  1. Yes
    75.9%
  2. No
    6.9%
  3. I Want One
    17.2%
  1. ivanhoe
    ivanhoe
    Northern Ontario
    My older Fasco exhaust motor is starting to make noises:hair:
    Must be the impeller:whistle:
  2. ivanhoe
    ivanhoe
    Northern Ontario
    If I put some pressure on the motor the noise goes away, mmmm!
    Too cold tonight so a job for tomorrow.
    The Lacrete's are smoking, 160*F at level #4.
    Irish-1 likes this.
  3. ivanhoe
    ivanhoe
    Northern Ontario
    Here's the scoop, the metal black casing is slightly loose from the grey casting and vibrates! It seems the motor winding will rub when pressing the motor. Could of that have happen when I switches impeller, had to hit down the shaft as it was too snug even with antiseize. Next time it'll be emery cloth the shaft while she spins.
    Irish-1 and Jay Z like this.
  4. ivanhoe
    ivanhoe
    Northern Ontario
    So the OEM spare Fasco with original impeller is back in duty. I haven't taken notes on the difference of air damper position and heat output yet but will report back on any changes.
    Jay Z likes this.
  5. ivanhoe
    ivanhoe
    Northern Ontario
    11% more air damper opening for same pellet heat(160*F) and 12*F difference at same air damper opening, so the bigger impeller makes a difference but is it really needed? more top end air if ever needed! Those #'s are for my tweaked furnace and #4 heat setting on premium pellet fuel choice, others might have different results:whistle:
  6. ivanhoe
    ivanhoe
    Northern Ontario
    I'm gonna install some studs in place of those four bolts holding the exhaust manifold, I'm having a hard time aligning the holes for the bolts and it would hold the gasket in place too;) Or is there a trick I'm not aware of:whistle:
  7. Irish-1
    Irish-1
    Victory Twp,Mason County,Michigan
    My motor makes the same damm noise,sorry I haven't been on in awhile,had hand surgery then the flu!:faint:Matt told me to tighten the crimps on the motor housing with a hammer and chisel,it really didnt help,Also I called the dealer that told me about the st criox motor and fan,when i asked for part# I got "we have them in stock".:doh:
    I use a drift pin,long tapered punch, when setting manifold back in place,seemed to make lining it up a snap!:smoke:
    Jay Z and ivanhoe like this.
  8. Irish-1
    Irish-1
  9. ivanhoe
    ivanhoe
    Northern Ontario
    Looks like the beefed up impeller I have but with the OEM Fasco motor!
    I taught about a drift pin to align the exhaust manifold, thanks for reminding me of doing it next time:yes:
    Jay Z and Irish-1 like this.
  10. Irish-1
    Irish-1
    Well,Hello March!:D all downhill from here,two more months and I can shut her off for summer,I happy to say I've have just a little over two tons left start this month!:thumbs:
    ivanhoe likes this.
  11. ivanhoe
    ivanhoe
    Northern Ontario
    In like a lamb and out like a lion:picard: so they say :whistle:
  12. Irish-1
    Irish-1
    Oh yeah,I'm sure right towards the end we are going to hit hard!:startled:
    ivanhoe likes this.
  13. Irish-1
    Irish-1
    April is just kicking us in the Balls!:jaw: I hope it quits snowing!!LOL Just about have ton #6 gone
    ivanhoe likes this.
  14. ivanhoe
    ivanhoe
    Northern Ontario
    I'm nearing the 6 tons too, 276 + :picard:
    heyswitz likes this.
  15. heyswitz
    heyswitz
    skunks mizery ontario
    hey there I,m from s/w ont. have a 50f for 7 yrs ser.3253 been doing a lot of sandybagg,in u guys have tought me a lot I didn,t know thx for that was wondering where u get that bigger propeller 4 the exhaust motor I burn mostly corn never had much luck with pellets get better heat and cleaner cheaper! they call me switz!
    jtakeman and ivanhoe like this.
  16. ivanhoe
    ivanhoe
    Northern Ontario
    Hi and welcome heyswitz :handshake:
    Show us a pic or 2 of your set-up!
    Bigger impeller can be located further up this thread. Don't have the info at hand or :loco: :crazy:
    Irish-1 likes this.
  17. heyswitz
    heyswitz
    I found it does it make a big difference and worth the money
    ivanhoe likes this.
  18. ivanhoe
    ivanhoe
    Northern Ontario
    It gives you more top end of air injection, might keep the piping cleaner? The Gleason/Avery motor? Mine got toast after a couple of seasons, not a believer on that mod!
    This is what I noticed going back to stock impeller. Some holes in the burnpot have been sealed to increase more air underneath the fire.
  19. Irish-1
    Irish-1
    Welcome heyswitz!:coldone:
    ivanhoe likes this.
  20. Irish-1
    Irish-1
    Well Fellas,Fired up the old Fahrenheit tonight...sept 30th... gave her a good go over and she fired right up. Had nine bags left from spring .
    Think im going to need a new pusher plate this season,any guys on here make them out of SS?
    DexterDay and ivanhoe like this.
