Edged tool restorations
Discussion in 'Axes, Mauls, and Hand Saws' started by fishingpol, Oct 25, 2016.
  1. Dancan
    Dancan
    ns canada
    HighCountry, savemoney and WeldrDave like this.
  2. Dancan
    Dancan
    ns canada
    Here's a hatchet I picked up a while back , polly a Granfors Bruks only marked "Made in Sweden" like many of their exports .
    I made a handle for it out of birch about 14" long .
    I used it for a bit but didn't like it , it was too "roundish" and would feel like it wanted to rotate in my hand so off it's head it was lol
    I had made a longer and a bit beefier one , about 18" for a worn out little broad hatchet but decided to put it on the little Swede hatchet instead .
    Nothing fancy but I use this one when I'm running the splitter to shear the stringy stuff apart or to cut off the odd branch that I missed with the chainsaw .
  3. Mag Craft
    Mag Craft
    South East Wyoming
    Very Cool Dancan.. I would like it twice if it would let me.
  4. wildwest
    Same here, not one replacement hickory stick in town that would fit his ancient maul, gaps too big for spacers. We were a bit desperate for the 3 y/o lodgepole to be split ( 2013 if you remember, wicked cold) so I ended up buying complete new mauls instead. He really does need a new wood handle since he slides his right hand while swinging over his head but he says the new rubber coated antislip handles are ok. Not sure I believe him.
  5. Rook
    Rook
    Connecticut
    Update, made a sheath.
    Maina, Valleyman, Gasifier and 12 others like this.
  6. WeldrDave
    Jon, :picard: dammit! :p I don't need to be collecting anything else!~ :whistle: Here we go....:headbang:
  7. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    I pretty much finished the clean up of the brush axe. There was quite a bit of pitting and no visible manufacturers stamp.
    I gave the handle a light sanding to remove the last of the finish. I wiped it down and rubbed some oil on it. The two edges were very sharp even for the rusty state it was in.
    Here is a great view where the axe bit/hook edge was forge welded to the body.
    There is no mark anywhere of who made it. Maybe it had a paper label.
    The handle is 32" long.
  8. fishingpol
    fishingpol
    It is all good collecting old iron. Heavy, but good.
  9. WeldrDave
    I got a couple pieces that were my Dad's, most of the stuff I have is "fairly" new relativly speaking, with in 20 years or so. I only have one old hatchet that was his, I believe go's back to the 30's.
  10. Ronaldo
    Ronaldo
    Are today's Collins axes/hatchets any good, as good as the older ones?
    Was in a local Ace Hardware and saw that they have a very large selection of new Collins tools.
    HighCountry and Bert like this.
  11. fishingpol
    fishingpol
  12. Bert
    Bert
    Out west.
    This one was a real wreck.
  13. savemoney
    I would like to see some pictures of those sometime. I would like to see some real tomahawks.
  14. TripleF
    TripleF
    West Central FL Coast
    fishingpol suggested I post these restored boys axes I hafted, sanded, couple coats boiled linseed oil, and paracord buffer.
    They will be given as gifts to my youngest grandson (older one already has his) and to their friend!
    Maina, WeldrDave, Gasifier and 14 others like this.
  15. Mag Craft
    Mag Craft
    South East Wyoming
    Very nice Triplef. I have thought about putting some parachord around the shaft to protect like you have there or maybe a piece of sheet metal. What you have looks nice.
  16. fishingpol
    fishingpol
    Well TripleF got me thinking about finishing my roofers hatchet today. It is unmarked, possibly a Plumb, based on others I have seen out there. The handle is maple I believe. I fitted the handle using a drawknife to rough shape the end and files for finish fitting.
    I had the handle in the vise with a piece of leather to prevent marks. I put the piece of pine under the handle to keep it from dropping down when working on it. It worked well.
    A few of the tools I use to work up the handle. the handle tapers slightly up near the top under the head.
    All finished up with the oil treatment.
    It will hang right where I work in the shop.
    Maina, Valleyman, Gasifier and 8 others like this.
  17. Mag Craft
    Mag Craft
    South East Wyoming
    Nice clean work.
    HighCountry and savemoney like this.
  18. Rook
    Rook
    Connecticut
    Today's antique store score. I know nothing about Merit but it only cost a few bucks.
  19. Bert
    Bert
    Out west.
  20. Rook
    Rook
    Connecticut
    Little soak in vinegar and a light sanding
