Filled it up tonight
Discussion in 'Modern EPA Stoves and Fireplaces' started by Backwoods Savage, Jan 21, 2014.
  1. Todd
    Todd
    NW WIS
    Yeah, I don't know how it happens sometimes but it seems like all of a sudden the flame goes away and the cat takes over gorging itself and gets really hot. Sometimes it will get hot enough to ignite the flames back but not always. The stove can probably handle it but it can get scary.
  2. Backwoods Savage
    Ah, but we won't forget that start in Fairbanks. Could this be another one? I hope not.
  3. Backwoods Savage
    jdonna, in the colder temperatures, like below 10 degrees daytime, we will then run a bit more draft. This afternoon we've had it a 1.5. Right now it is full open because we are almost down to the all coaling stage. This will keep the coals from building too high. At night, even below zero we'll keep the draft at .75 and it seems to work nicely.
  4. Backwoods Savage
    Except that Dennis does not open the firebox door. We just give it a bit more draft.
  5. Backwoods Savage
    No science about it Steve. If you open the draft more, the stove top will not be as high but the sides and front will be higher. To get the most heat from the beast, keep some flame in it. You are right that it is sensitive with the draft setting. We have had a couple back puffs but it was our own fault and we also have a very short chimney.
    Oldhippie likes this.
  6. Backwoods Savage
    As the cat gets older, it seems to take just a bit longer to fire off. We tend to set the draft at 1.5 or 2 for the first setting as we turn it down. That does not stay there long though and it is interesting that as soon as I get it down to 1 or to .75, that is when the cat kicks in. But if I don't turn it down, then it takes longer for the cat to ignite. Strange, but it works.
  7. jdonna
    jdonna
    MN
    If I fill the box with that bone dry elm, I generally do not have a problem with coals. The red oak and hackberry can leave a bit of coals in the morning. Upside of a tall stack is you can crank the air open and chew down coals really fast.
    I stuffed the stove up with 2-4 in rounds/branch wood this morning, that was kind of a fun experiment. Got some nice heat out of it. We left the draft a touch under 1 and it was really ripping. I guess the question in mind was, if you only had dry tops of wood could the stove still heat the house? Answer was yes.
    Oldhippie and fox9988 like this.
  8. Backwoods Savage
    Most definitely you can jdonna.
    Looks like you are in another deep freeze up there.
  9. milleo
    milleo
    Maine
    How short is your chimney Dennis?
  10. ZeeB
    ZeeB
    My beta unit just got installed last week. Unfortunately I am traveling so the oil burner is keeping my pipes from freezing at the moment. Here is a picture of the newer air control markings.
    milleo, BrianK, Flamestead and 2 others like this.
  11. Oldhippie
    Oldhippie
    Ashby Ma
  12. Goose
    Goose
    Fairfield County, CT
    I knew it was something like that. Fortunately for me it worked.
  13. Backwoods Savage
    10'
    milleo likes this.
