Echo cs 730 hybrid
Discussion in 'Chainsaws and Power Equipment' started by Red97, Dec 19, 2017.
  1. Red97
    Red97
    Mi
    I have, don't think they will work too well.
    The cover bolts would be in the tunnels, or block the jug bolts.
    This case boltpattern is pretty much at it's limit with the sleeve od.
    J. Dirt, huskihl and Redfin like this.
  2. Red97
    Red97
    Mi
    Found a good platform for the billet jug.[​IMG][​IMG]
    J. Dirt, ChipsFlyin, Redfin and 2 others like this.
  3. Red97
    Red97
    Mi
    Put the hybrid in the hands of a faller, dropping some trees at my uncles.
    He had never run an echo before, didn't know they still made saws.
    Ran 660's then switched to 395's with a 24"
    I asked him to try my hybrid. 24" 3/8 light bar.
    He ran 3 tanks through dropping/ limbing to finish out the day.
    He said it was snappy, torquey, light nimble. And he wanted one lol
    He wanted bigger dawgs on it and a 20" bar to drop/buck some smaller trees tomorrow.
    So I swapped the 620 cover on for the extra dawgs. See how he likes that setup.
    Told him it's not for sale yet, just need someone to put some time on it and provide some feedback.
    Never met the fella before today, figure no better tester than a stranger.[​IMG][​IMG][​IMG]
  4. Red97
    Red97
    Mi
    Playing with the sleeve idea again today. Bore the 50mm jug to 2.188, heat the jug to 450* set sleeve outside 15*. Drop sleeve in .0015" shrink fit. Bore sleeve to 2.042 hone to 2.047/52mm
    Still have a bit more to hone, then carve out the ports. So far so good[​IMG][​IMG][​IMG]
  5. Red97
    Red97
    Mi
    Started roughing in the ports.[​IMG]
    J. Dirt, huskihl, p61 western and 2 others like this.
  6. J. Dirt
    J. Dirt
    That’s awesome to get that kind of an opportunity! I wouldn’t have had any doubts he’d like it either. That’s a sweet saw!
    p61 western and Red97 like this.
  7. Redfin
    Redfin
    central Pa
    How was it grinding on that sleeve Joe? Ive killed two flex shafts grinding on mufflers.
    p61 western and J. Dirt like this.
  8. Red97
    Red97
    Mi
    I figured he would be left wanting. Coming off a 395 24"
    But that wasn't the case.
    Honestly pretty well carving through. 071" at a time. Maybe just a bit easier than mufflers, think the wall thickness allows and angle to prevent chatter.
    I'll let ya know once I get to the uppers...
    J. Dirt, huskihl and p61 western like this.
  9. Red97
    Red97
    Mi
    These uppers ought to be in the 125*+ range vs the 118* of the current hybrid jug.
    If I do another I will srough in the ports before pressing the sleeve.[​IMG]
  10. Redfin
    Redfin
    central Pa
    Are you going to leave a bridge?
    J. Dirt and Red97 like this.
  11. Red97
    Red97
    Mi
    Yes, didn't get a measurement for the bottom, just the top.
    Poke a hole in then find the bottom.
    Using a 6 flute aluma hog burr. Working well so far.
    p61 western, J. Dirt and huskihl like this.
  12. Armbru84
    Armbru84
    Sparta, Michigan
    Did you use that one I gave ya Joe? Wonder how it worked.
  13. Red97
    Red97
    Mi
    Not yet. May give it a try. The longer shank will come in handy with the extra extension length I left on the jug.
  14. huskihl
    huskihl
    I don't think it'll like cutting steel. But she really flies through the aluminum. My exhaust ports are all a couple degrees higher using that burr lol
  15. Red97
    Red97
    Mi
    This is what I have been using so far.[​IMG]
    p61 western, huskihl and J. Dirt like this.
  16. Armbru84
    Armbru84
    Sparta, Michigan
    Very good point Kev...she won’t like steel much.
    Red97 likes this.
  17. Red97
    Red97
    Mi
    But what about cast iron?
    That one was made for aluminum...
    p61 western and huskihl like this.
  18. huskihl
    huskihl
    I wondered. The burrs look similar
  19. Red97
    Red97
    Mi
    Cast iron "chips" almost to a fine powder. Isn't hard to whittle on. Think the biggest thing is the better quality of the burr. Vs the cheap eBay ones that work ok in the aluminum.
  20. huskihl
    huskihl
    Yup. The cheap "hog" looking ones work well the 1st time or 2. After that, not so much
