Echo CS-490 advice please
Discussion in 'Chainsaws and Power Equipment' started by the fuse, Mar 1, 2021.
  1. the fuse
    the fuse
    NY State
    As some of you know, we're doing our own clearing on the building site we have in VT. Last year I did a bunch of research on a saw that would fit the bill for me now and going forward to feed our stove. None of the trees we have to fell are bigger than 24". For a bunch of reasons, I chose the CS-490 with a 20" bar... budget and quality were high on that list. I know there are simple mods that will maximize that saw all over the web. I want to get it performing at it's best. I also don't want to make any mistakes trying to achieve that. I would appreciate any advice you folk have to offer.
    BTW I'm not new to operating a chainsaw. For years I fed a wood stove, down here, with a 14" Craftsman happy home owner special circa 1970. Time for an upgrade.
    tamarack, Rothk, Screwloose and 6 others like this.
  2. amateur cutter
    Muffler mod & re tune is the go to on those saws I think.
    Rothk, Screwloose, Chvymn99 and 4 others like this.
  3. the fuse
    the fuse
    NY State
    Thanks for the reply. I've seen the muffler mod done different ways, on the web, and have heard that the carb needs to be reset carefully to match the extra breathability the muffler mod provides. I'm handy, have tools, and am not a small machine mechanic by any means. Guess I'm looking for specific advice on best practice with this particular saw. (i need a little hand holding here) :tears:
  4. M2theB
    M2theB
    Central Massachusetts
    short of mods amateur cutter suggested, keep running a non e fuel and keep the chain sharp. A sharp chain adds a lot of hp to the sum of the work
    tamarack, JW IN VA, JC@ATL and 7 others like this.
  5. the fuse
    the fuse
    NY State
    Yeah, I'm all about non E gas. That's all I run in my outboard, leaf blower, weedwhacker, genny, and saws.
    This is how much (little) I know. What is an "re tune"? A carburetor tune?
  6. Eric VW
    Start here the fuse -
    Echo 490
  7. Mag Craft
    Mag Craft
    South East Wyoming
    For 24" wood I would have bought a bigger saw. But since you have 50cc saw and want a little more the easiest is a muffler mod.
    Take the muffler off and open up the diffuser or baffles inside the muffler and then open up the exit hole larger. You can go a big as the exhaust port on the cylinder.
    You can remove the spark arrestor but I do not recommend that. I always try to leave the spark arrestor in.
    When done blow out the muffler real good with some compressed air to get out all the little metal chips out.
    When the muffler is opened up it will get rid of the exhaust much easier and so it will draw more intake. So you will probably richen up the mixture a little on both high and low.
  8. James Miller
    James Miller
    Hanover PA
    The 490 has an empty can for a muffler there are no baffles. Pull the deflector off remove tube under it and cut the front of the deflector out.
    It will take longer to get the screws holding the deflector on out then to do the muffler mod. Those screws are a bitch.
  9. M2theB
    M2theB
    Muffler mod allows for more btu’s through the saw, if you add more btu’s. Making the change allows for more air, make sure the air filter is clean, and because of more air, you add more fuel to maintain the right fuel to air ratio.
    Should be able to richen up, lefty loosy, on the H and L screws and rightly tighty on the idle screw. Small changes.
    Lots of good tuning videos on the netw
  10. the fuse
    the fuse
    NY State
    Thanks to you all for the advice. I will take it. :salute:
    M2theB likes this.
  11. BuckeyeFootball
    BuckeyeFootball
    Youre going to need a special tool to remove the stupid limiter caps fyi.
  12. Ron T
    Ron T
    Northeast Ohio....Bowdil
    Drywall screw won't work?
    the fuse and Mag Craft like this.
  13. the fuse
    the fuse
    NY State
    I have seen u-tubes of the limiter caps pulled out by driving a screw into them and using needle nose plyers to pull 'em out.
  14. the fuse
    the fuse
    NY State
    I've adjusted the idle on my Kawasaki outboard and my Husky weedwhacker but I've never adjusted the carb on anything before. Any handy advice for a small engine newbie?
  15. the fuse
    the fuse
    NY State
    Well it has been a while but I'm back. Spent all last summer clearing our building site with the 490. I did the muffler mod and carb adjustment. I dropped, limbed and bucked up over 5 cords with it. I'm 63. My knees and back are prone to flairing up if I'm not careful. That saw is light enough for me to work all day with only minor aches and pains. Thanks for all the help guys. :thumbs: DSCN6748.JPG DSCN6754.JPG
  16. Eric VW
    Fantastic return!
    Sounds like great progress and good news about the saw performing well for you with minimal detriment to the ol’ body.
    :yes:
    Eggshooterist, Rothk and Chud like this.
