  1. Yes
    75.9%
  2. No
    6.9%
  3. I Want One
    17.2%
  1. BAN83
    BAN83
    Ontario, Canada
    Santa Dex.... haha
    DexterDay and ivanhoe like this.
  2. ivanhoe
    ivanhoe
    Northern Ontario
    Even better:D
    DexterDay likes this.
  3. DexterDay
    DexterDay Administrator
    Northeast Oh
    Gonna try and find time tomorrow. But I also need to do some last minute shopping for my son and my wife.
    ivanhoe and BAN83 like this.
  4. Tjim01
    Tjim01
    Burbank, Ohio
    I have an idea.. Let's all post up your serial #'s.
    Quote this post (when you quote it, delete the "quotes" at the beginning and end of the list. That way it's not dark grey and it look like your post) and add your serial number. I'll edit it if need be. Or copy and paste my post and add yours below it)
    Tjim01 - 3143
  5. Tjim01
    Tjim01
    Burbank, Ohio
    Hello all - I'm new to this forum, but not new to burning corn and pellets. I used to frequent the "iburncorn" site (I think now defunct) when I first got involved in this in 2008 with my first F50. Mark Graham stopped by my place when I first got it and was having problems - he then upgraded me to the newer version for free in Michigan. Great guy. Anyhow, I haven't burnt for a couple years since the propane prices fell and my furnace sat dirty (what a fool I am, I know I won't do THAT again!) and corroded quite a bit during that time. I'm now going through it and upgrading what I can - getting a new exhaust fan motor and blade from Don, based on the information I found here :). I'm also going for the upgrade exhaust manifold, but I think most if not all the bolts will snap off when I remove the old manifold (see pics). What headache am I in for when that happens? Pretty tight quarters behind there and not sure if I am left with drilling them out and trying to get nuts behind there? Not to easy for me to get in from the back.
    Also, how important is it for me to get to the top of the exchange tubes? The heater exchange tube plate is also rusted and one screw is already snapped off without me doing anything yet....[​IMG][/URL][/IMG]
    It's all a mess right now - not sure where all the moisture came from. I had the exhaust and intake all capped off from the outside this whole time.
    Jay Z and ivanhoe like this.
  6. ivanhoe
    ivanhoe
    Northern Ontario
    Looks like you have your work cut out for you. Basement is damper than the rest of the house. Might have to put Dampness removal aid gizmo. Mine was surface rust from the summer. Welcome to FHC.
  7. Jay Z
    Jay Z
    Southeast Wisconsin
    Time for Damp Rid kits placed in unit and cooking spray to goober rust. Looks like a winter project.
    ivanhoe likes this.
  8. Tjim01
    Tjim01
    Burbank, Ohio
    Roger that - it is winter and it is definitely a project! Got two bolts drilled out and re-tapped. Waiting on 6" drill bits to get to the other two. Luckily, my son works at Fastenal to get me all the odd tools and supplies I need ;-)
    I have another question for you all - The unit is tied into my propane furnace ductwork and I question if I can/should disconnect from the return air plenum. I have 2 reasons I am considering this;
    1). The sheetmetal box the installer made on the back of the unit extends across the entire width of the unit. As the exhaust duct exits just above this, it makes it near impossible to get to the clean-out of the exhaust without disassembling ductwork. If it stays, I at least will need to have that box made differently to correct this.
    2). While working on it with the house furnace running, I notice massive amounts of return air back-feeding from the ductwork into the burner, which is only reducing the effectiveness of the house furnace system.
    So, as I understand the purpose of return air loop in an HVAC system, I'm not so sure I really need the burner tied into this as the house HVAC is already providing the loop - why can't the burner simply take the cold air from the basement and push the warm air into the house hot-air loop? (I'd also love to get rid of the convoluted & massive (12") cold air ductwork in the process.)
    Thoughts??
    ivanhoe likes this.
  9. ivanhoe
    ivanhoe
    Northern Ontario
    I don't have the cold air return installed and finding the dust from filling the hopper dirties the filter sooner than later.
  10. Tjim01
    Tjim01
    Burbank, Ohio
    Thanks for the input. I can deal with the filter getting dirty sooner.
    Here's another interesting pic...I got the HE Tube Plate off with only 1 broken screw and found what appears to be Stalactites , lol.....just odd.
  11. Tjim01
    Tjim01
    Burbank, Ohio
    Sorry, but I have another question - are you pulling your combustion air in from outside, or just the room? If from outside, what are you using for the duct and adapter to the duct, if required? I removed the chicken-chit setup the installer had in there an debating if I even need to replace it or not?
    FYI - The return air ducting is now history and I like it gone.
    ivanhoe likes this.
  12. ivanhoe
    ivanhoe
    Northern Ontario
    My furnace is inside a furnace room 7 1/2ft X 13ft. I leave my door open to let out heat into the laundry room. Not much heat but my water system is in there too. Ok for hot water tank but not the cold tank. I will tie the cold air later as I'm still tinkering ideas how to connect it. I will be going on left side from looking in front of furnace. Right side is too busy.
  13. Jay Z
    Jay Z
    Southeast Wisconsin
    Need a good grill brush and chimney brush to clean out. Check the airflow holes in back of ash pan drawer. I use plumbing strap to run up sides and clean.
    My stove has the cold air return from Fahrenheit so not much to prep for cleaning. I also have 3ft of clearance in the back. Mine is ducted into my furnace as well.
    ivanhoe likes this.
  14. Jay Z
    Jay Z
    Southeast Wisconsin
    You can go to Fahrenheit website and download the manual for free. You also need a back draft damper going to main furnace. They also recommend one on main furnace below AC coil.
    ivanhoe likes this.
