Did you clean the ports behind the jets? Torch tip cleaners work well for that. My splitter has been sitting at a friends house for the past 3 years. I can only imagine the fun that awaits me when I drag it home next weekend.
As The Wood Wolverine mentioned then, give Seafoam a try if you havent already. Ive had great luck with using it as an initial attempt before cleaning the carb. Run the fuel level low, then put a heavy shot of Seafoam in the tank and run it.
Pulled this beast out yesterday. Purchased in 2009 but I have not used it much since 2020 or so. At that point a friend was using it and in 2022 had to put the new motor on it. He stopped using it in 2023 and it has mostly sat since then, other than my running if a few short times. Noticed it was slower than normal and the larger hose (feed?) from the tank to the pump was collapsed. Need to go through and replace the filter and most likely the fluid but have not looked to see if it got contaminated or not. Right now, my pickup is at the mechanic to replace the pinion seal and he is going to look at the splitter tongue and that is cracked by the jack stand. Once I get it back I will start to check it out unless it's too cold, and in that case it can wait until spring. Not sure what I will do with it in the end as I don't need 2 splitters around.
