Enviro auger bushing.
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by jtakeman, Dec 6, 2014.
  1. imacman
    imacman
    Denver, NC
    During the startup procedure of my stoves, I had always put a couple drops of light oil (3 in 1 or teflon-based TufOil) into the bushing....never had an issue.
  2. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    slvrblkk likes this.
  3. jtakeman
    Well it doesn't say I have to pull the auger or lube the bushings in the manual. So I'm going with a defective part! :p
    5 years of use and never lubed, Plus to wear the flange clean off. It had to be stuck and spinning for a while. I guess I better add the lube once a season or pull it every once in a while.
    SmokeyTheBear and slvrblkk like this.
  4. badbob
    badbob
    Methinks you all are imbibing some adult beverages?:drunk:
  5. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    You should have noticed the metal shavings. I vote weld that sucker to the plate and use a liberal amount of dry moly on the auger shaft.
  6. badbob
    badbob
    The flange is the thrust surface for the auger.
  7. jtakeman
    Well, I do blast the crud of with an air tank. Might have seen it if I didn't do dat! I did notice some bronze fillings stuck on the auger motor once I dropped it. But it was already too late.
    Don't forget I'm an old quad burner. Ran the little beauty for 8 seasons and never pull-lube the ol cork screw auger once! :emb:
  8. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    It will have some metal to thrust against just not its former flange. Sometimes you have to be creative, just don't get flustered if your creation bites you in the hind end.
  9. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Get a proper critter as soon as possible and remember what happened to the former one so you don't have a repeat.
  10. jtakeman
    The plate had a worn area/spot were the flange used to be. Plus all the replacements(current and the old revision numbers) all showed they have flanges.
    Notice the replacement plate has a flanged bushing as well.
  11. jtakeman
    Will do and I'll also stock up on other replacements. The bushings are cheap so I'll get 3. Prolly order a spare auger motor from Gleason along with the agitator motor too.
    List might get rather long before I'm done. But a Low limit-High limit-Air Switch and the Agitator sprocket's will also be added. And any other thing I think I might keep me down for more that a day.
    I definitely will add to the list of parts I already carry!!
    Control board √
    Combustion motor √
    Convection motor √
    Igniter √
    Air Pump √
    Agitator *used spare
    Agitator chain√
    imacman likes this.
  12. pell it
    pell it
    Rhode Island
    Did you check TSC for that bushing? I know they have std size flange bushings. (bought some for the front of my old Wheel Horse)
    jtakeman likes this.
  13. jtakeman
    I might pop over tomorrow. Didn't know that had them! Thanks for the tip!!
  14. imacman
    imacman
    Denver, NC
    Grainger?
  15. jtakeman
    I'd have to drive to Brookfield(70 miles) to the nearest. TSC is 4 miles away and HB Guildford is less than 15 miles. Both are on my way home from work. Plus I aint seen my buddy Harvey in some time now!
    imacman likes this.
  16. DexterDay
    DexterDay Administrator
    Northeast Oh
    Sounds like you got it covered Jay :) And wow do you have a nice list of spare parts!! :thumbs:
    I noticed the bushing on my Fahrenheit is spinning (making a louder humming noise now). This thread has inspired me to look at it now. I did put some 3-n-1 oil on it last weekend, but it still sounds louder than it should.
    jtakeman and slvrblkk like this.
  17. slvrblkk
    slvrblkk
    Northampton, PA
    Dex...on a side note...have you tried the Clean Energy's yet?
  18. jtakeman
    Geez! Is dem pellet all you think about? Some one get him a brew!! :cheers:
    :Yar:
    :p :vulture: :rolleyes: o_O :loco: :crazy: :wacky:
    slvrblkk, imacman and SmokeyTheBear like this.
  19. DexterDay
    Northeast Oh
    No. My BIL bought 2 ton, but I won't see him until Christmas. It will be a nice Christmas present though. :)
    Pics. . Because it happened. ;)
    imacman, slvrblkk and jtakeman like this.
  20. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Me thinks that the Dex is getting old, that pellet testing thing just doesn't seem to get his juices going anymore.
    DexterDay and slvrblkk like this.
