Fed up with Combustors
Discussion in 'Modern EPA Stoves and Fireplaces' started by bobdog2o02, Feb 18, 2019.
  1. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Passed the air leak test.... I replaced the door gasket 1 year ago and the door glass is firmly in place. No movement.... the SS cat is going to be a between seasons thing, for now limping on a mostly toast cat but it's a night and day improvement allready.
    BigPapi, Maina, chance04 and 3 others like this.
  2. papadave
    Good news.
    BigPapi and bobdog2o02 like this.
  3. Canadian border VT
    Thanks for update
  4. rdust
    rdust
    SE, Michigan
    I’d suggest checking everything really well in the off season. That cat in your first post is really smoked.
    BigPapi, chance04, bobdog2o02 and 2 others like this.
  5. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    I'm wondering on a cracked stove?
    BigPapi and chance04 like this.
  6. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Would explain why I'm having cat issues in spite of diligent maintenance and exceptionally seasoned wood.
    BigPapi, chance04 and fox9988 like this.
  7. chance04
    chance04
    Denton Md
    Well that's great the stove is still functioning for you. Sorry you didn't find a culprit as to why your ceramic cat fell apart on that one side. I'm at a loss on what to suggest next to chase down what may have caused that.
    BigPapi likes this.
  8. chance04
    chance04
    Denton Md
    Weld fail? Seam split?
    It's cerainly a possibility. And would be hidden behind bricks this time a year
    BigPapi likes this.
  9. rdust
    rdust
    SE, Michigan
    Do you still have Control over the fire with the stat? bogydave had a hole in the back of his king.
    BigPapi, bobdog2o02 and papadave like this.
  10. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Yup, getting 12 hour burns again easily, great temps too. 400 degree Stt , 800-900 cat and 250 chimmey.... all looking good to me.
    Mitch Newton, BigPapi, TBONE and 4 others like this.
  11. Eric VW
    Good deal BDog :yes:
  12. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    well i think a problem became apparent today. Adhesive failed on the door gasket, came right out last night.... What size gasket does the door take on the PEJ1006? I found 7/8? but that doesnt seem a very available size?
  13. rdust
    rdust
    SE, Michigan
    Yep, 7/8, order it from the dealer.
  14. Highbeam
    Highbeam
    This is a dealer only gasket material which I think is lame but the seal is so important that you need the right stuff. I recall it was 30$ paid to the dealer and the gasket was shipped directly from BK to my house.
    I used a very deep bed of permatex copper RTV, the highest heat stuff for exhaust. It's all just RTV but the copper looks good in the one place it spooged out. I think I used a whole tube!
    While you have the door gasket out you can verify the glass gasket nuts are all properly tightened and the glass retainer brackets are flat. This is another lame thing about the BK, the door glass retaining nuts are under the door gasket. Makes access to glass gasket impossible and makes the door gasket prone to leakage unless you are liberal with the RTV bedding.
  15. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    ordered both gaskets and goo from a dealer 80miles away, theyre shipping to me....
  16. Woody Stover
    Woody Stover
    Southern IN
    I think "poisoning" refers to inactivation of the catalyst material due to burning chemicals of some type...colored newsprint, treated or painted wood, etc. I've seen the term "masking" used for what you are describing...coating with a non-harmful material that can be removed by washing the cat.
    Yep, I've seen the catalyst coating peel off the substrate in a couple of cases. I think that happens by repeatedly running the cat very hot...like glowing very bright orange.
    Not sure why the BKs are so sensitive to air leaks. I've had an air leak in the Keystone, and my SIL's Fireview, but have never seen a ceramic cat crumble. The air on both stoves comes out right in front of the cat.
    I would get the OEM product, it may be from a different maker..?
    Also, do you open the bypass for a couple of minutes before you open the stove door, to allow it to cool some?
    fox9988 likes this.
  17. Highbeam
    Highbeam
    Air leaks in a bk can cause thermal shock to the cat but also uncontrolled intake air bypassing the thermostat can overfire the cat.
    Bobdog’s cat was exceptionally destroyed.
    Woody Stover likes this.
