Engine overheat help
Discussion in 'Everything Else (off topic)' started by Well Seasoned, Dec 3, 2021.
  1. Warner
    Warner
    When you were going through it with the other guys did you find a ground at the back of the frame? I don’t 100% remember the location and my computer with the info is at work. If the fuel pump driver module is bad the truck won’t start but that shouldn’t cause the lights to go out. I really suspect that ground back there on the frame by the passenger or driver wheel. Again a load test for ground at the plate lamp will tell a lot quickly.
    Also do you have any DTC’s?
    Horkn, Eric VW, Creekin and 1 other person like this.
  2. Well Seasoned
    I dont recall seeing any ground wire towards the rear. Didnt see anything on the frame. There were a bunch on the front passender fender, one on the frame under the driver door. The ONLY spot we didnt check was above the spare tire.
    Also..... Half of the big black square fuses were warn, the other half wasnt. We coyldnt get them out at all.
    I dont know what a dct is
    Eric VW and Horkn like this.
  3. Horkn
    Diagnostic Trouble Code
    Well Seasoned and Eric VW like this.
  4. Well Seasoned
    Found the likely culprit after cutting the cable holding the spare tire.
  5. Well Seasoned
    In my picture above, i think that's the case. I'l need to remove the plate which i think this connects to. I'm not sure which wire this is yet
  6. Creekin
    Creekin
    Manitoba
    Sweet, hope it fixes it, should be an easy fix!!
  7. Creekin
    Creekin
    Manitoba
    The fuel pump module has a habit of rotting where it mounts to the frame, unbolt it and the aluminum will be all flakey, might even have a hole in it
    If it doesn't, the fix to prevent it was to elevate it off the frame with studs and nuts that keep a gap so anything doesn't accumulate under it
  8. Creekin
    Creekin
    Manitoba
    That looks like the main ground for the rear of the truck
    Chaz, Horkn and brenndatomu like this.
  9. Warner
    Warner
  10. Horkn
    Looking very suspect...
    This should be it.
  11. brenndatomu
    Oh...that's not just the spare tire static safety strap...? :whistle: ;)
    That sure ought to fix something! :thumbs:
  12. Canadian border VT
    I am not a mechanic BUT that could be a problem :smoke:
    Chvymn99, Horkn and brenndatomu like this.
  13. Well Seasoned
    Chit..... grinded down to new metal new connector but still no rear lights ect. I'm gonna charge the battery awhile check again and move on to whatever could be next
    yooperdave likes this.
  14. brenndatomu
    Me personally, I would disconnect the battery terminals, make sure they are nice and clean, charge the battery, then reconnect...sometimes these bus system controllers need "resynchronized"
    Horkn and Well Seasoned like this.
  15. chris
    chris
    SE WI
    actually the repair for the fuel pump control was to isolate it from the frame, cause- dissimiller metals in contact with each other in a caustic environment= galvanic corrosion. repair mostly requires replacement control unit with an isolation kit as the moisture gets inside the case and corrodes the connection terminals up into the potted board.
    My first experince with this was a 1980 datsun king cab pickup 4wd. It would start losing one cylinder at a time- ( 4 banger) using the oem repair manual the very first thing to do was remove the computer assembly from the block. I never could find the problem at first and it always ran fine again until it got damp out side then it wood rear its ugly head . after a couple weeks of this, I was driving down the road and the proverbial light bulb lit up. computer assembly- Alum case- grounded to cast iron block. The alum. wood oxidize losing electrical connection. the mere cracking of a bolt lose and retightening would solve the problem for awhile- pulled buffed it out greased the h out of it problem resolved. ( first year production -third month)
    Horkn, brenndatomu and Well Seasoned like this.
  16. Well Seasoned
    I did that, truck started I'll let it run a bit.
    MikeInMa, Horkn and brenndatomu like this.
  17. Well Seasoned
    Any way to run this broken ground i thought i fixed to another ground, even another vehicle via a jump start cable?
  18. Warner
    Warner
    You could certainly run it back to your battery.
  19. chris
    chris
    SE WI
    M most vechicles now have constant power to one side of the the component. the computer system controls the grounding either directly or through a relay. systems operate above chassis ground
  20. Well Seasoned
    Some of these suggestions seem outside my mechanical skills. :zip:
    Horkn and Canadian border VT like this.
