Enviro M55 Cast Insert - Agitator Drive Chain
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by eatonpcat, Dec 23, 2015.
  1. gbreda
    gbreda
    NH
    OUCH...BFH it is
    IHATEPROPANE, ivanhoe and slvrblkk like this.
  2. slvrblkk
    slvrblkk
    Northampton, PA
    Nope, that's all he'll need! :D
    IHATEPROPANE, ivanhoe and gbreda like this.
  3. imacman
    imacman
    Denver, NC
    That, plus WD-40 and duct tape.......what can't you fix???
  4. gbreda
    gbreda
    NH
  5. brokenwing
    brokenwing
    Northern MD, Near the PA LIne
    Eaton having this stove there is a another scenario I can think of. While It may sound crazy let me see if I can explain. Every once in a while when the agitator is running, I will here the fingers get caught on some pellets in the burn pot pushing the agitator up, and then you will here a crunch as the pellets break and it continues to turn. While this does not happen every cycle, it does happen. I am wondering if something like this could of happened causing excess pressure on the drive mechanism and popping the chain and bending the bracket. I know it sounds far fetched, but at times that agitator takes on a fair amount of pressure. How do you have your stove programmed. Do you have the agitator turning with every revolution of the auger, or is yours running on the premium pellets, where it turns once every 30 minutes?
    imacman, IHATEPROPANE and ivanhoe like this.
  6. smoke show
    smoke show
    Pittsfield, Wi
    Its a possibility brokenwing but if I know eatonpcat as well as I think, he let the chain get out of adjustment. :D
  7. eatonpcat
    I would like to argue this point...But you are most likely correct!! :picard:
    ivanhoe, imacman, jtakeman and 5 others like this.
  8. eatonpcat
    I run on Premium Pellet mode...It seems possible, just hard to think that the steel would fail before the pellets!! I guess if a pellet(s) somehow got wedged and the auger was pushing against the strong axis anything is possible.
    Thanks for your input Brokenwing! :yes:
    ivanhoe, imacman, brokenwing and 4 others like this.
  9. brokenwing
    brokenwing
    No problem, and I know it seemed far fetched, but I was trying to think of all of the possibilities. :yes:
    ivanhoe, imacman and eatonpcat like this.
  10. schoondog
    schoondog
    Dutchess County N.Y.
    A couple of years ago, when we had the American Harvest insert, the wifey hung the stockings with care....... right over the hopper. Of course someone dropped something in the hopper and in this case it happened to be a piece of cardboard that got jammed in the auger, not the agitator, and it shut the stove down. Could something have fallen into the stove and got past the auger to wedge the agitator and burn pot ? Have you found anything funny or unexplained lately ? Do you even have stockings hung on the fireplace? Guess it don't matter as Smoke, JT and Imac said, smack that sucker back into shape and let it agitate away !!
    Doggy
    ivanhoe, brokenwing, imacman and 2 others like this.
  11. smoke show
    smoke show
    Pittsfield, Wi
    :rofl: :lol: Just pretend it's name is Dottie and smack it around some. :bug:
    brokenwing, ivanhoe, imacman and 2 others like this.
  12. eatonpcat
    Nothing blocking the agitator Doggy...Smokeshow is the only agitator that I want blocked!
  13. eatonpcat
    Smacked her around earlier...gonna get some Christmas cookies now!!
  14. brokenwing
    brokenwing
    Shots Fired, I am taking cover :rofl: :lol:!
    In all seriousness while you got that thing taken apart check your wiring harness Eaton. When I first got my stove it was popping a fuse, and the dealer could not figure out why. I started tracing wires, and found the convection fan rubbed the insulation off a wire, and it was shorting out. I had to cut the wire. solder it and then I put heat shrink tubing over it. No problem since then. I went through the whole cabinet with a few zip ties doing a little wire management, because the bozos at the factory must of been dreaming about there next coffee break!
  15. eatonpcat
    Will do BW...I usually check the wiring because I worry about it getting caught somewhere when I slide the unit in and out!!
  16. eatonpcat
    :eek:
    Shut up Smokeshow!! :D
  17. gbreda
    gbreda
    NH
    While managing your tie downs, being more liberal with the lubricant can ease your binding issues
  18. eatonpcat
    :eek:
    slvrblkk, imacman, smoke show and 4 others like this.
  19. ivanhoe
    ivanhoe
    Northern Ontario
    I hear KY jelly is a good lubricant:whistle:
    slvrblkk, imacman, brokenwing and 2 others like this.
  20. brokenwing
    brokenwing
    This thread is now gone down the toilet! :rofl: :lol:
    imacman, gbreda, ivanhoe and 2 others like this.
