Echo cs 730 hybrid
Discussion in 'Chainsaws and Power Equipment' started by Red97, Dec 19, 2017.
  1. Red97
    Red97
    Mi
    Progress...[​IMG][​IMG][​IMG]
  2. Red97
    Red97
    Mi
    Still have to set the roll pins to keep the plate from turning while boring the jug.
    Put the fixture in the big 4 jaw indicate the od, face off the outside. Flip it around face off the inside (where the jug will bolt)
    That hole will be bored to the diameter of the 590 extension, then drill tap the bolt pattern.
    This fixture will ensure the bore stays perpidicular to the base while boring. And the same stresses placed on the jug when bolted to the case will be mimicked here.
    The extension bore will be concentric to the tube of, so all that needs to be done is center the fixture, and press it agains the face of the chuck for set up.
    In the case the extension isn't centered on the bore i can still line up by checking the bore.
  3. Red97
    Red97
    Mi
    Little bit of progress. Hopefully Tuesday. I can finish it up and bore a 590 cylinder.
    Used some locktite retaining compound. Pressed the top in. Also put in 4 roll pins. Shouldn't move too far.
    Have to finish the through bore, face off the inside, and transfer the bolt pattern.[​IMG]
  4. J. Dirt
    J. Dirt
    Looking good! :D:thumbs: Always wanted to learn to be a machinist!
  5. Red97
    Red97
    Mi
    Getting closer[​IMG][​IMG]
    p61 western and J. Dirt like this.
  6. J. Dirt
    J. Dirt
    You said Tuesday and here it is Tuesday :thumbs:
    Nice snug fit?
    p61 western and Red97 like this.
  7. Red97
    Red97
    Mi
    Got a pretty decent finish cut. Hone to .0005" then polish the rest. Going to finish in 1500 grit.
    Going to try bare bore bare piston.
    590 jug at 50mm. +5mm over bore went from closed port to open lol[​IMG][​IMG]
    p61 western, J. Dirt and Barcroftb like this.
  8. Red97
    Red97
    Mi
    Since the 52mm sleeve didn't work too well in the 590 jug I decided to start the billet one.
    4.5" cube to start
    Roughed in the intake/Ex port angle
    Then drill the hole that will become the bore. 3 step
    7/8,1 5/8, and a 2" 4 flute core drill. Put the lathe in low and let er eat
    Used the junk base peace to transfer the bolt pattern, and scribed the outline.
    Started roughing to shape.
    Rough out around the ports, and above the ex. I can turn all the fins on the lathe. Well the top 5 fins anyway[​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  9. SquareFile
    SquareFile
    somewhere
    Definitely outside the box! Cool stuff.:yes:
    Your bore to finally size for sleeve? Figure out a coolant system?;)
  10. Red97
    Red97
    Mi
    Right now the extension is sleeve size. Once I get the block roughed out I'll have to turn it down to fit the case.
    After I layout the ports I'll bore it for the sleeve.
    Going to do a plain hemisphere chamber roughly 50% Squish area.
    Transfers are just going to be straight tunnels, like the stock 590 jug. Then the sleeve will close them off. I can get a little bit more depth to em, but the base is only so big.
    Just fins for cooling.
    Here is a pic of the stock 590 tunnels. Don't think I will be notching them that far right away. Seems like they wanted a lot of volume...[​IMG]
  11. Red97
    Red97
    Mi
    Well I ran 3 tanks through back to back this morning. 24" light feels really good.
    Most was large cherry, bar buried and quartered. Saw feels like it is finally settling in.
    I'm pretty happy with it. Did about 1/2 a tank of piled limb wood. That is were the weight/balance really shined
    I haven't cut that much in close to 3 years lol
  12. Red97
    Red97
    Mi
    Well got a bit more done on the fins...
    Ain't gonna be purdy. Getting a ton of deflection on the bit. Not staying very uniform.
    Ought to do the job still.
    Tip: Cut the fins first next time.[​IMG]
  13. Red97
    Red97
    Mi
    Some resemblance.[​IMG]
  14. Redfin
    Redfin
    central Pa
    Looking good Joe.
    p61 western, J. Dirt and Red97 like this.
  15. J. Dirt
    J. Dirt
    Taking shape for sure!!
  16. Red97
    Red97
    Mi
    Going to have to start hand carving soon..
    Might better order a spare cable for my grinder lol.
    Thank you sir.
  17. Fabz
    Fabz Banned
    Buffalo ny
    Lotta Work !
  18. Red97
    Red97
    Mi
    Have about 10 hours in so far..
  19. The Wood Wolverine
    Awesome to follow along. Thanks for sharin'.
    p61 western, Red97 and J. Dirt like this.
  20. Redfin
    Redfin
    central Pa
    Consider doing removable transfer covers?
