Echo or Husky, 50ish cc . 24" bar
Discussion in 'Chainsaws and Power Equipment' started by Cold Trigger Finger, Jul 24, 2025.
  1. fuelrod
    fuelrod
    Western Maine
    Being retired also and my trusty 044 started to gain weight (seemingly ) and I didn't have a 60cc in my collection...
    and I didn't want a $1k +/- saw at my stage of life ....
    and most any saw is faster than I am, or feel like being anymore...
    I decided on another echo after trying a little echo cs 490-? 50cc
    saw for light stuff and around the sawmill about 5 years ago. Very reliable for any saw let alone a $350 saw! I'm a couple of years into my cs 620p (60cc) and it's just as reliable as any of my 3 pull stihls of the past 40 years. A great all around saw that I run a 20" bar in hardwood. It was $600 several years ago and the "w" model has a full wrap handle.
    Maybe SKEETER McCLUSKEY will jump in on a particular model. He seems to be playing around with Echo's more and more (at his shop) and he's (seemed to have) been a Husky/Still guy primarily.
    It may be customer driven.
    You out there Skeet?
  2. SAWMIKAZE
    SAWMIKAZE
    PGH
    Or..get a 550 and a 50 gauge 24" tsumura light bar and have someone put a .325 tip on it and run rsp chain.
  3. brenndatomu
    Isn't that suited better for use on big bore/high HP saws?
  4. SAWMIKAZE
    SAWMIKAZE
    PGH
    Polar opposite
  5. Screwloose
    Screwloose
    I definitely would NOT recommend skip chain on a small powered saw for limbing.
    Horkn, T.Jeff Veal and brenndatomu like this.
  6. Eggshooterist
    Eggshooterist
    Erff
    I ran Stihl 23RSP on the 241 and will also on the redmax saws. Its a narrower kerf .325 than standard .325.
    T.Jeff Veal and Screwloose like this.
  7. brenndatomu
    Huh...I guess I'm misremembering that lil factoid...or non factoid in this case.
    I had it in my head that RSP was good "big boy saw" chain...oopsies :D
    Horkn, eatonpcat, T.Jeff Veal and 2 others like this.
  8. Eggshooterist
    Eggshooterist
    Erff
    The boxes say 23RS from my dealer. The pro part, I believe, is what they call it in other parts of the world.
  9. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    501 is a well built saw,very disappointing in stock form
  10. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  11. Screwloose
    Screwloose
    My brain confused RSP with RSF.
  12. Screwloose
    Screwloose
  13. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    My mom passed away...
  14. Screwloose
    Screwloose
  15. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  16. Elm-er Fudd
    Elm-er Fudd
    Kansas
    I switched my 4910 over to 3/8 and stuck a 28” on it just for gits and shiggles. Didn’t have any issues oiling it, but it was pretty nose heavy. I’m going to buy a 28” light bar and give that a go. The 4910 won’t pull 28” buried, but that is not the intention. I am a convert to the “stand up and buck” crowd now and will never go back. I found it a bit awkward at first but once I got used to it, I love it. All of my firewood saws now wear a minimum of 24” and I prefer 28”-32”. The only saws I have with less bar than that are 35cc or less and I only use those for pruning the fruit trees around the yard.
    Horkn, eatonpcat, T.Jeff Veal and 5 others like this.
  17. Mrxlh
    Mrxlh
    Dat Boot
    I run a 24” 3/8 full skip on mine.
    Horkn, eatonpcat, T.Jeff Veal and 4 others like this.
  18. Mrxlh
    Mrxlh
    Dat Boot
    Whew, good thing my 346 isn’t small powered…
  19. MuddyPaw
    MuddyPaw
    North Central Ohio
    I've had the same idea, in fact I have an un-installed .325 nose sprocket waiting to be put on a 24'' bar. You'll be hard-pressed to find pre-made loops of 24'' in .325. You'd have to make your own after determing the number of drive links. I did the math once but never did make the chain. Easier way is to probably get a 3/8 rim sprocket and run that. I can attest that a 501 oils heavy.
    Horkn, eatonpcat, T.Jeff Veal and 3 others like this.
  20. Ronaldo
    Ronaldo
    I don’t like skip chain for limbing and trimming because of the distance between cutters. For small limbs and little stuff I think a full comp chain is just smoother and works better. In fact I prefer 3/8 chain on my 50cc saws but I keep one with a 16” bar and .325 chain just for fence line work and trimming. It’s just less grabby and smoother cutting.
