Engine overheat help
Discussion in 'Everything Else (off topic)' started by Well Seasoned, Dec 3, 2021.
  1. Well Seasoned
    Im stumped..... I had success today after i burped the system while idling. First time I was able to get the heat to work
  2. Creekin
    Creekin
    Manitoba
    What i do for burping air is run with cap off till thermostat opens and ensuring i have heat out the vents, if it heats at idle it should have all the air burped
    Another thing that helps is a funnel that fits tightly on the fill port partially filled
  3. Well Seasoned
    I ran that burp bucket snug in the radiator opening, ran it full throttle a couple times, and it filled up quick.
    I went with a aftermarket thermostat, and shoulve tested it first. Not easy to get to, especially in 17deg weather.
    I "think" i burped it enough..... Was finally either boiling or releasing air.
  4. Creekin
    Creekin
    Manitoba
    Depending how in depth you want to go, a leak down test would tell you if its a head issue,
    Yank the plugs and pressurize the cylinder with valves closed, if you get bubbles or a geyser out the rad you have definite proof
  5. Well Seasoned
    Sounds complicated......
  6. Well Seasoned
    Then its time to drill holes in the thermostat? :whistle:
  7. Creekin
    Creekin
    Manitoba
    Most oems use a Stant thermostat, haven't had many issues with them, years ago different story, 2 or 3 to get one that worked properly, THAT SUCKS!!
  8. Creekin
    Creekin
    Manitoba
    Its not bad, been awhile since I've done plugs on one
  9. Well Seasoned
    I might get an oem tomorrow with a rad cap in St J subaru after work
  10. Well Seasoned
    Ill have to youtube that one.
    Backwoods Savage, Horkn and Creekin like this.
  11. Creekin
    Creekin
    Manitoba
    Buddy at the local ford dealership used th open the thermostat by hand and hold it partially open with an aspirin tablet, let him fill it much easier and pill would just dissolve
  12. Well Seasoned
    Ill probably take one too..... To keep my heart valves open!
  13. Creekin
    Creekin
    Manitoba
    I agree, start with cheap/easy stuff first
    Seen too many young techs go down a diagnostic rabbit hole when easy stuff was overlooked
  14. Well Seasoned
    I shouldve boiled or torched the thermo before i spent all this time putting it in. It was wicked tight with the gasket around it. I could barely keep it in place.
    Backwoods Savage, Horkn and wildwest like this.
  15. brenndatomu
    My first thought is that the impellor is gone off the WP shaft...but the intermittent thing kinda blows that...and you keep getting air...its possible that a head gasket is leaking compression into the coolant system...would explain how you keep getting air. Do you have a radiator pressure tester? That would tell the story
  16. Creekin
    Creekin
    Manitoba
    If you do, then often you can see the pressure pulses on the gauge
  17. Well Seasoned
    I don't, but thinking i might get one. Any suggestions?
  18. Well Seasoned
  19. Creekin
    Creekin
    Manitoba
    Looks ok, price isn't bad either
  20. wildwest
