Englander NC30 deal .....ordered
Discussion in 'Modern EPA Stoves and Fireplaces' started by papadave, Mar 12, 2014.
  1. papadave
    Thanks Al.
    I'll look around some more too.
    Can't seem to find anything else, so a ordering I will go.
    NortheastAl likes this.
  2. jeff_t
    jeff_t
    SE MI
    Yeah, don't try to buy a probe locally [​IMG] I've tried twice, all the up thru there.
    papadave likes this.
  3. papadave
    You don't think Freddies will have one? :)
    I could check the hardware store, but I doubt they'll have anything.
    Stove shop in Lewiston might.
    Unless I'm already headed over there, I'd spend almost as much in gas as I would just ordering the thing.
    jeff_t and raybonz like this.
  4. raybonz
    raybonz Moderator
    Carver, Mass.
    Little did Carly realize that it would be 2014 when Dave FINALLY got a new stove.. Just think she was anticipating Dave getting a new stove back in 1971! Now she's a wretched old woman who doesn't remember ever singing that song lol..
  5. papadave
    I was in love with her for a little bit back then.
    However, she didn't even know I existed.
    I was 17 that year. :)
    NortheastAl and raybonz like this.
  6. raybonz
    raybonz Moderator
    Carver, Mass.
    Yup! You, me and 10,000,000 other 17 year olds! In 1971 I was 14 and a freshman at Vocational HS..
    NortheastAl and papadave like this.
  7. Locust Post
    Here she is last year with Taylor Swift....I don't know about wretched, maybe old.....same as us.
    papadave and raybonz like this.
  8. papadave
    Al, I ordered the probe thermo. you linked. It should be here about the same time as the pipe.
    Thanks for that.
    One small problem in the plan.....my wife has been going through her "sewing room".....(I'm still amazed she can fit 20lbs of crap into a 5lb bag), and there are boxes all over the stove room and living room.
    She wants to put at least one set of bunk beds in there for the grandkids, so it's for a gooder cause, but wow.........
    We'll make it work.
  9. jeff_t
    jeff_t
    SE MI
    I stopped at Freddie's, right after they started selling the 'hearth accessories'. He told me he ordered a probe for somebody, and they would probably keep one in stock. Nope. I have stopped in Fairview three times, and they just have an empty hook where one should be hanging. Makes it hard to support the local economy, but I guess the folks at Amazon hafta eat, too.
  10. NortheastAl
    NortheastAl
    Putnam County NY
    Dave, it always comes down to more work than anticipated to get a project done. Gotta add in those cushion days on any projects.
    You should like that probe. I've used it this whole heating season. Much easier to tell when you're heating your house or just heating the flue. With mine, I get the stove top and flue thermometer within 100 degrees of each other to get a decent burn. If I can get the stove hotter'n the flue, then I'm golden.
    You'll experiment to see what works best with the 30, and you'll be glad you got the flue thermometer. Let us know how it goes.
  11. papadave
    The Selkirk doublewall just got here a few minutes ago.....wasn't due until Thursday.
    It should give me about 5" to fit it, then slide it open. Came with a finishing band.
    I'll need to look at the instructions again, since both ends are crimped, but I'm thinking this end goes in the stove collar.
    And, this end goes into the ceiling support adapter with the finishing band around it.
  12. papadave
    Checked the brick behind the single wall this morning with the IR gun. Between 155° and 160°.
    Hoping this will drop that a bit, although that's probably fine.
    I tend to "overkill" sometimes.:rofl: :lol:
  13. NortheastAl
    NortheastAl
    Putnam County NY
    Dave, I have the Duravent double wall and the adapter goes on the stove collar. Kind of looks like the opposite of what your install may look like. If it has stickers on it, like mine still does. Reading them right side up will show the direction of installation. Try to check an install pic on the net to confirm. Also, you may want to call Selkirk to make double sure.
    Good luck. I know you will keep the heat off the bricks with the double wall.
  14. NortheastAl
    NortheastAl
    Putnam County NY
    Dave, ok, I'm dyslexic. I Reread your post, and think you do have it right. I was reading the captions for the pics in the wrong order.
  15. papadave
    Lysdexic.:rofl: :lol:
    Just got a call from the freight company to confirm stove delivery tomorrow morning between 9-11 a.m.:thumbs:
    I think the bottom pic makes more sense at the ceiling with the finish collar over it.
    Can't see putting the finish collar going over the other end. It just has me confuzzled because the male pipe at the ceiling will be going counter to most other suggestions of male down.
    HDRock likes this.
  16. jeff_t
    jeff_t
    SE MI
    The class A adapter at the ceiling will fit inside of that crimped end, and the finishing band covers it all up. If you needed a stove adapter, it would look the same. Crimped end up, but the inside crimp in the pipe fits inside the crimp of the adapter. If that makes any sense. Lots of crimping goin on. It's pretty obvious when you go to put it together.
  17. NortheastAl
    NortheastAl
    Putnam County NY
    Dave, just had an epiphany. When the pipe is expanded, the outer pipe goes to the ceiling mount. Seems counterintuitive compared to single wall, but after looking at mine, that is how it goes.
    papadave and jeff_t like this.
  18. papadave
    Ok, that's the way I thought it should go.
    I did a quick measurement (pipe is hot right now) and it looks like the adapter will fit down inside the doublewall crimp, then I can put the finish ring over it.
    Guess I'll find out tomorrow.:)
    Jeff is saying the same thing.
  19. papadave
    Well, look what I found buried under all the packing peanuts in the box.
    Pallet Pete, milleo, HDRock and 3 others like this.
  20. Woody Stover
    Woody Stover
    Southern IN
    IIRC from installing a telescoping section on my BIL's (formerly my) Fireview, it'll only fit one way.
    Yeah, those may come in handy. :D
