Effect of moisture content vs burn
Discussion in 'The Wood Pile' started by Marshel54, Jan 7, 2017.
  1. Backwoods Savage
    For sure that would be best.
    Horkn, Chvymn99 and Woodsnwoods like this.
  2. brenndatomu
    There's always the "scrounge up some kiln dried lumber cutoffs and/or cut up some old pallets idea" too...just to be clear, this would just be mixed in with the regular firewood. Wouldn't want a whole load of this stuff by itself...especially after struggling with wet wood...likely some creosote in the chimney that could be lit off by a real hot "dry softwood" load
    Horkn, Chvymn99, Woodsnwoods and 3 others like this.
  3. TurboDiesel
    Me too
  4. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    At this point I suggest whacking 2x4 into pieces and buying a chuck of kiln dried hardwood lumber. If that burns, you know the issue is the wood. Do not mix any of your wood, burn just the lumber. You may have to supplement with bricks or find pallets etc, but at least you will know. Good luck
    Backwoods Savage, oldspark and Horkn like this.
  5. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Oh boy, here we go.
    Be warned also that wood that is too dry, thats right i said too dry, can cause other burning problems.....
    1st problem with too dry is overfire if your not carfull....duh
    2nd and not much discussed, too dry wood can gas off faster than the stove can supply air, this leads to extra fuel not being burned in the form of heavy smoke out the chimney.... this leads to creosote just as easily as wet wood....
    from the stove manufacturers themselves, these EPA stoves are engineered to run well on wood from roughly 13%-22% Mc
    Kiln dried wood in the 4% range will cause problems if you have a stove full of the stuff....
  6. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Thank god I do not have one of these EPA stoves. I burn the right moisture content in mine, but in the event I didn't I would not have so many headaches as it sounds like some of you do. Looks like the EPA stoves are solid supporters of the three year plan.
  7. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    I also did not mean filling the stove full. Small to medium sized load. i would be very advise filling with kiln dried and possibly over firing.
  8. OhioStihl
    OhioStihl
    Southern Ohio
    If he is in the south west part of the state then I can help him out on seasoned wood.
  9. Loon
    Loon
    North of the border
    Once ya get the hang of them Woods they are very simple.:yes: And the house cruises fine.;)
  10. Horkn
    I figured that.
    I just want to see this stove work how it's supposed to for him.
    I think we're all in that boat.
  11. Marshel54
    Marshel54
    I grabbed three pieces from the pile today and split them.
    Ash 17.9 to 19.4
    Walnut 18.2 to 19.6
    Maple? 1 split 16.9 to 19.9 the second half of the same split 16.7 to 24.1. Don't know what to make of this reading. Took the readings many times. Wood was not room temp. when I did the readings.
    This is not at all what I expected.
  12. Marshel54
    Marshel54
    For those of you that have asked. I am located about 15 miles east of Marion Ohio.
    I plan on picking up a package of Eco- Bricks Tues when in Marion.
  13. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    do it again tomorrow. bring your splits indoors and let them acclimate for 24hrs... the mc% is completely unreliable if not measured at about 70deg. F.
  14. swags
    swags Moderator
    Your probably a little over an hour or so away from me.
  15. Canadian border VT
    Marshel54 do not know what ya got for a truck or trailer.. but this is what I would do... it's January in ohio.. you got roughly 2 months left of winter.. get some bricks and take swags or somebody closer up on their offer.. bring truckload to them.. (they are really doing you a big favor to be friendly make it easy on them) take a truckload of dry home.. what's downside get a trip.. meet some nice people.. learn somethings.. EPA stoves ARE finicky about dry wood but once you learn then you get more heat from less wood!
    just my 2 cents worth what ya paid for it:handshake:
  16. walt
    walt
    north central ohio
    Sir I am 30 miles east of Marion,I am retired if there is any thing I can help you with let me know.
    If nothing else we can get together have a cup of coffee and talk wood
    PM me sometime, and it is good to have you here .
  17. Canadian border VT
  18. oldspark
    oldspark
    NW Iowa
    Sometimes stoves dont work well in certain installs, it happens, my Summit would not come up to temp no matter what I burnt in it.
    The scrap lumber is a good suggestion but as mentioned you have to be careful and watch the stove after all it is a box of fire in your house.
    I would think after the moisture is cooked out of your wood the stove should come up to a good temp but this would be a little later in the burn cycle, the fire would be sluggish to begin with.
  19. oldspark
    oldspark
    NW Iowa
    If cut to length it dries, the cell structure of wood is made up of what looks like straws so a lot of drying is done from the ends.
    Horkn and TurboDiesel like this.
  20. Canadian border VT
    A lot of that depends on the wood and location.. I realize your talking in generalities but the most extreme example birch.. will rot in less than a year cut to 16 inch length and not split.. in my area
    NH mountain man and Horkn like this.
