Echo cs 730 hybrid
Discussion in 'Chainsaws and Power Equipment' started by Red97, Dec 19, 2017.
  1. p61 western
    p61 western
    Northern California
    I like where your going with this. That would be really cool to have it at 52mm.
    Barcroftb, Horkn and Red97 like this.
  2. Fabz
    Fabz Banned
    Buffalo ny
    (In a high pitched female voice) “who’s that knocking at my door “(3x) said the fair young maiden ....... well ..... open the door you ...... ..... said barnacle bill the sailor
  3. Red97
    Red97
    Mi
    Added a small deflector to the flywheel side. [​IMG][​IMG]
    ChipsFlyin, Barcroftb, Horkn and 2 others like this.
  4. Fabz
    Fabz Banned
    Buffalo ny
    Do u have deflectors for sale ... 288s are great but a bit steep ! Thanks
  5. Redfin
    Redfin
    central Pa
    Ive been putting the mufflers in a toaster oven after adding your deflectors and painting them Joe. I let them bake for an hour.
    Seems to be working well. Make sure they are pefectly clean before painting.
    Barcroftb, Horkn, huskihl and 2 others like this.
  6. Red97
    Red97
    Mi
    Says to wait 1 hr before heating. Got a junk toaster it will go in for a bit tomorrow.
    This is the first one I've ever painted lol. Well second time, but first muffler.
    Barcroftb, Horkn and p61 western like this.
  7. Redfin
    Redfin
    central Pa
    I use the toaster oven to heat case halves also. Works very well.
    Barcroftb, mdavlee, Horkn and 3 others like this.
  8. huskihl
    huskihl
    How possible/feasible is it to cut off the fins around the exhaust port to give some room for welding around the exhaust flange to allow you to go wider?
    Barcroftb, Horkn, Red97 and 1 other person like this.
  9. Red97
    Red97
    Mi
    Center to center of those muffler bolt holes is 65%[​IMG]
  10. huskihl
    huskihl
    I see...:yes:
  11. Red97
    Red97
    Mi
    Now if one were to bore out the plating, and add a couple mm bore size. It may be worthwhile to have it welded wider before replating...
  12. huskihl
    huskihl
    If you're gonna do that, it'd be easy to fill the holes in and spread the pattern another 1/2"
    p61 western, Barcroftb, Red97 and 2 others like this.
  13. Redfin
    Redfin
    central Pa
    Dats like a whole nudder ball game.:cool:
    Barcroftb, Red97, Horkn and 1 other person like this.
  14. Mag Craft
    Mag Craft
    South East Wyoming
    Pretty cool stuff. That makes a pretty neat sleeper with all the covers on. Sounds like your having some fun there.
  15. Red97
    Red97
    Mi
    Yes and add 1/2" more length then machine the correct angle instead of a spacer. Same with the intake..
    Same game over and over gets old No? Gotta watch some rugby occasionally lol.
    Thank you. Beginning goal. Was Echo, 24"bar and light. Then seeing how well the covers fit. Sleeper saw. Now seeing how boring the jug will help get even better port timing. Without the plating will allow all the welding needed to make the jug fit without spacers.
    52 mm would add 20cc over stock. 1/3 more saw in the same chassis is pretty exciting to me.
    Plus Echo lol
  16. Red97
    Red97
    Mi
  17. Barcroftb
    Barcroftb
    The Mitten
    Liked the way it handled when I ran it the other day. Very nimble saw even with the 28 l&t you had on it. Can't wait to get my b!tch mits on it again in a couple days!:thumbs:
  18. Red97
    Red97
    Mi
    Imo, it feels a lot stronger than when you ran it last.
    Bigger carb, ignition advance, unlimited coil, more exhaust outlet. And porting.
    Picked up a 24" lightweight... gws other firewood saws lol
  19. Barcroftb
    Barcroftb
    The Mitten
    If it feels the way it looks in the vids I'm sure it's stronger.
    Horkn, Red97 and p61 western like this.
  20. J. Dirt
    J. Dirt
    o_O:bug::dex::saw:
