Equipment trailer help
Discussion in 'Everything Else (off topic)' started by eatonpcat, Apr 27, 2021.
  1. brenndatomu
    I can bring some tools/supplies if you want...better pop the rest of the lights out an check them too...also look underneath for damage...if its too bad a new wiring harness would be easier
  2. brenndatomu
    o_O
  3. brenndatomu
    NAPA usually has the lights and plug repair pigtails...TSC and Rural King too...
  4. eatonpcat
    Underneath is good, the mice got into the tail lights and wreaked havoc. I am sure I have all the tools, just don't want to delay out trip. We will be fine, 90% of the trailers seem to have bad lights.
    T.Jeff Veal, Eckie, Horkn and 5 others like this.
  5. brenndatomu
    If that's the case it wouldn't take too long to pop some new lights and repair pigtails in there...running with intermittent clearance lights is one thing, no tail or brake lights is another!
    I can try to get there a little earlier to help with this if needed (wanted) and you probably do have a bad fuse in the truck now if you lost all the trailer lights...
  6. eatonpcat
    Truck fuses are definitely good, if you give me a list of parts and wiring needs. I will have them here.
    But the magnetic lights give us brake lights, turn signals and running lights.
    Appreciate the offer, just not sure on time frame!
  7. brenndatomu
    True, but IME getting them to stay on can be a trick sometimes, especially on a longer trip at highway speeds.
    Just take the light(s) with you to get replacement(s) and then grab some repair pigtails for them too...and we'll need some blue butt connectors...I have some dielectric grease, electrical tape, and heat shrink I can bring to seal things up.
  8. eatonpcat
    Will do, appreciate it my friend!
  9. eatonpcat
    I have the grease and tape and will get some heat shrink. I don't have a butane torch for the heat shrink. Where do I get the pigtails?
  10. brenndatomu
    I have a torch...and most any place that has the replacement lights will have the pigtails too...
  11. amateur cutter
    Use heat shrink butt connectors & a heat gun. There's only two types of pigtails on those oval lights, if you buy a kit they usually come with the lights. Brighter colored wire is brake/turn. Yellow wire on trailer is LT green is RT & brown is tail/marker. Go big & put led's in it, they're much better & brighter. 20 minute job & you're on the road.
  12. brenndatomu
    You talking the ones with low temp solder in them?
    If not, I've had much better luck with a standard butt connector filled with grease before installing...I fill them with the nozzle of a squirt bottle stuck in the end (like the restaurant style ketchup/mustard squirt bottles) go until it comes out the other end...
  13. huskihl
    huskihl
    Lol.
    Get pics
  14. Eric VW
    Why would you want to see that...? :whistle:
  15. huskihl
    huskihl
    Future fuggery?
  16. eatonpcat
    I will be way too busy laughing to take pictures!!
  17. Chvymn99
    You all ain’t right....:rofl: :lol:... that’s pretty nasty thing that those mice did...
  18. Horkn
    What a bunch of degenerates!
    Can't wait to meet you all!!
  19. amateur cutter
    Nope, those suck. Crimp connectors with the heat shrink insulation & sealer inside. Please no pics of blowing troopers!:rofl: :lol:
  20. T.Jeff Veal
    The mice or members???:p:p:p
    After meeting them, it's proba6 the 2 legged ones...:rofl: :lol::rofl: :lol::rofl: :lol:
    eatonpcat, huskihl and brenndatomu like this.
