Felling and stacking today
Discussion in 'The Wood Pile' started by HDRock, Oct 22, 2015.
  1. NYCountry
    NYCountry
    Mohegan Lake NY
    Stacked a rack next to the house, should be burning soon 24/7 usually in November, I put weights to hold the tarps down
  2. bogydave
    Now that you process firewood
    You don't need to use the weights for exercise.
    Putting them to a better use, keep the wood dry :yes:
    NYCountry and HDRock like this.
  3. Backwoods Savage
    Either way on the splitting will work fine. I like to move the logs to where they will be split then set the splitter right beside and do the work without moving the splitter or moving it ahead just a little at a time. Those logs will be heavy but certainly not unmanageable. Shoot, you could even take the splitting maul back with you in case a couple logs were too big to handle. Split those in half and all would be well.
    HDRock likes this.
  4. HDRock
    I took the moisture meter out there right after I bucked it up, bottom half of the tree dead center is 25%, top half 16 to 20%
  5. wildwest
    When I see this thread pop up I misread the title everytime. First instinct is WTG girl, push up bras rock!! Then realize its about fire wood.
    Stephiedoll likes this.
  6. bogydave
    Stacking a stack is good
    but
    an unbridled stack is a good sight to look at too ;)
    wildwest and HDRock like this.
  7. NYCountry
    NYCountry
    Mohegan Lake NY
    You ain't kidding. It sure is better then exercise
    wildwest likes this.
