Explosive ignition on p43
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by D-Mac0211, Mar 23, 2018.
  1. D-Mac0211
    D-Mac0211
    Upstate, ny
    Went through the 5 blink and nothing you could smell like they wanted to light but nothing
    ivanhoe and IHATEPROPANE like this.
  2. IHATEPROPANE
    IHATEPROPANE
    I think its more the boom thats troubling....which he should be concerned.
    That being said, I also believe its a lack of air issue. My stove had a burn pot redesigned prior to me buying one because of booming ignition. Added more air holes to the bottom of the pot.
    The new quad a couple years back had issue too if IIRC.
    ivanhoe and imacman like this.
  3. D-Mac0211
    D-Mac0211
    Upstate, ny
    I have a new burn pot. It has 6 rows of holes. I can’t even get the thing lit in auto now.
  4. D-Mac0211
    D-Mac0211
    Upstate, ny
    I don’t get it. The igniter is getting hot. Enough to where it blackens some pellets but they won’t light. I’m at a loss
  5. IHATEPROPANE
    IHATEPROPANE
    Is the igniter in the proper position? On a Harman can it only go in a certain way so its exactly the same every time it is swapped out?
    I am assuming you can see it glowing orange during startup
    ivanhoe, imacman and Eric VW like this.
  6. D-Mac0211
    D-Mac0211
    Upstate, ny
    It is in the right position. The cables are on the right side of your looking at the burn pot and I never took the cover off while it was going to see the igniter
  7. ttdberg
    ttdberg Pellet Pig
    CT
    If I remember, your venting goes up then into the wall, into a pre-existing chimney liner? Are you certain the flue is clean after where your pellet venting enters the wall? Have you looked in there past the thimble (assuming you can) as well as from the top, even if that means getting up on the roof and pulling the cap off to see inside?
    imacman, ivanhoe and IHATEPROPANE like this.
  8. D-Mac0211
    D-Mac0211
    Upstate, ny
    Yup just did it the other day. Vacuumed the chimney out. Cleaned the flue. I’m at a loss. Seems like somehow it’s not getting enough air flow up through the burn pot or something. Idk.
  9. IHATEPROPANE
    IHATEPROPANE
    Is there any way you can perform the leaf blower trick on it?
    ivanhoe likes this.
  10. D-Mac0211
    D-Mac0211
    Upstate, ny
    What’s that?
  11. IHATEPROPANE
    IHATEPROPANE
    ivanhoe likes this.
  12. ttdberg
    ttdberg Pellet Pig
    CT
    Did you say ina previous thread that you modified the air inlet flapper? Put a hole in it or something along those lines?
  13. D-Mac0211
    D-Mac0211
    Upstate, ny
    Nope not I.
  14. D-Mac0211
    D-Mac0211
    Upstate, ny
    What I don’t get is it was working great the other day
  15. ttdberg
    ttdberg Pellet Pig
    CT
    When the stove takes a long time to start (or doesn’t start) does it try so long that pellets spill over the end of the burn pot into the ash pan?
  16. D-Mac0211
    D-Mac0211
    Upstate, ny
    Yup. Tried it 2 different ways. 1 tried letting them spill till the 5 blink came on and then waited till they got close opened it up took some out and let it go. Same results either way
  17. D-Mac0211
    D-Mac0211
    Upstate, ny
    So I’m out of ideas. Also this weekend I took all the piping apart and used a soot eater and douched it all out. Then went up on the roof and vacuumed the chimney out and came in and sucked whatever right out of the flue. Did a draft test when I got home today and posted the results for that and the high pressure was like .05 high but the low I dialed right in and never lit. Igniter is less then prob 4 months old. New burn pot with gaskets, new exhaust gasket. Idk what else to do
  18. D-Mac0211
    D-Mac0211
    Upstate, ny
    I’m at my wits end with this thing. Prob the only thing I have never replaced in the 5 seasons I owned it was the distribution blower, auger and the board.
    ivanhoe likes this.
  19. IHATEPROPANE
    IHATEPROPANE
    Can you check the ohms on the igniter? Not sure what they are supposed to be. But have heard some go all at once and some go slowly. Perhaps you got a chit one
    ivanhoe likes this.
  20. D-Mac0211
    D-Mac0211
    Upstate, ny
    But it was working perfect up until like a few days ago. It’s getting warm enough to turn the pellets Black idk
    ivanhoe likes this.
