Englander/Drolet/Century: what brand should I get?
Discussion in 'Modern EPA Stoves and Fireplaces' started by wildwest, Oct 26, 2014.
  1. wildwest
    Wyoming high plains
    The good news is that its in and giving great heat.:dancer: Unfortunately its too far back into the fireplace to use the faceplate. We had a heck of a time getting the stove, adapter, and liner to meet up. :zip: We are both beat, so I think it will stay bare this winter...:whistle: Its called flex pipe, but its not "flexible" LOL
    HDRock and fox9988 like this.
  2. DexterDay
    DexterDay Administrator
    Northeast Oh
    Can you trim the existing plate to fit in the recessed area? Or maybe fab a custom plate?
    Looks great either way and insulating the liner was money well spent. :)
    HDRock and wildwest like this.
  3. wildwest
    Wyoming high plains
    New observation, sustained wind eats logs, sucked a fully stoked firebox empty in 3 hours. I used to tighten the air caps all the way down and tilt the damper on my old stove, this one only has one lever. Thank goodness its not our primary heat.
  4. fox9988
    fox9988
    NW Arkansas 72717
    WW are you monitoring the surface temp of the stove? Its a little hard to do on some inserts but if its sucking down a load of wood every 3 hours you maybe over-firing. Is it putting off tons of heat burning like that? Thats 14.4 cuft/day if you fed it day and night :bug:
    wildwest likes this.
  5. wildwest
    Wyoming high plains
    You have me thinking. This is the first time its done that after running 24\7 for days now.
    The best explination I can come up with is that my husband forgot to close the door this morning @ 7 am, but you'd thing I would have smelled smoke!?! When I checked it at 10 am there were ashes dancing & flying inside, it didn't phase me because my other stoves I had to open the door to see, and the wind suction would pull those ashes but this was through the glass w door closed. This is a sealed stove, should they blow and get sucked up the chimney with the door closed?
    I just stole the thermometer from the pellet stove, stuck it on the side of the firebox. I will monitor it tonight when he lights it again. Something doesn't add up eh fox?
  6. fox9988
    fox9988
    NW Arkansas 72717
    Not sure I'm following you.?
    If he left the door open at 7, it would have been open when you checked the stove at 10. Was it open? I assume you mean cracked not wide open. If my stove door were left open or cracked there would be no smell of smoke in my house.
    Maybe he left the draft all the way open. I've never seen ash blow around in my stove but I've seen the flames blowing like it had a bellows on it.
    With the ash blowing, I'm guessing the door was cracked.
  7. wildwest
    Wyoming high plains
    I think you nailed it, I should have said cracked open. The draft was less than 1/4 open. Little emabarresed, should I delete the false alarm post above?
  8. fox9988
    fox9988
    NW Arkansas 72717
    Nah, thats part of it.
    How long did the 10am load last?
  9. wildwest
    Wyoming high plains
    I put in 2 more logs that didn't light, so the fires been out since then...:whistle:
  10. fox9988
    fox9988
    NW Arkansas 72717
    :picard::doh:
    :D:D:D:whistle:
    papadave and wildwest like this.
  11. wildwest
    Wyoming high plains
    :whistle::picard::doh:
    It's ran fine since then:thumbs: Thanks Fox!!
    fox9988 likes this.
  12. wildwest
    Wyoming high plains
    Cruising @ 575*
    papadave and fox9988 like this.
  13. fox9988
    fox9988
    NW Arkansas 72717
    Where is the thermo?
  14. wildwest
    Wyoming high plains
    there is a couple inch's gap on the side before the faceplate starts, I stuck it there. Where would you suggest?
  15. fox9988
    fox9988
    NW Arkansas 72717
    I'm not very familiar with the 13i but the hottest spot you can find. I've seen them above the door off to one side on some inserts.
