  1. Yes
    74.2%
  2. No
    9.7%
  3. I Want One
    16.1%
  1. ivanhoe
    ivanhoe
    Northern Ontario
    The high temperature copper silicone disappeared after I did a visual inspection during my warm weather cleaning :picard:
    I think I'll try to braze it later and temporary use chimney cement in the meantime or let it as is ;)
  2. Irish-1
    Irish-1
    Victory Twp,Mason County,Michigan
    I guess its not so "high" temp!
    ivanhoe likes this.
  3. heyswitz
    heyswitz
    skunks mizery ontario
    does anyone here have a new 50f just wondering if they upgraded anything
  4. heyswitz
    heyswitz
    just wondering what a bigger impeller does for u
    ivanhoe likes this.
  5. ivanhoe
    ivanhoe
    Northern Ontario
    More top end on air for fuel mix if you ever need it :D
    My furnace is somewhat new if that matters :smoke:
    Irish-1 likes this.
  6. Irish-1
    Irish-1
    Well My stove is newer I guess,only a couple years old.I wanted to install the bigger impellar for level 5 burning in January with hardwood pellets,I am hoping for a better burn maybe a little more heat.
    ivanhoe likes this.
  7. heyswitz
    heyswitz
    ok thx maybe something I need to look into I burn corn so maybe that would help it
    Irish-1 and ivanhoe like this.
  8. heyswitz
    heyswitz
    well my 50f is 8yrs old just wondering if they updated anything on them
    ivanhoe likes this.
  9. wildwest
    Drolet Eco-65. Does anyone know the two buttons to push simutaneously to reset BOTH auger motors? Power went out and they are not running, for the life of me I cannot it the manual.
    Edit, just remembered, getting cold in here. its push - and + that resets the whole board. Tried it and now feeding and should ignite soon :yes: That was it, both augers working now.
    Editing to add again, it is on a UPS surge protector.
  10. ivanhoe
    ivanhoe
    Northern Ontario
    It's good you remembered :D Now tape a note on the furnace ;)
    Irish-1 and wildwest like this.
  11. Irish-1
    Irish-1
    I've had the auger time-out on me twice so far this season,Each time ,I clean all the pellets out of the hopper to see if there is something causing a jam...I find some
    sawdust.I press the lid safety switch and the prime button and it works fine.Then I vac the Auger out,fill hopper,prime it and it starts back up and im in business.I
    Also checked for play in the auger ,it had very little. Any Thoughts Gentleman? Is it time for a new auger motor??:confused: Thanks in Advance!!
    ivanhoe likes this.
  12. ivanhoe
    ivanhoe
    Northern Ontario
    Do you sift your pellets? Everytime I switch pellets and run the hopper empty I vacuum and oil the brass coupling. Mine also leaves a buildup of fines underneath inside the cabinet.
    Irish-1 likes this.
  13. Irish-1
    Irish-1
    Yes and no,First start of the season I clean hopper every week. Then I start vaccing them when it really starts to go though alot per day
    Was thinking about getting the beefier auger motor,The Fahrenheit are rate at 150 inch lbs of stall torque,The Glean/Avery unit is 180.
    I started Vaccing them as of the failure.
    ivanhoe likes this.
  14. Irish-1
    Irish-1
    Just ordered some "Ultra Premium" White Pine Pellets for the polar vortex days:) I hope I get and extra 10* out of them. Im getting about 165* out of my hardwood pellets(Pro Pellet) on level five.:thumbs:
    jtakeman and ivanhoe like this.
  15. Irish-1
    Irish-1
    And My Auger just timed out again...I think I have got it figured out.Fan Limit switch is going to hell,Tied the high limit sensor wires together and shes running,I am hunting for a new fan control locally.... My Fahrenheit dealer is just this side of worthless,doesn't stock any parts except for the top plate.
    ivanhoe likes this.
  16. ivanhoe
    ivanhoe
    Northern Ontario
    You can get that part at any furnace shop!
    Irish-1 likes this.
  17. Irish-1
    Irish-1
    Yes Sir,Found one at premier heating in Ludington. Got it installed and been working perfect since. The old unit was starting to melt where the hot wire connects on the fan control side. Side note,
    them damm things are spendy!
    ivanhoe likes this.
  18. heyswitz
    heyswitz
    having a bit of problem with corn 13.9 % runs good for 3-4 hrs then after pot change it starts piling corn up in middle of pot any suggestions as to what the problem is all gaskets seem good on door an ash pan. getting flustered
    ivanhoe likes this.
  19. ivanhoe
    ivanhoe
    Northern Ontario
    I'm mixing my corn(30%) with pellets(70%) so I can't tell you what gives. It might be sticking to the burn plates ? I find my exhaust screen gets a build up of soot, could be the fines in the corn which I manually screen prior to mixing with pellets. I need to find a way to vacuum the corn prior to loading my barrels. The bluejays are enjoying the crumbs :D
  20. Irish-1
    Irish-1
    I have a new idea for a vac system,I will be building after the silly season.
