Echo cs 730 hybrid
Discussion in 'Chainsaws and Power Equipment' started by Red97, Dec 19, 2017.
  1. Red97
    Red97
    Mi
    Rd 2 cylinder take 1 and 2 lol[​IMG]
    Horkn, Barcroftb, J. Dirt and 2 others like this.
  2. J. Dirt
    J. Dirt
    Starting from scratch?! Ooooo. Aaahhhhh
    Can’t wait to see this:nerd::popcorn:
  3. Red97
    Red97
    Mi
    Gonna try it, with a cast iron liner.
    Lots of chips, head scratching, and colorful words to go...
  4. Fabz
    Fabz Banned
    Buffalo ny
    Horkn likes this.
  5. J. Dirt
    J. Dirt
    Mega displacement or going with sort of a size comparable to the stock cylinder?
  6. Red97
    Red97
    Mi
    Going bigger. 52mm bore. 79.8cc.
    I may make a sleeve for the jug im using and leave it 50mm just to get rid of the ring of death. Allow a little bit more playing with transfer timing. I have a scored up jug that would be the perfect candidate.
  7. Red97
    Red97
    Mi
    Thought about that, but I have no casting experience or stuffs.
    But I have made lots of chips. So billet seems like the way to go.
    The blocks were 30$ and 15$ for a sleeve. Just lots of hours whittling to get em right.
    Other than the outside fin area, I don't have a jug to make a simple mold from for casting. Likely have as many hours making a mold as whittling a block.
    Really do like the idea of casting, but not doable for me.
    Horkn and p61 western like this.
  8. Fabz
    Fabz Banned
    Buffalo ny
    So your plan is to machine everything from a solid block ? Anything’s possible but man that’s gonna take a looooooooooooooong time sir !
    Horkn and Red97 like this.
  9. Red97
    Red97
    Mi
    That is the plan.
    Then machine a cast iron liner to press In instead of having it plated.
    Sometimes time is easier to part with than $$.
    Horkn, Sty57, huskihl and 3 others like this.
  10. Fabz
    Fabz Banned
    Buffalo ny
    What machine(s) do you plan on using to do said project ?
    Horkn likes this.
  11. Red97
    Red97
    Mi
    Bridgeport and a lathe.
    p61 western, Horkn and Mag Craft like this.
  12. Fabz
    Fabz Banned
    Buffalo ny
    Numerical control ? Or as much power as you put into it ?
    Horkn likes this.
  13. Red97
    Red97
    Mi
    No power feed / digital read outs unless I use the big mill. But a 4" cube would look kind of odd on a 48×72 floor mill.
    Lathe does have power feed but that's it.
    Just old school lots of time and measuring.
    Realistically, leave the bore under size .080-.100". Leave an extension and some witness marks to reference in other set ups. finish the outside profile. then turn the base on a mandrel. Just like a std jug. The bore and base will be perpendicular.
    Then bore the jug to 52mm setup on case to lay out all the ports.
    Hog out the ports 70%
    Set the jug up like cutting squish. Bore then hone to size. Make the sleeve .003-5 press fit. Home I'd to final size then finish all the ports through the liner.
    Sounds good typed out anyway lol
    Horkn, Sty57, J. Dirt and 2 others like this.
  14. J. Dirt
    J. Dirt
    I’m thinking it will be pretty sweet all said and done especially to have pics as you go to show people after they watch the saw tear it up in the wood like the other echo !
    Barcroftb, Red97 and p61 western like this.
  15. Mag Craft
    Mag Craft
    South East Wyoming
    You could also pin the liner in place at the bottom of the jug where the ring never goes.
    Horkn, Barcroftb, p61 western and 2 others like this.
  16. Red97
    Red97
    Mi
    Less of a press fit, and just use a couple pins? That could be an option.
    I'm planning on keeping it a blind cylinder. At the base the liner will likely be clamped when the jug is bolted to the case. Keep it from sliding. Shouldn't want to rotate.
    I hope so. Billet jug will allow me to to dial in port shapes and sizes. Something echo typically leaves very conservative in the stock jugs.
    Horkn, J. Dirt, mdavlee and 4 others like this.
  17. Fabz
    Fabz Banned
    Buffalo ny
    Gonna be ALOT of whittling to make that stick sharp ! Just as a side note ... why not get it plated ... I have contacts with someone who would do it and it’s not as expensive as you think ... let me know when u get there if you are even interested going that route ... the pressed sleeve shud work just fine if you don’t wanna nikasil it !
  18. Red97
    Red97
    Mi
    Lot of whittling indeed.
    Nothing against plating, just the prices I have heard. Range between 180-210$ for a blind cylinder.
    melling makes a cast iron liner .94 wall 2" bore for 36$ long enough to make 2 sleeves. 18$ per attempt is pretty cheap. And. 047" from bore size. Not a lot of whittling time to make it fit.
    What price range is your source for a blind cylinder?
    Not gonna do a 2 piece head on this jug. Have the material to make whatever chamber I want. Not a luxury on a std jug.
    Horkn, J. Dirt, Mag Craft and 3 others like this.
  19. Red97
    Red97
    Mi
    Looks like the jug will handle 52mm. Now plate it or sleeve?[​IMG][​IMG]
  20. Barcroftb
    Barcroftb
    The Mitten
    Gonna have that sucker ready for tomorrow!?!:rofl: :lol:
