Electric Heater Suggestions for old Ice House (hubby got a new office!)
Discussion in 'The DIY Room' started by wildwest, Dec 23, 2014.
  1. wildwest
    He cleared out a 10' x 10' closet. Put in a window and electrician ran power. The building was the "ice house" many years ago for the railroads, 6' (6 feet) concrete slab underneath, its hard to heat. He wants to lay carpet with decent pad too. What would any of you suggest?
    I bought a quartz infrared heater a couple years ago that he likes, think it has 6 crystals. Will the infrared help the cold concrete slab?
    At the moment there is a wall mounted electric fireplace on sale, would be a space saver, but I wonder about the cold concrete.
    What else?
    Thanks!
  2. Grizzly Adam
    Grizzly Adam Guest
    I suggest a nice rug first :) Those quartz heaters work pretty decent, I prefer the ones with real thermostats built in.
    wildwest likes this.
  3. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
    Yep that concrete will just suck the heat out of there. Any electric space heater should do a good job. Don't fall for the Eden-Pure sales pitch.
    Gary
    wildwest and concretegrazer like this.
  4. wildwest
    Gary, that brand of quartz heaters? Or all quartz heaters in general?
    Thanks
  5. Grizzly Adam
    Grizzly Adam Guest
    That brand. I think the heaters work well, but the box store heaters work as well as the Eden Pure.
  6. Daryl
    Daryl
    Don't spend too much. They are all the same 1500 watts.
    IHATEPROPANE, fox9988 and wildwest like this.
  7. brokenwing
    brokenwing
    Northern MD, Near the PA LIne
    Just my opinion but we had a Eden Pure heater, and it ran not stop through the winter for almost 4 years straight. Electricity bill was always low, and that thing kept the upstairs toasty warm. It finally gave up the ghost and I ordered a 70 dollar infrared heater from lowes. It is just not the same, and does not heat the upstairs as well. I will miss that heater, but I kept hearing everyone saying there all the same, so I tried out a cheaper replacement option, which is working just not as well.
  8. My IS heats my home
    My IS heats my home
    Albany, NH
    I'm thinking Martha Stewart could come up with something :)
  9. brokenwing
    brokenwing
    wildwest and My IS heats my home like this.
  10. RockyMtnHigh
    RockyMtnHigh
    Bailey, Colorado
    I use this one http://www.northerntool.com/shop/tools/product_200632947_200632947?cm_mmc=Bing-{adtype}-_-Heaters, Stoves + Fireplaces-_-Electric Heaters-_-45209 solely to heat up my bathroom either when it's 0F or colder (to keep pipes from freezing) and when I take a shower. This thing will heat a pretty small space when it comes down to it depending on what type of comfort level you are working for. Aside from that I'd say put a pellet stove in there or make him run on a treadmill for 10 minutes every half hour :p
  11. wildwest
  12. wildwest
    He ended up with something like you linked. As matter of fact the pics look almost identical, wonder if the same manufacturer is selling under different brands names for different store chains? Paid $5 more than Northern Tool, but worth it for instore pickup. Once there he'll find an area rug, and done! He's done his time in a less than ideal "office" if you could call it that for 4 years.
    Thanks for all the advice.
    RockyMtnHigh likes this.
  13. RockyMtnHigh
    RockyMtnHigh
    Bailey, Colorado
    I think there are a number of companies buying up a ton of them and re-badging them as almost all of them look the same to me. Some have a little bit different casings and button set ups but really they all do the same thing from what I've read.
    I'd still hold out for a cheap used pellet stove if there is room in there, the quartz heaters (or infrared or whatever they want to call them) do still chew up more electricity than a pellet stove according to my electricity bill.
  14. chris
    chris
    SE WI
    I think to get away from that slab say a 1/2" or better dense foam and then a 3/4" plywood over that for the floor carpet or tile on top. That should be enough to maybe keep the toes warm and not allow that slab to suck all the heat out. you could due the same for the block walls with some paneling over the foam. random thought if this is your own place.
    RockyMtnHigh and wildwest like this.
  15. wildwest
    I'm afraid this is a large closet, not enough room for a stove, the property is leased, but he has freedom to make changes as needed :) Fortunately he is not in the office full time so this should take the edge off at the times/days he is in there all day.
    Also, there seems to be construction material around often, he could even put some spare of that under the carpet to insulate against the floor!
    Thanks for you excellent thoughts.
  16. lukem
    Put down some DRIcore panels on the floor and whatever flooring you want over the top. If there's a lot of mud involved carpet may not be ideal...a sheet of vinyl or peel and stick tiles may be better. The DRIcore will have add some insulative value. They uninstall quickly if the landlord objects somewhere down the line.
    If you want to heat it full time some electric baseboard panel are easy to install and pretty inexpensive. If you only want to heat it occasionally (i.e. when he's in the office for short periods of time) then look for something that will produce quick heat with forced air.
  17. wildwest
    Major issue that has been conveniently overlooked :emb: Thanks!
  18. lukem
    If it is a 10x10 square a sheet of vinyl will be cheap, easy to DIY, and clean up easy.
  19. wildwest
    ISO foam board, I finally remembered the name!
  20. Stinny
    I agree with rigid foam. I'd try 1" rigid with just the carpet over it... to try it and see how it works. Then, as others have said, plywood over the foam. We used to stand on a chunk of that foam between our boots and the steel deck on our crane truck. That %^$#&@* deck would pull the heat outa your feet in minutes, no matter what you were wearing for boots.
