Effect of moisture content vs burn
Discussion in 'The Wood Pile' started by Marshel54, Jan 7, 2017.
  1. Marshel54
    Marshel54
    You are the second poster that has suggested eco bricks, what are they?
  2. Loon
    Loon
    North of the border
  3. yooperdave
  4. swags
    swags Moderator
    What part of OH are you from? If your close enough to me I have plenty of dry firewood and can get you some good stuff to try out on the new stove to see if the wood is the issue. I'm in North Canton
    I learned the hard way as well that a new stove really needs very dry wood. I burn in a cat stove and they are even more picky.
  5. Loon
    Loon
    North of the border
    Part of the problem I was having at first with the T5 swags was definitely the wood not being dry enough.:whistle: Had some help here and its been cruising great since.:salute:
  6. yooperdave
    Nice offer.
  7. papadave
    An awful lot of us have had issues learning about needing dry firewood............I'm in that group.
  8. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    me too....
  9. Loon
    Loon
    North of the border
    Was used to throwing pretty much anything in the old Drolet we had and couldn't get it through my fat head that the T5 really really likes dry wood.:salute:
  10. Butcher
    Butcher
    I know that when I first started using a newer stove it was a struggle for me also. Mostly the wood but there was a certain amount of operator error involved too. Old habits are hard to break.
  11. bushpilot
    bushpilot
    Eastern Washington
    I was always confident of the wood in my 30, but I doubted the draft, and did have some problems with the cap plugging. But I believe in my case, the problem was mostly operator error. I do not doubt that in many cases it is a combination of factors, including the dryness of the wood.
    But once you figure it out, it really works, and becomes the new norm, no more difficult than the old norm, just different.
  12. Lumber-Jack
    Lumber-Jack
    Have you done that yet?
    You can't expect to get a true reading on a previously split piece of wet wood because the surface of the wood can dry below 20% in about 24 hours in the right conditions while the inside can remain wet for months or even years with some types of wood.
    If you really want to troubleshoot your problem this is the first thing to start with, you already have everything you need.
  13. ansehnlich1
    ansehnlich1
    ew boy, how many times i've read a thread like this one. All I can say is, my wood is 3, 4, some of it 5 years sitting after it's been split, and I have a 6 inch pipe coming off my Jotul. Any deviation from that and my woodburning suffers....ie: Wood only sat one or two years after being split, OR, I have an 8 inch pipe. or worse, a large outdoor terra cotta liner.
    gboutdoors, Woodsnwoods, Loon and 4 others like this.
  14. Backwoods Savage
    Marshel54 we really feel for you and this problem. Sadly, many have faced the same problem as you but the good part is that the problem can be fixed. One thing for sure is that if you are near swags I would definitely take Sean up on his gracious offer.
    I would also invite and practically beg you to take the time to read the following article: Primer on Woodburning by Backwoods Savage (If the link does not bring it up right, then go to "Resources" and look for the Primer either at the top of the page or in the list.
    Canadian border VT brought up a great point about the MM. Most definitely the very first thing is that the wood needs to be freshly split and then don't wait; take the reading right away from the center of the freshly split piece; it will naturally be a bit drier toward the end. Also to be more accurate they say the wood should be at 68 degrees or more; not out in the cold we have now.
    But, knowing what you need and perhaps what you already have is not going to solve the immediate problem. Getting known dry wood is great but you can also get the bricks as others have suggested. One other thing you can do is to use the wood you have now and mix in some pallet wood or the bricks or both. This way you can use what you have on hand and try to get better for next winter.
    Along with this, I would highly suggest you sort out all the oak and not try to burn that this winter. Oak is indeed one of the very best but it tends to hold its moisture a long, long time. And as of today, we still have not figured out totally just what is the best way to burn water. And dry wood is the key to hot stoves.
    Once you get the problem solved, put a lot of thought and work into getting the right wood for next winter and the next one and the next one. Personally if at all possible I would concentrate on getting soft maple, white ash and elm; perhaps some cherry too. These tend to be a quicker drying wood. Caution though on the elm; it can be terrible splitting and I do not recommend splitting freshly cut elm. We cut the elm and split it only after all or most of the bark has fallen from the trees as then it will split better and burn better too. Soft maple we have burned in as little as 6 months after being split and stacked.
    I would also highly recommend you top cover all your wood; don't let rain and snow ruin your work. Some will claim they don't do this but by experience we can say without hesitation that you get better wood. True, we do usually split our wood here in the spring and stack it immediately then leave it uncovered through the summer but top cover before winter. It just helps the drying process but it does no harm and in fact helps in some wetter areas to top cover immediately.
    Another thing I would suggest to you right away is to take another peek at the chimney. Does it need cleaning? For sure with less than ideal wood it will need cleaning more often so please keep this in mind.
    Good luck.
  15. Lumber-Jack
    Lumber-Jack
    Great post Dennis, but I'm thinking you might have meant 6 months, not 60. :emb:
  16. swags
    swags Moderator
    I had some cherry this year that was half dead when I cut it early spring. I split it right away and it was piled under my carport between the stacks I had. Lots of airflow in there, I was really surprised when I checked a few pieces in November. everything i checked a fresh split on was between 14-16%. My father in law is burning that stuff now in his fireplace.
  17. brenndatomu
    If you got "economic bricks" you probably don't need to fart around with burning wood (unless its just for fun ;) :D :wacky:)
  18. Backwoods Savage
    Wow! Can't believe I didn't catch that one. Thank you, I got it fixed.
  19. brenndatomu
    I think he's closer to walt s area...
  20. swags
    swags Moderator
    Hopefully we get him some dry firewood to try out
