FHC Exclusive! Long low oak burn in the new Ideal Steel stove
Discussion in 'Modern EPA Stoves and Fireplaces' started by BrianK, Nov 29, 2013.
  1. Oldhippie
    Oldhippie
    Ashby Ma
    As we say here in Bahston.. Wicked pizzah Awesum!!
    raybonz and BrianK like this.
  2. Oldhippie
    Oldhippie
    Ashby Ma
  3. charlie
    charlie
    Schoharie, NY
    I would have loved to have seen the burn time on a Fireview that was built to the size of the Steel stove... I think that would have been a 2 day burner with lots of heat ...
  4. Machria
    Machria
    Long Island, NY
    Yep, when you want them, just turn the handle on the PH and you have a show. ;)
    The Progress is super easy to load. Before getting th stove, with no experience I could not understand all the talk of "Get a N/S loading stove, i's soe much betterto load....". Just seemed, open the doorand stick the wood in, what's the big deal? But now after a year, I get it. The PH is a N/S loading stove. The splits are E/W in the stove (left to right looking at it from the front), but since the door is on the side you are really loading "n/s", or sliding the splits straight in. That does make itreally easy, and safe as well.
    The fact you can load EITHER direction in the Ideal is absolutely awesome! Especially in a case like you (ad most of us), you often end up with short splits (from a previous stove, or tree guy cut it up to much...) and chunks and uglies. So with that big door, you get th both of all worlds.
    What are the basic dimensions of the firebox (Width x Deep x High)? Did I miss that somewhere?
  5. BrianK
    BrianK
    West central PA
    22" wide, 18" deep, 11" high at the rear and 15" high at the front of the secondary air plate that forms the ceiling of the firebox
  6. Machria
    Machria
    Long Island, NY
    So you can North/South 16 o 17" splits I take it.
  7. BrianK
    BrianK
    West central PA
    Yep. Eats 'em right up. Then a long one on top EW.
  8. firecracker_77
    firecracker_77
    IL
    What was the sale price back then? $2,500? I think they are $3,000+ now
  9. charlie
    charlie
    Schoharie, NY
    Yes around 2500...
    firecracker_77 likes this.
  10. sherwood
    sherwood
    They are usually $3600, right now on sale for $3200. I'd say about half the year or slightly less, the Woodstocks are on sale.
  11. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    I need a hell of a "refurbished" sale for the Progress and an "intro sale" for the Steel stove to give my wood burning addiction a new starting lineup next year. My Billy Beane approach to wood burning continues.
  12. Machria
    Machria
    Long Island, NY
    BB, if I worked fo Woodstock, I would have sent you a PH already! And had it installed for you, and if you didn't like i after a month, remove it for you. Cause I'd bet 1000-1, you'd keep it, and love it, and buy it fo whatever they asked for it. ;)
    If for noting else, just to get a comparison from it, and the othrstoves you are running and/or hve run in past.
    Of course, that doesn' help you cause I don't work at Woodstock, have never been there, and don' know anyone there other than a phonecall to order it, and a few emails with questions. ;)
    But to be honest, I'm amazed they can deliver the PH for 3,200 or whatever it is, and make a profit. The soapstone alone can't be cheap, then they have t cut it, shape it, finish it (sand and polish a bit), then fit it to stove, not to mention cast some iron, ben some sheet-metal, mold and bend some stainless steel, make and insert gaskets, add in a CAT, som hardware, paint, packing, marking....
    I can't figure out how they make money!
  13. reckless
    reckless
    This is probably why you smelt smoke, you had the air so low that the gas was building up igniting and blowing smoke out the front seal. This is exactly what happens on my VC when I completely close the primary. Just my opinion though and Im a noob....
  14. Oldhippie
    Oldhippie
    Ashby Ma
    BB Should buy one and then if he doesn't like it, some other poor dude can get an awesome refurb out of the deal!! :)
    Those refurbs are the Bees Knees! :D
    Chvymn99 and fox9988 like this.
  15. Oldhippie
    Oldhippie
    Ashby Ma
    I didn't see where he said he smelled smoke, but I think he meant he had the front door to his house open. ..don't think there was any puffing out smoke through his seals/gaskets.
    BrianK likes this.
  16. Oldhippie
    Oldhippie
    Ashby Ma
    Machira we need to get you up there sometime. You would love the walk through of the place and to see them building a PH is so worth the trip. I'll tell you this, once you see how they are built you will realize why they weigh 700 lbs, but you will also wonder even more how they make a profit on them, as there are a LOT of parts in one of them babies.
    Seriously do a road trip sometime and a couple of us other guys will meet you up there and we'll have some fun. Maybe they'll even let us play with the waterjet toy.
    Raybonz is dying to go up too, so I'll cajole him and then we'll get Charlie to come over from Upstate.. it'll be a party.
  17. Oldhippie
    Oldhippie
    Ashby Ma
    ROAD TRIP!!!
  18. raybonz
    raybonz Moderator
    Carver, Mass.
    I've been there Steve back when they had the open house a couple years ago and had a good time..
    Ray
  19. BrianK
    BrianK
    West central PA
    We did not smell any smoke when I took that video.
    We only smelled smoke the one morning when I had cut the air control way down to about 6 or 7% overnight and got up to door glass completely opaque with soot, very little heat off the stove, and stove top temps under 200. We have not experienced that smell before or since that one episode.
    Now I know with my installation and flue not to run it on that low of an air setting. There is no point to even try for that long of a burn and I do not intend to operate this stove in that fashion in real use.
    This is also why Woodstock likes to run Beta stoves ahead of releasing a new model. It helps them identify potential problems and areas that can be improved. They didn't really intend this stove for the long burns I put it through already on this thread, and they might not offer air settings that low on the production Ideal Steel stoves.
  20. Backwoods Savage
    Me too. Most times once a post reaches around 30 I quit looking unless someone asks something of me.
    Gark likes this.
