about anything on a ZTR. Down/sideways is a different story......
    Chvymn99 likes this.
  4. jeff_t
    jeff_t
    SE MI
    I don't like going up. The engine sits behind the drives, I sit just barely forward, and it just doesn't feel that comfortable. The first time I let one of my kids drive it, she just jammed the handles up and brought the front tires off the ground.
    I have no problems on the ditchbanks, though.
  5. nate
    nate Banned
    Palmer, AK
    [​IMG] Used to mow the tops of underground ammo buildings with John Deere Z TracsZTR. I'd guess a 40* angle. Was steep enough to screw with the seat switch.
    Real fun trying to deal with a mower stalled out. In order to realease the brake the arms has to be in neutral. So pop the brake, try to grab the arms in time before rolling back and not wheelie.
    Going down you just let it slide and try to steer best as you could
    Couple times only thing that saved me from going over was the back of the machine hitting the ground... So near vertical.
    raybonz and jeff_t like this.
  6. MasterMech
    The machines I have run will climb like the space shuttle. But will slide straight down a wet or sufficiently steep slope. "Crabbing" them sideways was doable unless it was real wet out and then you just slid down the hill uncontrolled. :bug: Yeah, they do wheelies if you hit the handles hard enough. :whistle:
  7. colin.p
    colin.p
    Ottawa Canada
    Interesting, Ariens made by Husqvarna. I have a Poulan riding mower and other than the color (and lack of beer kozy) it is it's exact sister.
    I had to tie a rope on the plastic cover where the grass shoots out so I could lift it up out of the way as it is forever knocking my wife's flower pots over. Of course it can't possibly be because I can't drive.
    raybonz and clemsonfor like this.
  8. lukem
    We used to mow a park that had some monster hills in it. Up was no problem...down could be tricky if the grass was really wet or really dry/dead. We'd try to side-hill it every once in a while to break up some of the perma-stripe if the conditions were just right. If you could keep the nose pointed uphill it was all good, but as soon and the nose pointed downhill it was all over.
    I don't have any hills on my property now, but when I mow my in-laws I put the hitch ball on there for a wheelie bar.
    jeff_t, clemsonfor and MasterMech like this.
  9. raybonz
    raybonz Moderator
    Carver, Mass.
    Pretty sure Husqvarna makes Poulan riding mowers too.. I like that I can mow in reverse too.. Good feature!
