  1. Yes
    75.9%
  2. No
    6.9%
  3. I Want One
    17.2%
  1. ivanhoe
    ivanhoe
    Northern Ontario
    Maximus rebuilt his burnpot and might be a source for beef up parts!
    wildwest, Irish-1 and DexterDay like this.
  2. Irish-1
    Irish-1
    Victory Twp,Mason County,Michigan
    Maximus can ya help a brother out?
    ivanhoe and wildwest like this.
  3. NorthernCrew454
    NorthernCrew454
    NE WI
    Hi All,
    Just picked up a used Fahrenheit 50F, serial number 2413. I look forward to reading through this entire thread for tips and tricks!
    Jay Z, Eric VW, DexterDay and 5 others like this.
  4. ivanhoe
    ivanhoe
    Northern Ontario
    Welcome to FHC NorthernCrew454 :handshake:
    Pics are always required and tell us about the planned install :smoke:
    Sounds like you've the red LED Control panel with the Auto Ignition ;)
    Eric VW and Irish-1 like this.
  5. DexterDay
    DexterDay Administrator
    Northeast Oh
    I'll second what ivanhoe said. Welcome to FHC and pics are a must of the install! If you have any questions about the furnace, do not hesitate to ask!
    I also added you to the "list" of owners and serial numbers on the 1st page.
    Highbeam, Irish-1, ivanhoe and 2 others like this.
  6. Jay Z
    Jay Z
    Southeast Wisconsin
    I am located in Southern WI. Have a Fahrenheit 50 for last 5 years. If you need info email me. [email protected]
    ivanhoe, Irish-1 and DexterDay like this.
  7. DexterDay
    Northeast Oh
    NorthernCrew454
    I'll add you to the list. Look on the back of your furnace for your serial #
    ivanhoe and jtakeman like this.
  8. ivanhoe
    ivanhoe
    Northern Ontario
    Dex, I see you connected your cold air plenum to the furnace :yes:
    It does help on the movement of cold air around the house. I was getting smoke around my DTM vent near the furnace outlet when it was igniting so I removed the heat shield to further inspect it. I found the evidence of soot at the seal which was caulked with High Temp Silicone which was probably pulled down at least a 1/4 inch when I did the assembling when first installed. So I clean it up and resilicone it. Let dry then I adjusted the extendable vent to the furnace outlet for a perfect fit. Glad I nosed around the assembled vent and corrected the problem.
  9. ivanhoe
    ivanhoe
    Northern Ontario
    Just noticed your cold air plenum isn't completed to the cold air return :picard:
    My insurance broker brought it to my attention on propane furnace cannot be fitted with a solid burning add-on, it's a big no-no!
    Maybe if they are further apart it might be allowed or different insurance companies, different rules:whistle:
    DexterDay likes this.
  10. Jerry Welch
    Jerry Welch
    Indiana
    Hello everyone I am new to this group and a new owner of the 50f furnaces, got mine on the 16th of november and installed as an addon, not doing what I think that it should so is there anything that you veterens can give as pointers anything would help.
    Thanks in advance.
    Jerry
    ivanhoe likes this.
  11. ivanhoe
    ivanhoe
    Northern Ontario
    First welcome to FHC:handshake:
    Pics Pics Pics are always helpful :smoke:They also help on troubleshooting ;)
    What seems to be the problem?
    Explain your set-up and will see what we can do for you :yes:
    Serial number is required so we know which furnace you have just for references, whatever that means:D
  12. ivanhoe
    ivanhoe
    Northern Ontario
    The leaking vent fix did the job, no more smoke :smoke:
    Made to silicone gaskets, a round one for the exhaust fan and a square one for the otherside of the exhaust fan for impeller cleaning. Haven't install yet just waiting for a replacement time :yes:
  13. DexterDay
    Northeast Oh
    Our insurance agent comes out every two years. She has seen and watched them all operate.
    Not sure why with Propane it is a no?
    Jerry Welch - How many square footage are you heating? Where is the furnace located? How is it sent through your house?
    What is the exhaust path? What pellet vent size?
    As ivanhoe said, pics help tremendously!
  14. Jerry Welch
    Jerry Welch
    Indiana
    I am heating around 2500 square feet and the furnace is in the basement and is hooked to the duct work from my gas furnace, the exhaust is coming out into a clean out tee to a 45 degree then up about 3 feet to another 45 then out through the foundation to another 45 with bird guard, vent is 4",and my serial number is 3627
    ivanhoe likes this.
  15. ivanhoe
    ivanhoe
    Northern Ontario
    Pics are always welcome.
    Thanks for replying back.
  16. DexterDay
    Northeast Oh
    I added you to the list on the 1st page. Do you have the required dampers in place? On the Fahrenheit and your gas furnace?
    And pics always help with questions.
    ivanhoe likes this.
  17. Irish-1
    Irish-1
    Has anyone ever played with the auger and draft trim settings ? If so how has it worked out for ya?
    Jay Z, DexterDay and ivanhoe like this.
  18. ivanhoe
    ivanhoe
    Northern Ontario
    no
    No, but I could just imagine on the improvements it can do and not knowing .........................don't want to go there :whistle:
    DexterDay, jtakeman and Irish-1 like this.
  19. Irish-1
    Irish-1
    If it aint broke dont fix it right...LOL:hair:
    Jay Z, DexterDay and jtakeman like this.
  20. ivanhoe
    ivanhoe
    Northern Ontario
    Never took the time to try it, just hooked it up and light it :whistle:
    But you did refresh it back somewhere deep, deep in a far corner of the brain :zip:
    One of these days I/we should take the time to try it:smoke:
