fact/fiction?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by ivanhoe, Dec 22, 2013.
  1. ivanhoe
    ivanhoe
    Northern Ontario
    I was at my Harman dealer and was discussing my unsuccessful dismantling of the exhaust fan on my Accentra FS stove. I've tried heat, acetone/power steering mixture, PB blaster and other premium penetrating oils with no luck at dismantling fan off the motor shaft, I even broke a allen key in the process. He mentioned of trying a wood stove glass cleaner. He says it breaks down the soot & creosote and frees up the strangle hold of the nut on the shaft. He also mentioned the tightness of the set screw would be high in the first place so be prepared for that too. Further talking about my stove not performing like it use too, he mentioned the exhaust fan is getting tired and not spinning as fast as before. By doing a draft test, maybe the #'s are not what it used to be. I want a vacuum gauge for christmas to see for myself. I still have to get around of changing my door seals, just waiting for a rise in the temperature to jump to it. Have a good and safe X-mas everyone!
  2. Hoot23
    Hoot23
    Alfred, ME
    Keep us posted. I wanna change my door seals at the end of the season. Is there a time period on changing the gaskets?
  3. subsailor
    subsailor
    Winthrop, Maine
    I'm wondering the same thing about my exhaust fan. I don't seem to be getting than air like I used to and my ash is blacker than normal. I thought it might be my door seals and had them replaced with only a slight improvement. I also can't seem to get the set screw out of the fan like you.
  4. imacman
    imacman
    Denver, NC
    Spray w/ PB blaster the day before (if possible). Then a propane torch w/ small flame and heat the fan hub....try to stay away from the allen screw.
    Oh, BTW, don't know if dealer confirmed that the set screw is really an allen, but some set screws are actually torx screws.....the one on my comb. fan is.
  5. Hoot23
    Hoot23
    Alfred, ME
    I had a problem with the set screw on my sisters 68. I was scared to break anything. I gave one last crank before giving up, and it finally came loose. Shouldn't be a problem anymore. Mine comes off easy.
  6. IHATEPROPANE
    IHATEPROPANE
    I bought a tachometer to see the rpm on my combustion blower......I guess my baseline is 3300
    brokenwing and smoke show like this.
  7. smoke show
    smoke show
    Pittsfield, Wi
    Sweet. what's its redline? :D
    jtakeman, brokenwing and IHATEPROPANE like this.
  8. gbreda
    gbreda
    NH
    Not really, just do the dollar bill test. I changed mine this year after 4 full seasons.
    Hoot23 likes this.
  9. subsailor
    subsailor
    Winthrop, Maine
    Same here.
    Hoot23 and gbreda like this.
  10. don2222
    don2222
    Salem NH
    Hello
    I worked on an old PP38 and could not get the impeller blade off! So I removed the bolts that held the motor to the stove body. Then I took out the old hand held hack saw and cut the shaft. Installed a new motor and new impeller blade! Problem solved! ! !
  11. Lousyweather
    Lousyweather
    if I had to guess, around 80% of them wont come off easily at all. When we do a repair, we first determine if the blower is good or not...if it is NOT good, spend maybe a minute trying to get it off.....if not, rotozip the shaft off, replace fan AND impeller. Time is money here, guys, and when you do this for a living, it just isn't worth wasting all that time........
    gbreda likes this.
  12. ivanhoe
    ivanhoe
    Northern Ontario
    A time waster, yes but spare motor if the new one fells. I just did a cleaning and installed the new gaskets. Made a difference, hard to say. I was not impressed with the cement supplied with the rope, just too runny. I also switched to Ambiance pellets from Trebio's.
