I meant EPDM but couldn't find how to change it. Still haven't ordered all the chimney stuff. It's a bit overwhelming. Do we need Silicone flashing for the metal roof or is EPDM enough. Silicone rates over 400 degrees EPDM only aroud 250 or so. Want to use stainless steel Duratech from ceiling through roof and Dura black 22 gage welded as stove pipe below.
Few thoughts on this one— 1. Did you get a through-the-roof kit yet? If your manufacturer recommends a certain kit for metal roofs, go for that kit. 2. Metal roof “jacks” may be used. They’re like the roof flashing that goes on shingle roofs. 3. Red HT silicone boot with proper install and sealant is preferred over conventional roof boots for pipes/ vents, etc.
Hi BuckthornBonnie, No code officers, inspectors etc. here My stove guy sells the cheapest stuff only and isn't happy that i won't buy his chimney pipes. i guess I'll go with the silicone for safety. The install will be straight up. We have a support bracket, then the flashing then a storm collar. Still have to decide if we should go with a special wind chimney cap.