  15. Tjim01
    Tjim01
    Burbank, Ohio
    Thanks guys - I have the manual and all is/was installed according to the instruction "Connecting to existing duct work & furnaces"...just think the return air connection is pointless. In my earlier post I misspoke a bit. The return air duct wasn't "back-feeding" is was drawing cold air through the F50 anytime house furnace was on...and the F50 was not, which reduces the return air effectiveness of the house furnace (and maybe draws damp air from basement into the F50 when not running, partially causing this mess).
    I don't run the F50 as much as you fella's - especially with propane prices at reasonably levels. I have quite a bit I pre-bought cheap enough that burning pellets or corn isn't much worth the effort anymore, but once I get this thing done with all the upgrades (Don's motor & fan, Sail Switch, Exhaust Manifold, plugging some pot holes, sealing the hopper, yadda, yadda) I'm hoping burning gets more efficient and it's competitive even at these propane prices (which will be going up this year I think). I was only getting about 135-140 degrees from the F50 (measured 12" from top of unit) and hope to get closer to 155 when all is done.
  16. DexterDay
    Northeast Oh
    Do you have a back draft damper on the plenum of your furnace (coming out of the hot air supply/top of furnace)? Without one air will back flow through your system.
    As for serial #'s I will add yours to the list on page one of this thread. See here -
    BTW- Welcome to FHC!! :thumbs:
    The screws for the clean out above the heat exchange tubes are just small sheet metal screws. Having one or two break shouldn't be a probelm. Just replace with a small/slightly bigger self tapping screw.
    The upgrades will help a lot. I've been tinkering for 5 years with mine and I now have my damper about 50%-60% closed and still have a very good burn. Very white/grayish ash.
    This pic was after the unit sat at idle (level 1 with auger trim at 2 and Draft trim at 1). 5 years ago this would have made a black mess. The deposits on the furnace walls would actually burn because it was so dirty and still volatile.
    The burn pot has all the holes in the front burn plate block and all but maybe 6 in the back pusher plate. The sides just have the upper holes blocked (not in the bottom V. Just the row of 5 near the top).
    And I run an OAK and pull outside air. The combustion blower is around 80 CFM. So without an OAK you are blowing 80 Cubic feet of air (heated air) out of your house. That 80 cubic feet is being replaced with cold outside air from your windows, doors, outer wall outlets, etc. Which makes it harder for the stove to heat the house.
    The main reason for the cold air return to eliminate your basement from the heating requirements. If you pull air from upstairs (warmer air than the basement) and then heat it and put it back upstairs? Then the basement is not heated.
    With the cold air disconnected? You now pull warm air downstairs and have to heat cooler air from downstairs and put it back upstairs. So the basement is now part of the heated area. Whether you want to or not. Just because the replacement air is now heating the cold basement air.
    I don't have a cold air return myself. But my basement air is warmer than upstairs because I run a woodstove down there. That adds to the efficiency of the Pellet furnace. Pulling 80° air from the basement makes the air coming out of the plenum warmer than if it was pulling 60° air without the wood stove.
    ivanhoe likes this.
  17. DexterDay
    Northeast Oh
    Added your serial # to the list. Your unit is very new. 3rd on the list. We have 12 members with this unit. That's probably more than even the most popular freestanding unit here (Harman P61 or P68). That's more members than any forum out there. Including Iburncorn when they were huge! (I was a member there).
    ivanhoe likes this.
  18. Tjim01
    Tjim01
    Burbank, Ohio
    Thanks Dexter - I do have a backdraft damper on the furnace and also use outside air for the combustion. I would say my basement is "semi-heated"...probably 65 degrees generally. I am planning to plug my pot holes according to your example also. I hope I can get to your clean/efficient burn before the winter's over...just waiting on parts now to put it all back together. Kinda excited to get it going again after the couple year break.
  19. DexterDay
    Northeast Oh
    Pellets are a big contributor to the heat output. I've been reading temps for years from the same spot. I've seen as low as 120°-125° and as high as 165°-170° All my tests have been done with the woodstove going and an average downstairs temp of 75°.
    The somersets I have produce an average of 155° and the stove Chow is around 135°. Both were done within the same week this year, on the same heat level 4 (normally do them on 3 in previous years. But I've found on level 4 I am using less Pellets to regain the same heat).
    A 20° output temp differenceis huge. I notice it in just how long the furnace runs as well as how much I burn. Every year I say I'm just gonna by Somersets (best in my area without driving about 1.5-2 hrs) but last year Stove Chow was at $199 a ton and Sets were $250- $265). So the difference in price V's amount burned makes up for itself. Especially after buying 6 ton of Stove chow. I saved over $300. I'd have to burn less than 4.5 ton of Sets over the 6 ton of Chows.
    So buy a good pellet, but one that at least produces decent temps. I bought 6 ton of Presto Logs 3 years ago and they averaged about 140°-145°. I'd love to find more of them for less than $200 a ton.
    As for other biomass. I've tried corn (when mixed with pellets 50/50 I had good results), cherry pits (great burn but so light that they blew out of the pot half burned and less than average heat), and horse bedding Pellets (100% pine and no additives. Super good heat! Great burn! But not rated for stoves and they are pricey!).
    ivanhoe likes this.
  20. DexterDay
    Northeast Oh
    Our LP prices have been down as well. I could've maybe saved a few bucks by not burning pellets/wood. But I was afraid I would get lazy. After getting a promotion at work (and I started burning 8 years ago when LP was far more expensive) I know I can afford the LP without worrying about our budget.
    But it is now a family hobby. My son and I do all the wood cutting, and filling the wood racks in the basement. The wife and my son feed the Pellets down the "slide" to the basement while I stack. And both of them fill and can operate them if I go away on vacation. So even though we can afford it? It's something that brings us together almost all year round (especially the wood side of things).
    Me and the wife stacking just over a year ago.
