Finally a Harman
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Well Seasoned, Apr 17, 2021.
  1. bogieb
    Wow, don't usually see a 4" air intake. Thanks for the info!
    ivanhoe, Horkn, eatonpcat and 3 others like this.
  2. Well Seasoned
    That's usually for anything over 10 feet in pipe the outside air jumps up to 4" rather than 3"
    ivanhoe, Horkn, eatonpcat and 4 others like this.
  3. Lousyweather
    Lousyweather
    the outside air connection is 3"....not 4
  4. Well Seasoned
    Correct, only the venting opening will do either.
    Have you found that the 35i air setting should be turned down a bit more? I adjusted the draft according to the manual but it seems still high.
    ivanhoe, Horkn, eatonpcat and 5 others like this.
  5. ttdberg
    ttdberg Pellet Pig
    CT
    Looks great Well Seasoned, very nice setup! May that stove serve you well for a long time to come!
    :thumbs:
    ivanhoe, schoondog, Horkn and 7 others like this.
  6. Canadian border VT
    Yeah we’re he lives frost til June 15
    ivanhoe, MikeInMa, Horkn and 6 others like this.
  7. Lousyweather
    Lousyweather
    sometimes it cant be turned down enough.....I think there's about a -25v adjustment you can make- they are usually maxxed out from the factory, but on many occasions, turning down all the way isn't even adequate to drag the draft down far enough
  8. Well Seasoned
    Thanks!
  9. stuckinthemuck
    stuckinthemuck
    Can I play this game?
  10. wildwest
  11. Well Seasoned
  12. eatonpcat
    That is beautiful Well Seasoned, if you can't find the best (Enviro cast M55)...might as well settle for a hormoan!! Lol
  13. stuckinthemuck
    stuckinthemuck
    Yes Sir. Just picked it up yesterday. Guy said it was 5 years old and had about 5 tons through it as it was only used part time.
    ivanhoe, wildwest, bogieb and 5 others like this.
  14. Well Seasoned
    That's excellent! One of my favorite stoves! Enjoy!
    ivanhoe, wildwest, bogieb and 4 others like this.
  15. stuckinthemuck
    stuckinthemuck
    Thanks!!! Gonna be a part time burner in my unfinished basement. Don’t have a zone down there for FHW, wouldn’t want to burn oil to heat it anyway and would be ridiculous to run a chimney system for a wood burner up 2.5 stories just for part time heating... probably won’t be able to install it until this fall...
    ivanhoe, wildwest, bogieb and 6 others like this.
  16. ttdberg
    ttdberg Pellet Pig
    CT
    ivanhoe, wildwest, imacman and 3 others like this.
  17. bogieb
    Barely even broken in
    That will help tremendously. My house is the same, FHW only run on the main floor. Already have a chimney for the boiler and DHW, don't want (or have room for) another chimney. Pellet stove fit the bill perfectly. Heated floors in the winter, regardless if any excess heat gets upstairs, will help with the fuel bill for heating the main floor.
  18. Lousyweather
    Lousyweather
    easy to find Enviro M55....look in a scrapyard near you
    ivanhoe, eatonpcat, bogieb and 4 others like this.
  19. imacman
    imacman
    Denver, NC
  20. Tullytown
    Tullytown
    North of Phila Eagles.
    yep..
    this another setup but with OAK on the bottom...
