expired oil??
Discussion in 'Everything Else (off topic)' started by Greenstick, May 31, 2015.
  1. Greenstick
    Greenstick
    You ever forget? I forgotted. Stumbled across a six pack of one gal mini mixer bottles of 2 cycle. Foil seals are intact but can't remember when these were bought. They were in an unheated yard shed knocked off back of a shelf and hung up between a stud and shelf leg. 5 years old or less cuz I didn't have them when we moved here. Can this go bad or is it good forever?
  2. rottiman
    They will be fine.
  3. Minnesota Marty
    Minnesota Marty
    Eastern Minnesota
    I just used some from when I moved and unpacked the box they were in. Mine were about 5-6 years old. Worked fine. IMO you are good to go.
  4. Horkn
    Dead dinosaurs can't expire anymore. :)
    You'll be fine.
  5. Backwoods Savage
    I have some that is approximately 30 years old. It is still good. The can is sealed so no dirt got in...
    yooperdave and Minnesota Marty like this.
  6. Greenstick
    Greenstick
    I watched to see when I poured and didn't see any milky from condensation:yes:.
    Backwoods Savage and Horkn like this.
  7. yooperdave
    Back in the 80's I bought a six pak of lawn boy 2-cycle oil in the pull tab cans at a rummage sale. I think I have one left! Stuff is great and never even thought there would be such a thing as an expiration date....
    (I use it for "emergency" when I run out unforseen at the cottage)
  8. redneckdan
    redneckdan
    Northern Minnesota
    There are 4 major ways oils 'expire':
    Contamination
    Depletion of Additives Package
    Shearing out of Grade
    Oxidization
    None of those four is going to happen to a sealed container in the span of 5 years.
  9. Greenstick
    Greenstick
    That's kinda why this pack was bought. Out cutting and was about out of oil and only store near by only had six pk gallon mixers. Finished cutting on last tank and didn't need to mix more. Got home and put it up and mixed a batch out of the big bottle n just forgot about the little ones.
  10. HDRock
    Sealed up, looks good , I wouldn't worry about it :)
