Filled and top covered
Discussion in 'The Wood Pile' started by Stinny, Oct 9, 2014.
  1. Paul bunion
    Paul bunion
    I got one of those tarps this spring. I've got some plywood in spots under it too. It seems to be holding up really well. Definitely a different product than traditional blue or whatever the color of the day is type of tarp.
    Horkn, HDRock, Stinny and 2 others like this.
  2. Stinny
    Lemmee know how you like em HD.
    Horkn and HDRock like this.
  3. Chvymn99
    Ok... dredging up the old sewage...:D.... So how are these tarps holding up so far? :cool: I need to get something before we get to the wet fall season...
    Flatlander Pete, Horkn and Stinny like this.
  4. Stinny
    It's good stuff Chvy. The UV protection is big. As far as tough, the one I put up at the end of the patio behind the garage, get's the chit beat out of it every time the wind howls from the NW. It's across a 7'x8' opening. Even when it's as brittle as a vinyl type material can get at below zero... still hanging in there after 3 summers, 2 winters. The 2 I have over the racks are fine too. I know what the green and blue tarps would look like by now... they'd be coming apart by now and they'd be faded from the sun.
  5. Erik B
    Erik B
    Western Wisconsin
    Where are you getting those 14 mil tarps from?
    Horkn, Stinny and HDRock like this.
  6. HDRock
    I have only had mine since last fall but they are the best tarps I ever had, they are not just heavy duty but are Super Duty, well worth a little more money for sure
  7. Erik B
    Erik B
    Western Wisconsin
    I found the source for those tarps. Didn't look close enough the first time.
    :emb:
    Flatlander Pete, Horkn and HDRock like this.
  8. HDRock
    Flatlander Pete, Chvymn99 and Stinny like this.
  9. Stinny
    Flatlander Pete, Chvymn99 and HDRock like this.
  10. Gasifier
    You mean I've been reading this whole time! o_O
  11. Gasifier
    Nice work on the piles Stinster. :thumbs:
    Flatlander Pete and Stinny like this.
  12. Chvymn99
    :yes: .... Good to hear on long term use. I've been looking for the rubber stuff, just haven't found what I'm looking for with out buying new. But really don't want one year and it's done either...sounds like it may fit the bill...:thumbs:
    Stinny, Flatlander Pete and HDRock like this.
  13. boettg33
    boettg33
    Wakefield, RI
    Need the desin specs, cut list and purchase list. I want them.
  14. weatherguy
    weatherguy
    central massachusetts
    I forgot about this stuff, I bookmarked the site to buy some and forgot all about it. I should order some before I forget again, sounds like its money better spent than on a tarp. Every tarp I've bought has lasted a couple years and that's it.
  15. HDRock
    The fiber reinforced grid on this stuff is not wimpy at all either, not little strings, they are 1/16" thick
    papadave, Stinny, Gasifier and 3 others like this.
  16. Flatlander Pete
    Flatlander Pete
    Go Dawgs!
    Just wondering. Can this type of tarp be cut into any width you like without fear of the reinforcing material unravelling? I was thinking of purchasing one big tarp and cut it to fit my needs and putting my own grommets in it.
    Another option may be to simply hook a tarp strap to the reinforcing material if it's that dang strong!
    It sure sounds and looks like great stuff.
    Let me know your thoughts, please!
    HDRock and Stinny like this.
  17. HDRock
    I haven't cut any but don't see why not , It's all bonded together, I have thinner tarps I have cut to size and for tarp Tie-Downs, these things flat out work great, http://www.northerntool.com/shop/tools/product_200365576_200365576
    Don't waste your money on this type
  18. Stinny
    The reinforcing is molded into the clear vinyl material when it's manufactured. It doesn't have a tendency to tear, but if it's super cold, it can tear easier, but still not like the green/blue stuff. Take a look at their grommets and install tool they have. You can cut your pieces and put grommets where you want them if needed. I usually use a narrow strip of wood and wrap the tarp on the strip a little... then screw thru the strip to hold the entire edge tight. It can take a lot of wind then and no grommets. Best thing to do, if you've never seen this stuff, is buy the smallest piece they have and check it out before you buy more of it.
  19. HDRock
    If you want to put in your own grommets, take a look here also, http://www.csosborneupholsterytools.com/category/Grommets / Vents / Dies Grommet Kits
  20. Flatlander Pete
    Flatlander Pete
    Go Dawgs!
    Thanks guys! I'm pulling the trigger. It looks awesome and I trust the FHC input! :thumbs: Appreciate the responses for sure!!! I'll let you know my review too.:D:D
    papadave, Chvymn99, HDRock and 2 others like this.
