FHC Exclusive! Long low oak burn in the new Ideal Steel stove
Discussion in 'Modern EPA Stoves and Fireplaces' started by BrianK, Nov 29, 2013.
  1. papadave
    I think it's been touched on, but let's not forget that Brian was opening the stove and also turning up the air at various points in the burn.
    The stove may have gone even longer if that hadn't been done.
    Maybe WS should put a stat on this one?;):D
    I'd be willing to bet they know how.
  2. Mitch Newton
    Mitch Newton
    Beavercreek, Ohio
    With these long of burns I'd like to see the condition of the flue.
    papadave, raybonz and milleo like this.
  3. rdust
    rdust
    SE, Michigan
    As long as the cat stays active the flue should be fine.
    Brian does the stove have a place to monitor cat temps?
    BrowningBAR likes this.
  4. BrianK
    BrianK
    West central PA
    No but it should be real easy to add a cat probe.
  5. rdust
    rdust
    SE, Michigan
    Good job Brian!
    I think this stove will burn similar to a BK when it's set on smolder like that which is awesome for the spring/fall seasons. If you go after those long burns again try it with a good coal bed. I find if I can load on a good coal bed and char the wood better before turning it down it will burn with a better stove top temp when it's dialed down. Doing this may avoid the need to open the air up during the burn to warm the stove back up a little. I find with a coal bed I get more smoke to keep the cat feed and happy. Obviously it's a different animal than a BK so it may not help anything! :)
    I'm also interested to see how it burns with some higher btu cord wood since that will better represent a more real world result.
    Keep up the good work! :thumbs:
    Gark and Backwoods Savage like this.
  6. BrianK
    BrianK
    West central PA
    That's helpful advice, thanks.
    When I do the low long burn on the locust this week I'm not going to record inside or outside temps or stove temps. I'm just going to load it full with locust, establish a fire, set it to zero, let it burn and find out how long it goes on that load.
    Gark likes this.
  7. raybonz
    raybonz Moderator
    Carver, Mass.
    Personally if I were to crawl burn a cat stove I'd want to know the cat remains active the entire time otherwise you could end up with a creosote factory! I feel all cat stoves should have a cat probe to ensure proper operation. This would be especially important when the stove is new to you.. Just my opinion here.. I always referred to my cat probe on my CDW..
    Ray
    Mitch Newton likes this.
  8. BrianK
    BrianK
    West central PA
    This stove has a hot spot on the front middle of the stove above the door, just in front of the cat. It gets really hot just after I cut back the air and the secondary air flames settle down so I'm pretty sure that hot spot corresponds to heat off the cat. It consistently registered as the hottest spot on the stove throughout the 24 hour burn.
    I figure as long as that hot spot is staying hotter than my stove top temp next to the flue collar then my cat must be functioning. But I wouldn't mind having a cat probe too.
  9. BrianK
    BrianK
    West central PA
    Thanks rdust. By the way, welcome to the forum. Good to see you here - where we're actually allowed to discuss this mythical stove :rofl: :lol:
    Backwoods Savage and raybonz like this.
  10. raybonz
    raybonz Moderator
    Carver, Mass.
    Serious you can't discuss this stove at another forum?? I love hearing all about this stove..
    BrianK likes this.
  11. Well Seasoned
    Lets not go there
    fox9988 likes this.
  12. raybonz
    raybonz Moderator
    Carver, Mass.
    WOWZA!!
  13. BrianK
    BrianK
    West central PA
    Yes sir. (But thank heavens for screen shots ;-)
  14. rdust
    rdust
    SE, Michigan
    Honestly I had no interest in joining another forum(I was happy with reading along) until I seen your name couldn't even be mentioned. That kinda rubbed me the wrong way so I figured I'd sign up so I could post here too. :)
  15. Well Seasoned
    Hmmm, your right
    fox9988 and BrianK like this.
  16. Well Seasoned
    Im glad you joined, and I've always enjoyed your content. You can introduce yourself here: http://firewoodhoardersclub.com/for...ntroduce-yourself-here.147/page-10#post-25297 if you want, but to most, you are no stranger around these parts
    BrianK likes this.
  17. BrianK
    BrianK
    West central PA
    Scotty and I weren't able to connect today, so I won't be able to pick up the locust till next weekend.
    So ...
    I'm going to repeat with the 3"x6" oak but on about 5% air without any air adjustments or opening of the door for photos etc. I might load it NW on hot coals instead of how I loaded for this 24 hour test. I can pick out the longest blocks for NW loading which will eliminate some of the gaps down the middle BBAR was referring to.
    DexterDay and Well Seasoned like this.
  18. sherwood
    sherwood
    Good luck with the burn. Will be interested to see the results. I expect Woodstock's direct air to the cat should keep you OK on 5 % air. Does 5 % mean just cracked open?
  19. BrianK
    BrianK
    West central PA
    Pretty much, yes. In DC Tom said he couldn't imagine a scenario when anyone would burn on 0% air so I'm going to keep it cracked open just a bit.
    The pre cat air only opens up on a HOT cat burn, so I don't know that it will come into play with this burn cycle.
  20. Tenn Dave
    Tenn Dave
    Give her hell, Brian............
    BrianK likes this.
