Englander NC30 deal .....ordered
Discussion in 'Modern EPA Stoves and Fireplaces' started by papadave, Mar 12, 2014.
  1. papadave
    Does the gasket look damaged (or partially missing)? Unless the door hinges were mounted too far to the left, that's about the only thing I can think of that would cause a gap there. Just looked at mine and the gasket is to the right of that cutout by at least 1/4", if not 3/8".
    NortheastAl, bushpilot and chipper1 like this.
  2. chipper1
    chipper1
    Grand Rapids Mi
    He bought it used and they said sorry, if you were the original purchaser we'd help. To me it's a safety issue and should be taken care of no questions asked, fire hazards are no joke, just got off a raffle thread on another forum for a guy who lost his home to a fire(not that a wood stove caused it, I don't know the cause, but sad none the less).
    NortheastAl and raybonz like this.
  3. chipper1
    chipper1
    Grand Rapids Mi
    It appears the door was mounted to far to the left.
    I'll try to get some pictures of another forum.
    NortheastAl, Chvymn99 and papadave like this.
  4. raybonz
    raybonz Moderator
    Carver, Mass.
    I don't expect them to supply parts but technical support.. Not impressed!
    NortheastAl and chipper1 like this.
  5. bushpilot
    bushpilot
    Eastern Washington
    Mine is like papadave 's.
    Looking for pictures, there might be an easy fix of some sort.
  6. yooperdave
    I'll check mine also, but I haven't had any problems with it so.......
    NortheastAl, chipper1 and papadave like this.
  7. brenndatomu
    Oh boy, here we go again, another Englander with the hinges welded on in the wrong spot?! :headbang: What the hairy is goin on down there these days?! :hair:
  8. Chvymn99
    Wow... This is my third Englander and I've always had good service. Had my first NC13 that was 2 years old and discovered that the top wall where the gaskets seals off was bent inward during heat ups. They replaced with no problems, minus logistics issues. Then got the big brother. I wonder whats going on here lately, doesn't seem quite right.
  9. chipper1
    chipper1
    Grand Rapids Mi
    Is this a somewhat normal thing you've heard of.
    Somewhat easy for a handy guy.
    I suggested welding a plate on the inside(mind you I've never seen the inside of one before), then filling the moon shape with weld as needed, grind flat.
    Not bad if you have what you need to do it. But the question begs why should you have to. Another question what happens if there was ever a problem, would this void any liability, would your insurance company walk away from covering a claim because the stove had been modified.
    Inquiring minds want to know.
    NortheastAl likes this.
  10. brenndatomu
    Not "normal" no, especially on the 30, but it is at least the third Englander stove I've heard of the with the hinges seemingly welded on wrong just in the last 6 months.
    chipper1 and NortheastAl like this.
  11. bushpilot
    bushpilot
    Eastern Washington
    I kind of doubt the hinges are off. There really is no room to move them left without going into the radius of the corner.
    chipper1, NortheastAl and yooperdave like this.
  12. NortheastAl
    NortheastAl
    Putnam County NY
    5BDBFB72-C398-4094-B8B4-F014C00AE3AB.jpeg Just looked at this image online. Does the door line up like this?
    chipper1, DexterDay and bushpilot like this.
  13. chipper1
    chipper1
    Grand Rapids Mi
    The tech at the factory told him he could cut the hinges off and reweld them on as an option, seems that if someone can mess something up they will sooner or later :(.
    What a bummer, wonder what's happening, I'd think the door/hinges would be in a jig of sorts to prevent this type of thing from happening. I guess if the jig was only on the right side and the door/hinges were not pushed tightly up against the jig this could happen.
    As I'm thinking out it it seems that if you know of at least 3, there must be many more, and those are the ones that made it past "quality control", seems there are some things at the plant that need to be fixed.
    NortheastAl, milleo and raybonz like this.
  14. brenndatomu
    Yeah seems a little odd that the Englander employee that usually hang around these sites has been MIA too...
    chipper1, NortheastAl and raybonz like this.
  15. moresnow
    moresnow
    Interesting on the above statement. Care to divulge the gents username? I have zero beef. Just interested.
    Sometimes I wonder about the questionable issues that pop up on different stove makes/models. Disgruntled/poorly trained employee's? Nobody would be dumb enough to intentionally mess up a stove during manuf. ? Then again. Who would let one get away and be sold that was incorrect? Strange days indeed.
    I'd be very cautious welding. My luck I'd warp the area. Another sealing problem to remedy! Good luck.
    Mitch Newton and NortheastAl like this.
  16. raybonz
    raybonz Moderator
    Carver, Mass.
    Think it is mike holton ..
  17. brenndatomu
    I don't recall his exact user name here...he mixes it up just a bit between sites...anybody else remember Mikes user name here?
    Looks like I was typing while raybonz already handled this...:thumbs:
    chipper1, raybonz and NortheastAl like this.
  18. Bags
    Bags
    Union, KY
    His user name here is just his name. Mike Holton Other places he goes by stoveguy or an arrangement with that like stoveguy2esw.
    I haven't seen him around anywhere though.
    chipper1, NortheastAl and papadave like this.
  19. Marvin
    Marvin
    Huntingdon, Pa
    Reviving this one for a quick question...
    When you guys talk about where you set the air control knob in relation to the ash lip, how far on to the rod did you install the knob? Is it on the whole way so the rod comes through the big coil to the end or just far enough to come to the end of the tight coil? Just curious...
    I put mine on just far enough to get the tip through the small coil...
  20. DaveGunter
    DaveGunter
    Mine are pushed all the way on with the rod all the way through the spring.
    Chvymn99, Marvin and NortheastAl like this.
