Fehrenheit endurance
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Ward8512, Feb 22, 2014.
  1. Ward8512
    Ward8512
    Northeast WI
    That is exactly what they are doing, as soon as the dampers come in. They had to be special ordered. My sister keeps telling me I should have went with Harmon (that's what she has). If they don't get this thing working I will never hear the end of it! ;)
  2. gbreda
    gbreda
    NH
    No you probably wont, but let's hope they get that Fahrenheit operational sooner than later!!
    Ward8512 likes this.
  3. DexterDay
    DexterDay Administrator
    Northeast Oh
    I can't see the bottom of the pot because of ash, but I would venture to say that isn't the newest pot, based on the version of the software. The newest pot comes to a "V" at the bottom. Yours will look like a "V" but will have a flat spot at the very bottom of the V (1/2" wide or so). I have this pot as well and it still works great. I don't know why they went to a Full V, but I know from talking with Matt Fitts (Lead tech at Fahrenheit technologies) that the newest version is a Full V.
    As for the software, the only change I can recall is the Blower setting (600 & 800). So no worries there.
    I am glad they are doing right by you. I think your really gonna like it. I never have to push mine on level 5. This year was the 1st time I used level 4 (we had -40° nights)If it's above 0° , I just use level 3 on the thermostat mode. I never used Fuelmizer mode either. But then again, I use my Enerzone stove upstairs for shoulder season (Spring and Fall when temps are not Freezing). I would highly recommend a good thermostat with a good swing setting. You don't want a 1° swing like most Honeywell stats have. You want a Lux 500, 1500, or a Good Hunter. They all have good swing settings (3°- 4°)
    A house your size, you should be able to use a lower setting. If you still feel like it's not up to par, then your gonna be better off hooking up the cold air return. Because the way it stands now, the furnace is heating your basement as well. It blows the heat upstairs through the registers, that air came from the basement and went through the furnace, then upstairs. So now, air upstairs has to come downstairs to replace that air. So you are heating every level of your home
    To keep the basement out of the equation, you will need a cold air return. I don't use one because I have a wood stove about 15' away and I can get the basement to about 90° and the Fahrenheit takes that hot air and distributes it upstairs. So I am helping the furnace by preheating the air. The wood stove also has an OAK on it. So that the house isn't drawing cold air in everywhere.
    The idea of an OAK is this. While the stove is running the exhaust blower is blowing 80 CFM (Cubic feet per Minute) of air out of the vent. By having the stove hooked to an outside air source, it's now a closed loop system. Air comes from outside. Stoves uses it for combustion of the pellets, then blows it back outside.
    Without an OAK, the stove pulls air from in your basement (air that you heated and paid money for pellets to heat). That air from in your house is then ducked into the stove, used for combustion, and then blown out the exhaust. Every Cubic foot of air that is blown out of your house, must be replaced. So any leaky or Draft area in your home will be pulling cold air in. Thereby making it even harder to heat your home. So every minute, you will be pulling in 80 Cubic feet of cold outside air through your drafty spots.
    That's why Fahrenheit wants one on the furnace. It's only helping you to heat your home and making the workload not as large. Your fighting against yourself when an OAK is not hooked up. They only make sense (although it's a great debate by many. Some say that they are useless. Some say that they are wonderful. I'm on the wonderful side. Every stove I own had an OAK).
  4. Ward8512
    Ward8512
    Northeast WI
    Thanks again! I cannot believe how nice and helpful everyone on here is. Nice to know that there are good people out there that will help a total stranger. :)
    343amc, smoke show, DexterDay and 2 others like this.
  5. will711
    will711
    Pocono Mts.
    Not a stranger any more just part of the family:)
  6. 343amc
    343amc
    Northeast Lower Michigan
    It's not the product that was the issue in this case, it was the installation. You'd be in the same boat with a Harman, as far as backdraft dampers go anyways. A PF-100 in a 1200 square foot house would probably drive you out of the building, or it would idle on low most of the time and require more frequent cleaning.
    DexterDay and Ward8512 like this.
  7. imacman
    imacman
    Denver, NC
    As you can see, his is 1.0......can it be upgraded with a firmware update?
  8. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
    Just wait until they get sobered up! They get a little cranky then!:rofl: :lol:
    Gary
    gbreda, 343amc, imacman and 3 others like this.
  9. will711
    will711
    Pocono Mts.
    What is this word sober you speak of:whistle:
    eatonpcat, smoke show, gbreda and 3 others like this.
  10. Ward8512
    Ward8512
    Northeast WI
    I think you means hers :)
  11. imacman
    imacman
    Denver, NC
    ooops. Sorry :emb:
  12. will711
    will711
    Pocono Mts.
    Go girl ,you fittin' just fine pop yourself a Woodchuck :drunk:
    gbreda, DexterDay and Ward8512 like this.
  13. Ward8512
    Ward8512
    Northeast WI
    My Hubby traded his friend 15 bags of pellets so his friend can try them. He had to take the kiddos to wrestling practice so I had to haul them in the basement. Who needs a gym when you have pellets...new exercise program 10 bags per day :)
    imacman, DexterDay, 343amc and 2 others like this.
  14. DexterDay
    Northeast Oh
    I noticed that, not much changed.
    I needed an entire board. Took old one and received a new one. And the blower was the only update. All fuels and trims are the same. Not needed. If she was gonna upgrade anything it should be the High flow exhaust manifold and the high flow sail switch.
    I don't know how Fahrenheit does upgrades? It wasn't as if the other parts don't work (this isn't a case like the M-55 NEEDED a bigger convection blower. So most models that were on the floor got an update). Although I would ask your dealer, because those 2 singles components made my stove go from borderline o.k. burning with damper wide open. To running with my damper 1/2 shut and getting a white firebox (you don't want to see dark colored ash. A grey, light grey, to white colored ash is what you want. And a nice and lively flame.
    343amc, gbreda and Ward8512 like this.
  15. 343amc
    343amc
    I moved three tons, a half ton at a time, near the end of August. Loaded them in the truck, unloaded into the barn at home, wash, rinse, repeat. At least the store was only 3 miles away.
    These days it's two bags a day from the barn, into the basement, then into the hopper. And I burn firewood off and on as well. I'd probably put on 10 more pounds in the winter if i only had to press a thermostat button to stay warm. That would be on top of the 5 pounds of winter hibernation weight I usually tack on.
    The pain from moving pellets and processing firewood is still a lot less than the pain I'd feel writing a check to the oil man once a month. :)
  16. will711
    will711
    Pocono Mts.
    Wrestling great sport everyone can play from the little guys to the big guys it's an even playing field :thumbs:
    Ward8512 and DexterDay like this.
  17. Ward8512
    Ward8512
    Northeast WI
    5 degrees out right now with a wind chill warning of 25 to 35 below through Wednesday. Sure wish that pellet furnace was working right now! At 5 bucks a gallon for propane I can hear my wallet being sucked dry!
  18. DexterDay
    Northeast Oh
    Just a thought, but they could have disconnected the main trunk off the furnace and you could have just had the furnace push all the hot air out of the top of it? And heat from the basement.
    That would have worked fairly well.
  19. Ward8512
    Ward8512
    Northeast WI
    New dampers are in and still not much for airflow out of our vents. I am ready to give up. 6000 dollars and can't even heat my house. What the h*ll was I thinking buying one of these when I know nothing about them. Stupid stupid stupid! I do not have money to waste. I could just cry...
  20. DexterDay
    Northeast Oh
    Take pics of where the dampers are in?
    How many registers throughout your entire house?
